Pagina 86 di 164 primaprima ... 3676848586878896136 ... ultimoultimo
Visualizzazione dei risultati da 851 a 860 su 1632
[ROM] - Mwakious3DROM® based on stock ICS 4.0.3 sense 3.6/3d transformer
  1. #851
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Quote Originariamente inviato da sduzzen87 Visualizza il messaggio
    Install V.11.0 Athena GSM NEW ROM BASE AND UPDATES
    1. This is good clean install....
    1a.arrivando dalla mwakious v.10 (con ultimo Firmware/Radio già installato)
    -backup apps and contacts etc(sync with google, etc)
    -place v.11 + update on SD card
    -go to CWM/Recovery/4ext
    -clean dalvik- cache-factory reset or super_wipe
    -install v.11 (latest version of 4ext, must turn on smartflash)
    -boot once
    -reboot
    -reboot in to CWM/Recovery/4ext
    -only Clean/Wipe CACHE - DALVIK (on 4ext Wipe DALVIK + CACHE)
    -install Update V11.1 (latest version of 4ext, must turn off smartflash)
    -Reboot Enjoy
    1b. Coming from mwakious v.9.x or any other custom rom (with latest Firmware/Radio NOT Installed)
    -backup apps and contacts etc. sync it with google
    -place PG86IMG.zip (firmware/Radio) on the root of SD card (not in folder)
    -also place v.11 + update on SD card
    -go to bootloader
    -install firmware/Radio (this will format/wipe everything)
    -once done, remove battery, remove sd card.(Extra Notes #1)
    -remove PG86IMG.zip from it, Replace card.(Extra Notes #1)
    -go to CWM/Recovery/4ext via bootloader
    -boot once
    -reboot
    -Reboot Enjoy
    Extra Notes #1
    Removing PG86IMG.zip from sd card
    -if can boot your phone do via usb.
    -slide out the sd card before going into bootloader, select recovery and quickly replace sd card.
    for 4ext recovery user, even better, as you can mount it
    -ADB command, use a command to delete it or tell the phone to reboot in recovery
    -remove card and delete on another device
    Anche se è in inglese si capisce facilmente e sono elencati tutti e 2 i casi sia che si arriva dalla 10 sia che si arrivi dalla nove poi stasera finisco la traduzione scusate
    inviato col pensiero di aiutare
    se poi ti ho aiutato il thanks e gradito
    1) É buona cosa fare un'installazione pulita...
    1A: Arrivando dalla v10 con l'ultimo firmware installato
    - Fare un backup delle app, contatti eccetera...
    - Copiate la v11 nell'sd
    - Entrate in recovery (CMW - 4EXT - Other)
    - Clean dalvik - cache - factory reset o un super wipe
    - Installa la v11
    - Primo avvio
    - Riavvio
    - Riavvia in recovery
    - Solamente un wipe dalvik - cache (nella 4EXT wipe dalvik+cache)
    - Installare l'update v11.1
    - Riavvio e Divertiti
    1B: Venendo da un'altra rom o dalla mwakious v9.x (ultimo firmware non installato)
    - Bakcup delle app, contatti ecc...
    - Copia PG86IMG.zip nell'sd nel root dell'sd, non in sottocartelle
    - Copia la v11 nell'sd
    - Entra in bootloader
    - Lancia l'aggiornamento
    - Rimuovi la batteria e il file dall'sd
    - Riavvia in recovery tramite bootloader
    - Super wipe
    - Installa la v11
    - Primo avvio
    - Riavvio
    - Solamente un wipe dalvik - cache (nella 4ext wipe dalvik+cache)
    - Installa l'update v11.1
    - Riavvia e divertiti
    Note:
    Per eliminare il file dall'sd, usare un altro telefono con l'sd tramite usb, oppure tramite adattatore per pc
  2. I seguenti 3 Utenti hanno ringraziato iGuich per il post:
    japoco_poz14 (30-06-12),scorpion90 (30-06-12),tonyroma (30-06-12)
    Ringraziato 87 volte in 35 Posts
    grazie ragazzi per il supporto ed aver portato la guida!!
    buon divertimento e spero vi piace la nuova versione...ho messo molto tempo e tanti test....spero che il risultato vi piace!!
  5. I seguenti 8 Utenti hanno ringraziato mwakious per il post:
    fpp90 (01-07-12),giapas (30-06-12),iGuich (01-07-12),Mignolo (01-07-12),rspillo (01-07-12),scorpion90 (30-06-12),Snoob (01-07-12),tonyroma (30-06-12)
  6. #853
    Scusate, volendo installare la 11 venendo dalla 10.
    Da recovery faccio wipe cache e dalvik + factory reset, metto la 11, riavvio, poi riavvio in recovery wipe cache e dalvik e metto la 11.1......Però non mi parte =/
    Potrebbe essere che sul thread XDA parlando di: baseband(radio) 11.77.3504.00P_11.25.3504.06_M from official release 3.28.707 (Che dovrebbe essere nella 10)
    Mentre io ho: 11.77.3504.00P_11.25.3504.06_M - - - 3.28.401.1
    Con non mi parte intendo che dopo aver fatto tutto il procedimento, installo la 11.1, va a buon fine, riavvio, parte la schermata di caricamento con l'ampolla e poi diventa tutto nero.
  7. #854
    Cattolica
    Quote Originariamente inviato da Mignolo Visualizza il messaggio
    Hai sbagliato a seguire la guida:
    codice:
    - Installa la v11
    - Primo avvio
    - Riavvio
    Dopo i vari wipe, devi installare la v11, devi dare un reboot, fare un riavvia e tornare in recovery facendo solamente un wipe dalvik+cache e poi flashi la v11.1
  8. #855
    Quote Originariamente inviato da Guich666 Visualizza il messaggio
    E non è quello che ho scritto? AAAAh ooora ho capito! Quello wipe sarebbe la terza opzione dalvik cache! Io ho interpretato con wipe dalvik e wipe cache
  9. #856
    Cattolica
    Quel wipe* (Wipe = Cancellare i dati)
    Hai sbagliato ancora, o fai i 3 wipe uno dopo l'altro (wipe data/factory, wipe cache, wipe dalvik+cache) e poi flashi la v11, non la v11.1, dopo segui la guida e flashi la v11.1
  10. #857
    Aspetta, ci stiamo confondendo.
    Dalla 10. Ho fatto il wipe data actory, wipe cache, wipe dalvik+cache. Riavviato, è partito tuoo ok, riavvio di nuovo per sicurezza. Spengo, boot loader, recovery, wipe cache E wipe dalvik e poi ho messo la 11.1. E poi non partiva
  11. #858
    Cattolica
    Se dopo aver flashato la v11 e partiva, devi fare un wipe dalvik+cache e poi flashi la 11.1
  12. #859
    Si appunto, credo che il mio errore sia stato intendere il "wipe dalkiv+cache" con un wipe dalvik e wipe cache
  13. #860
    Alla fine wipando solo dalvik cache e non dalvik cache e cache ;D Funziona tutto, vi ringrazio infiniatamente per la pazienza
    MA dovevo wipare anche le cache? XD
    EDIT: Non mi funziona il root
    Ultima modifica di Mignolo; 01-07-12 alle 03:43
