Pagina 60 di 164 primaprima ... 1050585960616270110160 ... ultimoultimo
Visualizzazione dei risultati da 591 a 600 su 1632
[ROM] - Mwakious3DROM® based on stock ICS 4.0.3 sense 3.6/3d transformer
  1. #591
    Grazie ragazzi!!!!!!!!!!!!!!!!!!!!
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Quote Originariamente inviato da totobellomo Visualizza il messaggio
    la tua guida guich..... Quindi in recovery flasho la v7 e faccio prima un wipe completo??? O solo dalvik/cache
    Eh, non lo sapevo dato che, di solito, mettono il "thanks" quando la seguono
  4. #593
    Cattolica
    Quote Originariamente inviato da Stefano1996 Visualizza il messaggio
    uscito nuovo upload
    V.8.4 ONLY UPDATE ONLINE!!!
    --NEW! NOW ONE UPDATE FROM ALL PREVIOUS RELEASES!!!(STARTING FROM V.7.0 AND UP!)
    --NEW! FASTER & WITH BETTER BENCHMARK!!!MORE BATTERY SAVER!!
    --NEW! SOME SYSTEM FIXES/CHANGES!!
    --NEW! IMPROVED A LITTLE RAM USAGE!
    --NEW! mwakiousCAM mod v.7.0(optimized the cam even more)
    MORE CLEAR VIDEOS AND PHOTOS EVEN IN DARK!!!ALL OPTIONS WORK!! DO NOT GO IN DIRECT LIGHT THE CAM AUTO-CLOSES FLASH ,USE FLASH ON IF YOU NEED IT!(tested on 2 evo3d,autoflash works)
    #NEW! ADDED BRAVIA ENGINE MODIFIED FOR MY CAM MOD!!!
    --NEW!mwakiousSOUND enhancement OVERLOADED v.8.0!!FINALLY ALL OTIONS WORK!!BRAND NEW MOD!!!!
    NOW CLEAR SOUND FOR MORE TRUE SOUND IN ALL OPTIONS!!NOW YOU FEAL THE DIFFERENCE IN EVERY OPTION!!!
    #NEW! ADDED xloud MODIFIED FOR MY AUDIO FIX,MODIFIED SO IT WILL NOT BE AGRESSIVE!!!
    #added some files from the last fix from lyapota (THANK YOU!) for beats option ,
    #ADDED MORE EQ options,
    #DOLBY REAL DOLBY WORKING!!!
    #enhanced SRS MAKES YOU CRAZY!!
    #in FM Radio you can change from mono to stereo sound!!
    --cleaned the stock battery as sugested from some ppl in the thread!
    --FIXED ALL VoIP programs,NOW MUCH CLEAR SOUND!
    --FIXED the stupid file that broke system sounds(i'm very sorry about that)
    --NEW! beats is working in stream play,and registered movies
    --NEW! 3D/2D option in playing registered movies works good now
    --NEW! fixed sometimes data/signal drop
    --NEW! ADDED a bonus widget and app
    --New bootanimation from predator!!!(Ty predator)
    --fixed ALL permissions....
    --and more....
    --AND MUCH MORE!!!......
    Già
    L'avevano già scritto e i link per il donwload ancora non sono online
    C'è da aspettare ancora un po'
  5. #594
    htc evo3D
    Mwakious riposati ogni tanto
    Inviato dal mio HTC EVO 3D X515m con Tapatalk 2
  6. #595
    Cattolica
    Umh, anche dopo la calibrazione della batteria (8.3) i consumi rimangono elevatini
    Aspetto la 8.4 intanto
    Edit:
    Disponibile al download la v8.4
    Disponibile al download la v8.4 mirror
    Ultima modifica di iGuich; 08-06-12 alle 16:29
  7. #596
    htc evo3D
    8.4 in download
    Prima di installarla vado quindi di wipe dalvik+cache? Poi installo e dopo posso cancellare lo zip della rom dalla sd? Lì ho tutti dalla 7.0in poi ed iniziano a occupare un po di spazio
  8. #597
    Cattolica
    Quote Originariamente inviato da steek Visualizza il messaggio
    8.4 in download
    Cancellali pure.
    Si puoi fare il wipe dalvik-cache ma se hai lag o altro leggi qua (lo copio pari pari dal suo thread su xda):
    ATTENTION!!!THIS IA A FREIENDLY ADVISE:
    WITH V.8.4 YOU CAN UPGRADE FROM V.7.0 AND UP,IF AND I SAY IF YOU HAVE BLOCKS-LAGS-NO BOOTS ETC JUST MAKE A CLEAN INSTALL LIKE I SAY BEFORE,THE UPDATES ARE TESTED BY ME ON A CLEAN INSTALL AND UPGRADES FROM ALL PREVIOUS VERSIONS AND IT WORKS!
  9. Il seguente Utente ha ringraziato iGuich per il post:
    steek (08-06-12)
  10. #598
    Ringraziato 87 volte in 35 Posts
    ciao @ tutti!!
    sono molto orgoglioso di v.8.4....
    la batteria dura mooooollttooo di più e la rom e molto più veloce e pulita....
    il changelog che avete qulche post prima non è l'ultimo...lol
    ho agiunto anche la modifica del mail di htc con il fix per html!!!
    se vedete che il cell va lento etc etc...installate la v.7.0 (clean install)->avviate->> riavviate ->entrate in CWM ->ed installate subito v.8.4,non c'è più bisogno di tutti quelli intermedi....
  11. I seguenti 3 Utenti hanno ringraziato mwakious per il post:
    fpp90 (09-06-12),steek (08-06-12)
  12. #599
    Cattolica
    Quote Originariamente inviato da mwakious Visualizza il messaggio
    ciao @ tutti!!
    4ext
    Hanno quasi tutti, se non tutti, la 4ext touch
  13. #600
    htc evo3D
    Sono l'unico che ha ancora la clock e non mi ricordo più il resto del nome della recovery? non sento la necessità di cambiare.
    Cmq complimenti a Mwakious, questa rom ha una velocità bomba e il segnale.che prendo con il WiFi è migliore rispetto al notebook
