Pagina 1 di 29 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 281
[ROM 32b] KiNgxKxlicK AOSP 2.1
    Senior Droid L'avatar di borjus86
    Aug 2009
    Ringraziato 67 volte in 54 Posts
    [ROM 32b] KiNgxKxlicK AOSP 2.1 ver 1.9
    Rom basata su aosp 2.1 by KiNgxKxlicK
    La rom eclair piu veloce e stabile che abbia provato..siamo arrivati alla versione 1.9 questo è il link:
    [ROM] [v1.7][FASTEST][STABLE] KiNgxKxlicK AOSP 2.1 "Updater Soon" 3/4/10 10:49pmPST - xda-developers
    Direct Link:
    4shared.com - online file sharing and storage - download KiNgxKxlick-AOSP2.1-v1.9_signed.zip
    PER CHI VOLESSE VEDERLA IN AZIONE la 1.6.1..ECCO IL VIDEO
    YouTube - Android kingxkxlick 2.1 1.6.1
    32A PORTING
    direttamente sul thread di xda
    Radio : qualunque
    SPL Required: qualunque
    Partizioni: Fat 32--EXT 1/2/3/4--Linux-Swap
    Wipe? : No wipe (se venite da 1.8)
    Per chi vuole la black bar delle notifiche vi riporto al thread su xda
    xda-developers - View Single Post - [REQ] Black Notification Bar for eclairOG rom
    Prima di installare il tema togliere tutti i widget della home..dopodicchè flashare il tema
    Ultima modifica di borjus86; 09-04-10 alle 23:04
    Galaxy S
    Cyanogen 7
  2. I seguenti 2 Utenti hanno ringraziato borjus86 per il post:
    Crocodile (31-03-10),iaio72 (17-02-10)
    Aug 2009
    Changelog
    Version 1.9
    - Fastest release to date
    - New base build
    - Now using king kernel #8!
    - Fully updated CFS
    - Using CFS
    - Cleaned up a2sd script
    - Cleaned up EXT partition (Some dummy files were staying on the partition)
    - Zipaligning fixed (should be quicker and more efficient now)
    - Fixing permissions on boot fixed
    - Live Wallpapers work just fine with performance kernel
    - More I will add
    Version 1.8.1
    - No wipe update
    - Added multiple kernel support
    - Added my kernel swapping scripts
    - Use the command performance kernel for Fast kernel with RAM hack
    - Use the command full3dkernel for 3d kernel
    - Both these commands will flash the desired kernel and reboot your phone
    - My performance kernel gives it a BIG speed boost
    Version 1.8
    - Full Wipe please (hopefully for the last time)
    - Fastest release yet
    - Updated kernel to king kernel #7 *thanks for the eclair source cy man*
    - Full 3D support *thanks firerat for some of your src code, would have taken much longer if it weren't for you!*
    - Removed BFS
    - Added CFS now
    - No RAM Hack, I will post a no wipe update for it
    - Added 3D Gallery *FULLY working*
    - ALL graphical glitches are gone
    - First eclair-based kernel I have done, still quite impressed though
    - Youtube has been reported as fixed, please let me know
    - Things I will add, in class now, and busy
    Version 1.7.1
    - No wipe update (Version 1.7 is the base version)
    - Removed 10Mb RAM Hack
    - Still using kernel #6, but with no RAM hack
    - Added 3D Gallery (still have regular gallery as well)
    - On 3D gallery, you can play with the display grid of your photos as expected
    - Added some support for 3D! *thanks _Case for some of your ideas*
    - Let me know which 3D games work/don't work
    Version 1.7
    - Fastest build yet!
    - All system apps on /system now!
    - Squeezed out more optimization!
    - A2sd still enabled for downloaded apps and applications on /data/app
    - Now using King Kernel #6!
    - Now using BFS 315
    - Changed default wallpaper
    - Fixed location for apps that were not functioning with it
    - Added working HTC_IME!
    - RAM hack still in there
    - Video Drivers coming soon, I promise
    - Things I will add I forgot for sure!
    Version 1.6.1
    - Full wipe before flash please (Sorry, has to be done)
    - Gapps updated and fixed
    - RIL tweaks
    - Speed tweaks
    - Sync fixed
    - Apps wont crash back to home screen
    Version 1.6
    - Now using King Kernel #5!
    - Numerous patches (a good few from cyanogen, thanks man)
    - Removed CPU hack as it does nothing
    - Fixed memory leak
    - Most changes are under the hood, not seen by end users
    - Multiple bug fixes
    - Removed a couple patches that caused instability
    - Now using linux-swap by default
    - Renamed kingswap.sh to kingcache.sh (it enables cc now)
    - Exchange mail should work properly, let me know
    - Added Launcher2! (let me know who did the final port of this please)
    - More miscellaneous bug fixes
    - Stuff I am forgetting I will add! who cares its FAST!
    Version 1.5
    - Rebuilt the build
    - Now using King Kernel #4!
    - CPU clockspeeds up to 780Mhz supported! (thanks for the src eugene)
    - Using BFS 313
    - VERY fast build!
    - Back to Stabletown we go!
    - JIT is disabled
    - Multi touch now supported in Maps
    - Facebook should sync with your contacts
    - Added smart dialer for Eclair (thanks Wysie!)
    - Removed Myspace
    - Added Overclock Widget (Fc's right now, uninstall then reinstall via Market)
    - Wifi fixed for first boot! (thanks for the help shafty)
    - Fifo=1 supported
    - Added Seesmic for all your twitter needs
    - Multiple things I cleaned up, not worth mentioning
    Version 1.4
    - MUCH faster
    - Now using King Kernel #2
    - BFS 313
    - 10Mb RAM hack for G1/MT3G users
    - Enhanced DalvikVM
    - Using the NEW JIT system *FAST experimental*
    - Multi touch in browser
    - Multi touch in gallery
    - Wifi fixed for first boot *thanks shafty*
    - Location for apps fixed
    - Using Compcache with SWAP_FREE_NOTIFY
    - Updated a2sd script *thanks shafty*
    - Cleaned up /bin
    - Cleaned up Ramdisk
    - I'll add things as I remember, BIG release
    Version 1.3
    - Fresh Compilation for a couple bug fixes etc
    - Live Wall Papers working *thanks a bunch Jubeh!*
    - Added some working Live Wall Papers
    - Added NEW Music Player from AOSP *thanks to whoever found the drawable fix for AOSP*
    - Many cleanups AGAIN to the build itself
    - More cleanups to the Ramdisk
    - Enable/Disable CompCache in Spare Parts supported
    - Vital scripts updated *thanks for the help shafty*
    - More optimization FAST
    - Using JAC's kernel now *Great Work bro, thank you*
    - Using JAC's CC modules
    - Removed 10MB RAM hack for now (I will do a no wipe update for the kernel I have been using)
    - Wired tethering included and functioning
    - Wireless tethering included and functioning
    - Removed some useless scripts in /bin
    - Wifi does not work on first boot, restart the phone and wi-fi will work
    - Added newer gmail
    - Added GenieWidget
    - Removed Twidroid
    Version 1.2
    - MUCH faster first boot and first boot
    - Many cleanups to bin and the build as a whole
    - Cleaned up ramdisk *thanks for the help shafty*
    - More stable, MUCH more responsive, quicker build overall
    - Optimized Frameworks
    - Updated necessary scripts *thanks shafty!*
    - Added Nemo Media
    - Updated user.conf for speed
    - SetupWizard fixed, can sign in to google the normal way *thanks shafty*
    - Added Nexus boot Animation!
    - Auto rotate should be fixed for sure for MT3G users
    - Renamed "kingcache.sh" to "kingswap.sh" (it turns on swap and disables cc, reboots the phone)
    - Things I need to add here I am forgetting
    Version 1.1
    - Many cleanups to the build itself
    - CompCache is fixed and enabled by default *thanks for the help shafty023*
    - Auto Rotate should be fixed for MT3G users (let me know please)
    - Network Location fixed and fully functioning!
    - Voice Search fixed
    - Added backups of some scripts in /bin for my scripts to function correctly
    - Added my scripts to bin
    - Added my script "kingcache.sh"
    - kingcache.sh will disable compcache, enable swap, and reboot your phone *thanks for adding logging and cleaning things up shafty023*
    - MUCH faster build due to cleanups and compcache running full steam ahead
    - More optimization to come, especially on the frameworks
    - It's late, I worked on this all day, I am forgetting things I fixed, cleaned up I will add tomorrow
    Version 1.0
    - First release from new 2.1 AOSP code
    - Live Wallpaper support!
    - Live Wallpaper selection available
    - Rooted with SU *Root FULLY working!*
    - Bluetooth is fully functioning!
    - Optimized using half of my method FAST (waiting for lycoln to return to do the finishing touches)
    - Voice to text keyboard included and working!
    - USING CTSO's CRAZY SUPER DUPER BOOT ANIMATION *THANKS MAN, DONT KNOW WHAT WE'D DO WITHOUT IT!*
    - A2SD is automatic! Just have that second Ext Partition
    - Pulled some files from CTSO's work
    - Linux-Swap enabled by default (working on compcache)
    - User.conf included and called on
    - Using Wes Garner's CFS Kernel *thanks bro*
    - Using the 10MB RAM Hack
    - Added my tools into bin
    - Added Myspace.apk
    - Added Facebook.apk
    - Added Terminal from AOSP
    - Added Spare Parts
    - Google Maps with Navigation included
    - Included Google Voice
    - Included Amazon.apk
    - Added Twidroid
    - Added Dev tools app
    Ultima modifica di borjus86; 09-04-10 alle 23:02
    Galaxy S
    Cyanogen 7
  5. #3
    May 2009
    Caserta
    Ringraziato 211 volte in 112 Posts
    Ciao,
    la sto provando praticamente da quando è uscita ed effettivamente è la più veloce tra quelle che ho provato, e le ho provate praticamente tutte.
    Sul magic 32b non funziona l'autorotate ma sembra sia solo a causa di un file utilizzato ad una vecchia versione.
    In compenso, a differenza di quasi tutte le altre 2.1, funziona la localizzazione tramite rete.
    Speriamo in futuri ulteriori sviluppi.
    Ciao
  6. #4
    Aug 2009
    si .. però è un bug risolvibile nelle prox versioni..per il resto la rom è stabile e per la prima volta vedo i miglioramenti della 2.1
    ma soprattutto...funziona il 3g
    Galaxy S
    Cyanogen 7
  7. #5
    Dec 2009
    Ringraziato 22 volte in 18 Posts
    porting per 32 a please
    3° Discepolo, SuperSuita a vita
  8. #6
    May 2009
    Veneto
    sapete se hai i driver 3d? (galleria del nexus che funziona per capirci)
    Phone: Samsung Galaxy Note (N7000)
    Rom: [I] Ultimate v5.1
    Recovery: Clockworkmod v6
  9. #7
    Aug 2009
    no la gallery ancora nn viene implementata...
    Galaxy S
    Cyanogen 7
  10. #8
    Androidiano L'avatar di capitano83
    Oct 2009
    Confermo che apparte la rotazione dello schermo per il resto è davvero una bomba!!!
    la 1.0 qualche problema me l'aveva dato, con i contatti e la localizzazione.
    Questa 1.1 sembra davvero ok in tutto e per tutto.
    2 cose solo volevo chiedervi:
    1. Gli MMS a voi vanno ??? a me nonostante ho messo APN italiani come applicazione non me li invia....mi restano in sospeso.
    2. se volessi cambiare tema (con il primo di questa lista per esempio) lo posso fare ??? se si come ???
    grazie a tutti in anticipo !!!
    HTC Magic White 32B Vodafone - SuperEclair_2.1-1 - Recovery Amon_RA v1.2.3G
  11. #9
    Senior Droid L'avatar di Dodopepper
    Oct 2009
    Ringraziato 26 volte in 19 Posts
    esiste un porting per 32a? come dura la batteria? Vorrei provare questa passando da Rav.
  12. #10
    Androidiano VIP L'avatar di paoloc67
    Jun 2009
    Noale (ve)
    Samsung S6 edge green
    Ringraziato 397 volte in 344 Posts
    È disponibile un aggiornamento che corregge il bug dell'autorotazione
    Un grazie se meritato non costa niente , premete il pulsante nell'angolo in basso a sinistra
Discussioni simili
  1. Risposte: 27
  2. ROM - KiNgxKxlick Espresso2G1 v0.1
    Da capitano83 nel forum HTC Magic
    Risposte: 7
  3. Risposte: 3
