Pagina 1 di 11 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 102
[EVo3d] [ROM] [ROM 5-7-12][Anryl] ICS 4.0.3 b04
    [EVo3d] [ROM] [ROM 5-19-12][Anryl] ICS 4.0.3 b18
    Installation
    UNLOCKING GUIDE
    S-OFF AlphaRevX
    TOUCH 4EXT RECOVERY
    4EXT recovery /\ czshare /\ 4shared
    AlphaRevX recovery 4shared /\ czshare
    Download ROM + md5 file
    format all partitions except sdcard to 4ext
    Install from sdcard in recovery
    for s-on download boot.img and flash via fastboot flash boot boot.img
    for ofiicial rom in u language dont forget to change u CID back to original state mine was HTC__032 "fastboot oem writecid HTC__032"
    ...... more to come
    ICS 0x beta from leaked 4.0.3 source in progress ....
    THANX FOOTBALL FOR THE SOURCE and mdeejay and lyapota for beats
    U need new firmware flashed before flashing Rom
    - from bootloader power+volDN as pg86.IMG 4 shared /\czshare/\ in root of sdcard
    - then with adb reboot recovery
    - with qtadb remove pg86.IMG from sdcard root
    - in recovery format system data cache partitions
    - and finaly flash rom.
    -= S-ON FLASH BOOT.IMG as allways with fastboot flash boot boot.img (extracted from ROM)
    - The firmware is in 4shared under ics folder it will flash New radio image .
    It's GSM ONLY
    BUGS : TELL ME .
    instagram. partialy working from b06 just turn cam the right way,?
    OK : 3D,GPS,WIFI,Bluetooth.......phereo3d,navigon...:ro lleyes:
    upload times CZSHARE 5min /\ share-rapid 8min /\ 4shared 45min /\ dropbox 10min but no traffic
    ROM 18 czshare /\ share-rapid /\ 4shared /\ E3D mirror /\ dev-host----*** 7effcca1d93197ba80c5d1f4e1997d5b
    - fixed boot.img script
    Due to script error from b10 to b17 u have to flash boot.img manualy sorry for the inconvenience in b18 fixed
    ROM 17 czshare /\ share-rapid /\ 4shared ----*** e18489dead4442187014ee21b6412d9a
    - changed tweaks to light due to FC
    - few minor fixes
    FOCUS BUTTON CAMERA FIX ATTACHED HERE FLASH IN RECOVERY thnx russof
    ROM 16 czshare /\ share-rapid /\ 4shared ----*** eb776bc678bc3349cc80245f962723e0
    - kernel tweaked
    - few more tweaks
    ROM 14 czshare /\ share-rapid /\ 4shared ----*** eb776bc678bc3349cc80245f962723e0
    - few minor changes
    - mkv 3d h264 aac works
    ROM 13 czshare /\ share-rapid /\ 4shared
    - Aroma installer fixed scripts for titanium backup , adjusted some more settings
    - minor xml fixes
    - TODO audio sound fixes to move apart xloud beats dolby for now select all three
    ROM 12 czshare /\ share-rapid /\ 4shared /\
    ROM 09 czshare /\ dropbox /\ 4shared /\ share-rapid
    - New beats
    - made on the device uploaded from it I love -TotalCommander
    - TWEAKZ included
    ROM 08 czshare /\ 4shared
    - fixing run-parts (init.d scripts)
    - tweakz included
    ROM 07 4shared /\ czshare
    - no need to wipe
    - fixing kernel ramimg removing debugs
    - fixing audio
    - totalcommander as default
    - new apps versions included i hope all
    TWEAKS for B04 , B03 , B02 ,B07
    -TWEAKZV6 from st@matis
    ROM 06 czshare /\ 4shared
    - * stuttering in the music player /\ Edit lpa.decode value in build.prop to false thnx jekyll86
    - * fm radio no sound
    05-07-12 ROM B04 ---- czshare /\ dropbox down again /\ 4shared
    added init.d support both cores online sdcard speed fix boot animation back with sound
    05-06-12 ROM B03 ----- czshare /\ dropbox /\ 4shared
    root OK , battery round mode thnx kevin525 , some apps updated
    from 02 to 03 no need to wipe
    05-05-12 ROM B02 ----- dropbox down for 3 days /\ czshare /\ 4shared.
    ROOT permission are not right so need to flash another root.zip
    New Qualcomm drivers included and rilhtc changed
    link rom Dev-Host - The Ultimate Free File Hosting / File Sharing Service
    link radio PG86IMG.zip - 4shared.com - online file sharing and storage - download
    Ultima modifica di Matrice; 20-05-12 alle 19:59
    Android And Apple Users
    @Se ti sono stato utile premi @Thanks
  2. I seguenti 3 Utenti hanno ringraziato Matrice per il post:
    bastard81 (07-05-12),japoco_poz14 (07-05-12)
    Anche qui Bug Fotocamera (quando si attiva lo zoom non esce la foto).
    Anche qui foto peggio rispetto a GB.
    Ora provo un pò il resto!
  5. #3
    morissio
    Quote Originariamente inviato da Matrice Visualizza il messaggio
    Preso da xda: As with all the ics roms camera will only be fixed when HTC release ics update for our device so it's just a case of waiting
  6. Il seguente Utente ha ringraziato morissio per il post:
  7. #4
    ottimo allora
  8. #5
    Senior Droid L'avatar di bastard81
    venezia
    GOOGLE PIXEL 6A
    Ringraziato 142 volte in 122 Posts
    ottimo allora
    ottimo hai fatto benissimo ad aprire questo post!!! chissà che riportando tutte le rom che usciranno a breve su xda riusciamo a far diventare questo forum il migliore tra tutti quelli che ci sono in giro!!!!
    a parte il bug fotocamera differenza sostanziali dalla rom virtuos oppure è la stessa ma solo con il mod della batteria???
    Inviata dal mio ONE PLUS ONE sandstone black
  9. #6
    Uguale con mod batteria. Non trovo differenza.
    Inviato dal mio HTC EVO 3D X515m Ics V 3.0.2 usando Androidiani App
  10. Il seguente Utente ha ringraziato Matrice per il post:
  11. #7
    venezia
    GOOGLE PIXEL 6A
    lo sospettavo... bè speriamo almeno che sviluppi qualche kernel interessante allora!!! anche perchè (opinione mia personale) il suo kernel era il migliore tra quelli disponibili!!!
  12. #8
    Androidiano VIP L'avatar di Snoob
    Torino
    HTC EVO 3D X515m
    Ringraziato 443 volte in 384 Posts
    Quote Originariamente inviato da bastard81 Visualizza il messaggio
    ho letto che aspetta la release ufficiale htc per poi lavorare seriamente sul kernel
  13. #9
    come tutti credo .-.
    Sapete mica se setcup è compatibile con i dual core?
    Grazie!
  14. #10
    morissio
    Grazie!
    Nello specifico non so, ma io uso con ottimi risultati questo CPU tuner
    Non facciamo come al solito, restiamo in tema al massimo scrivi nella sezione EVO 3D "base"
