[ROM]Yoda's IceCreamSandwich v2.0||4.0.3||Sense 3.6||Tweaks|
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Mi sembra doveroso farla conoscere a tutti perchè secondo me merita e andrebbe provata
    Yoda's IceCreamSandwich v2.0 || 4.0.3 || Sense 3.6 || 3.28.401.1
    Specification
    Base: RUU 3.28.401.1 test-keys HTC Evo 3D GSM X515m (SHOOTER_U)
    Android Version: 4.0.3
    HTC Sense: 3.6
    Kernel: Stock 3.0.16
    Recommended Radio: 11.77.3504.00U_11.25.3504.06_M
    Recommended Recovery: 4EXT Recovery
    Features
    ROM don't wipe DATA, only dalvik-cache and system partition, but if you have problems its recommended to make data wipe on first install this ROM
    fast, clean, smooth Sense 3.6 ROM
    deodexed and zipaligned
    rooted and busybox installed
    percent battery mod
    boot image with init.d support
    Leedroid Rosie and Status bar Tweaks
    removed unnecessary (for me, i like clean ROM's) apps from HTC - Full list in second post
    added and updated some apps - Full list in second post
    init.d tweaks - TweakZV6
    other init.d and build.prop tweaks
    CPU1 go offline when no needed...
    Sense 4.0 skin - thanks alper.s
    adfree hosts file - updated 31.05.2012
    gps tweak - changed NTP server to europe.pool.ntp.org
    ... some things that i don't remember :P
    Download
    ROM
    v2.0: Dev-Host || 4shared.com MD5: 520EA9850C1DBC3552DBD6D649D1B68B
    v1.0: Dev-Host MD5: A3E17D8BCBD838136F3E774A13625734
    Firmware
    3.27.401.2: Dev-Host MD5: 6FE49ECEED3ABED92B7C164580E643CD
    Changelog
    v2.0 - 02 June
    new base ROM RUU 3.28.401.1 test-keys
    more tweaks
    low keys backlight - less power consumption
    updated apps
    no need to install separately tweaks !! - now it's only one zip to install
    hosts file updated
    apn's updated - thanks anryl !
    working Beats audio added (go to settings -> beats audio -> switch it on, and chose headset type ! after make settings you must perform reset) - thanks lyapota
    camera mod - thanks pwnyourace
    Add panoramic camera
    Add HDR to camera
    Enable option for disabling camera sounds (focus and shutter)
    Enable ISO1250
    other tweks
    removed lot of unnecessary files from HTC/Android (HTC/Android Spyware and other rubbish)
    other things that i don't remember now :P
    v1.0 - 29 May
    initial release
    Known bugs
    Gameloft 3D games - we must wait for update them by gameloft
    Not all Lee's tweaks are working - we must wait for update for new base ROM,
    You tell me
    Todo list
    AROMA installer
    maybe a nice splash animation
    all lee's tweaks
    advanced power menu
    ...you tell me
    Installation
    ROM Installation:
    update your firmware (if you didn't make this earlier) to newest 11.77.3504.00U_11.25.3504.06_M (link above, rename it from PG86IMG_3.27.401.2.zip to PG86IMG.zip and put it on sd)
    restart Evo at least once after update firmware, wait for full system boot
    copy yodas_ICS_vX.X.zip to sd,
    boot to recovery, and install yodas_ICS_vX.X.zip
    ROM will format dalvik-cache and system partition,
    wait for boot, first boot can take few minutes
    enjoy Yoda's ICS
    Screenshot
  2. Il seguente Utente ha ringraziato iGuich per il post:
    japoco_poz14 (03-06-12)
    Cattolica
    Removed file v1
    • 3D_NFS.apk
    • 3D_SIMS3.apk
    • 3D_Spiderman_Stub.apk
    • AdobeReader.apk
    • com.htc.TrendsWidget.apk
    • com.htc.Twitter3DWidget.apk
    • Dropbox.apk
    • EReader.apk
    • Facebook_Client.apk
    • FusionStockWidget.apk
    • GenieWidget.apk
    • HtcFacebook.apk
    • HtcFacebookChat.apk
    • HtcFacebookChatWidget.apk
    • HtcGreader.apk
    • HtcGreaderWidget.apk
    • HtcLaputa.apk
    • HtcLaputaInstaller.apk
    • HtcLocationsWidget3d.apk
    • HtcNavigateWidget3d.apk
    • HtcNotes.apk
    • HtcNotesProvider.apk
    • HtcRichNotesWidget3D.apk
    • HtcTwitter.apk
    • IdleScreen_Stock.apk
    • MyShelf_Widget.apk
    • PlusOne.apk
    • ShowMe.apk
    • ShowMeWidget.apk
    • SoundHound_Freemium.apk
    • Stock.apk
    • teeter.apk
    • Twitter.apk
    • libAdobeReader.so
    updated/added files (in data folder)v1.0
    • [Update]Flash Player
    • [Update]Play Market
    • [Update]Box
    • [Update]Adobe reader
    • [Update]G Maps
    • [Update]G mail
    • [Update]G Street
    • [Added]Total commander
    • [Added]Sense 4.0 skin
    • [Added]Tweaks app
    • [Added]Titanium Backup
    Scusate se ho messo il quote e non il code, ma non mi fa allargare la finestra del code e quindi preferisco metterlo sotto il quota
    Ultima modifica di iGuich; 04-06-12 alle 14:59
  5. Il seguente Utente ha ringraziato iGuich per il post:
  6. #3
    Androidiano VIP L'avatar di japoco_poz14
    p500,Htc Evo3d, Note 2, Note 3
    Ringraziato 1,028 volte in 447 Posts
    sembra buonaperò ora non riesco a provarlamagari tra qualche versione
