Utente del giorno: Q.dino con ben 3 Thanks ricevuti nelle ultime 24 ore
Visualizzazione dei risultati da 1 a 10 su 28
Rs GingerX 2.2.1
    Androidiano L'avatar di brerek
    Jan 2011
    Castellana Sicula
    Nokia5800
    Ringraziato 10 volte in 3 Posts
    Thumbs up
    Rs GingerX 2.2.1
    New Rs GingerX 2.4-GingerBread 2.3.3 with Sense 2.1
    New Rs GingerX 2.7.1
    Codice PHP:
    Changelog 2.7.1
    New Rs GingerX 2.7.1 only updated
    Updated build
    .prop
    Updated Updater
    -script
    Fix problem trasparency text
    To
    use the 2.7.1 update should install the Rs GingerX HD 2.7.
    New
    Rs GingerX 2.7
    Updated build
    .prop
    Updated
    and modied SystemUI.apk (notification)
    Updated Updater-script
    Updated Hosts
    Modified Personal Animation
    Added Trasparency By MarOkVe
    and Rs125
    Optimized
    and Speed Tweaks
    Created zip to
    return the graphics to Default
    Added Extra mod in download section
    ---Versione 2.6-------------
    New
    Rs GingerX 2.6
    Updated Google Maps to 5.3
    Updated build
    .prop
    Fix Notification Button Problem
    Updated Updater
    -script
    Updated Hosts
    Added Personal Animation
    and Rs125
    Optimized
    and Speed Tweaks
    Created zip to
    New
    Rs GingerX 2.5
    Fix dialer problem
    Updated Rom Manger
    Updated build
    .prop
    Updated Updater
    -script
    Changelog 2.4
    New Rs GingerX 2.4
    Fix Crash on boot
    Fix eReader problem
    Fast
    Stable
    Kernel Stock
    Mix on ROM Desire S
    Update build
    .prop
    Update Updater
    -script
    Update Rom Manager
    SystemUI by MarOkVe Styles
    ---Versione 2.3-------------
    New
    Rs GingerX 2.3
    New Base HTC 2.31.1400.1
    Add Advanced Power Menu
    Add BootAnimation
    Updated hosts
    Updated build
    .prop
    Add Root
    and SU
    Removed Stock APK
    Add DSP Manager
    New Rs GingerX 2.2.1
    Fix Wi
    -Fi problem
    Updated driver
    ---Versione 2.2-------------
    New
    Rs GingerX 2.2
    New base on 2.25 Stock ROM
    Removed stock apk
    Updated all app
    Add
    new Costum Boot Animation
    Add
    new Down Animation
    Updated hosts
    Updated build
    .prop
    Updated Power Menu
    Tweaked Framework
    Rooted
    +SU
    Updated all app
    ---Versione 2.1-------------
    New
    Rs GingerX 2.1
    Removed stock apk
    Updated all app
    Add
    Add
    new Down Animation
    Updated hosts
    Updated build
    .prop
    Fix SuperUser problems
    Add
    new RadioFM MarOkVe Styles
    Updated Power Menu
    Tweaked Framework
    Codice PHP:
    Per chi ha installata la clockworkmod Recovery 3.0.0.6 o successive
    Procedura per il flash:
    Scaricate la ROM.
    Copiatela nella root della SD.
    Scaricate l'allegato.
    Copiatelo nella root della SD senza estrarlo. Serve così com'è!
    Andate in Menu> Impostazioni> Applicazioni e andate sull'ultima voce.
    Disabilitate il fastboot
    Riavviate il terminale tenendo premuto il tasto volume giù.
    Una volta entrati in recovery scegliete "Install zip from sdcard".
    Scegliete il file che avete precedentemente copiato nella sd "Full-wipe-1.3.zip e cliccate sulla voce "Yes - Install..........."
    Finito il processo vi ritroverete nella schermata di prima.
    Riclicchiamo su "Install zip from sdcard".
    Scegliete questa volta la rom che avete precedentemente scaricato e copiato.
    Cliccate sulla voce "Yes - Install..........."
    Finito il processo dovrete cliccare su "+++++Go Back+++++"
    Ed infine cliccate sulla prima voce "reboot system now"
    FLASH CONCLUSO CON SUCCESSO
    FULL-WIPE-1.3.zip
    Before downloading I suggest installing the radio Radio_12.28e.60.140f_26.04.02.17_M2. To install the radio you need the eng s-off that are here.
    Installing the radio have better performance!!
    si deve aver installato la 2.7 prima di aggiornare alla 2.7.1
    DOWNLOAD 2.31.1400.1 ROM Based:
    Rs Gingerx Hd 2.7
    Rs GingerX HD 2.7.1 GRI40
    New Rs PureGoogle 1.0 GRI40
    Cangelog:
    Codice PHP:
     BaseOfficial GingerBread 2.3.3 Leaked HTC 2.31.1400.1
    New kernel:HTC Stock Kernel 1 Ghz.
    GingerBread and Google Launcher
        No OC Kernel
        ROOT
    (SU SuperUser Permissions)
    Unsecured boot.img
    Si ringrazia Rs125 per la sua fantastica ROM
    Ultima modifica di brerek; 20-04-11 alle 14:29
    Htc Desire HD
    Rooted
    RADIO: 12.28e.60.140fP_26.04.02.17_M2_SF
    ROM: Ics Sense 4
  2. Il seguente Utente ha ringraziato brerek per il post:
    angiotell (03-04-11)
    Mar 2011
    Thumbs up
    Ciao a tutti.
    Sto provando questa ROM da 3 giorni e ne sono stra felice.
    È veloce tiene molta ram libera e nn ho trovato ancora bug.
    Spero di avervi dato una descrizione semplice ed utile.
    Alessio.
    Sent from my Destre HD.
  5. #3
    Jan 2011
    Castellana Sicula
    Nokia5800
    Aggiornamento 2.4
    Htc Desire HD
    Rooted
    ROM: Ics Sense 4
  6. #4
    Androidiano L'avatar di vandamme88
    Jan 2011
    Ringraziato 15 volte in 9 Posts
    Scusate ragazzi ma io con la versione 2.3 ho il problema del caller id, cioè anche se mi chiama una persona di cui ho il numero salvato il rubrica non mi appare il nome ma solo il numero di telefono, sapete dirmi se anche voi avete di questi problemi? E se in questa versione è stato aggiustato? Grazie
  7. #5
    Androidiano L'avatar di nikorr
    Feb 2011
    ciao a tutti,ho questa rom da un paio di giorni ed effettivamente l'unico mio problema è quello del caller id come detto nel post precedente da vandamme....non c'è modo di risolverlo?grazie.
    p.s. ho la versione 2.4
  8. #6
    Androidiani Power User
    Dec 2009
    Rimini
    Quote Originariamente inviato da nikorr Visualizza il messaggio
    sara' risolto nella versione 2.5 che è in upload in questo momento
    ....segui il thread su xda
    [ROM][GRI40] GingerX v2.4 |GingerBread 2.3.3 with Sense 2.1 [2 APRIL] - Page 14 - xda-developers
  9. #7
    Feb 2011
    Grazie appena sarà possibile scaricarla la proverò
  10. Il seguente Utente ha ringraziato nikorr per il post:
    rs125 (07-04-11)
  11. #8
    Senior Droid L'avatar di rs125
    Aug 2010
    Rs GingerX HD 2.5 ONLINE...c'è anche una versione PureGoogle 1.0
    Rs GingerX HD e PureGoogle for HTC ACE
    GingerX & PureGoogle
    Rs Xtreme Series ITA for Blackstone and Topaz
    Rs Xtreme 1.9 ITA MaxSense 1.05
    Rs Xtreme 2.1 ITA Sense 2017
    Rs Xtopaz 1.1 ITA
  12. #9
    Jan 2011
    Castellana Sicula
    Nokia5800
    New download
    Htc Desire HD
    Rooted
    ROM: Ics Sense 4
  13. #10
    Androidiano VIP L'avatar di Orco
    Aug 2010
    Crema
    Ringraziato 183 volte in 170 Posts
    Quote Originariamente inviato da rs125 Visualizza il messaggio
    Bene, la pure google la proverò sicuramente per testare la shell 3D di SPB!! La Sense...... azz.... mi servirebbero 6 mesi di ferie per provarle tutte!!
    [SIZE=1]HTC Desire HD Rooted & ENG S-OFF
    ROM: SP33_ITALIA_1.0.0_AROMAfull
    RADIO: 26.09.04.11_M2
    KERNEL: 3.0.93-ucdx
    RECOVERY: 4EXTRecovery Touch 1.0.0.5 RC9
