Pagina 39 di 117 primaprima ... 2937383940414989 ... ultimoultimo
Visualizzazione dei risultati da 381 a 390 su 1163
[ROM] ViperOneM8 5.0.0 | Sense 7
  1. #381
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    Quote Originariamente inviato da zhunghuo Visualizza il messaggio
    carminuccio ... come ti trovi con undervolt a -50?? io per paura di blocchi la tenevo a -30
    Quote Originariamente inviato da carminuccio Visualizza il messaggio
    Questo cambia da telefono a telefono...devi provare fin dove puoi spingerti, io a -50 non ho problemi
    [GUIDE] Snapdragon 805/801/800/600 Clock &am… | HTC One (M8) | XDA Forums
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    ViperOneM8 3.0.0 (October 19th)
    • Re-based on 3.28.401.6
    • Merged with 3.28.401.7 (FIXES Vipnet Croatia Data issues)
    • Enhanced camera features
      - More options for preview time after taking a picture
      - Enabled Blink Detection
      - Enabled Crop Me In
      - Enabled front camera video scene
      - Disabled GeoTagByDefault
      - Added more resolutions for video recording
    • Removed weather item in tweaks not showing when weather is uninstalled
    • Fixed being able to remove all prism menu items
    • Fixed 5x6 app drawer grid size layouts
    • Fixed hiding app/folder labels on homescreen/appdrawer
    • Fixed All apps bar with full transparency
    • Prism will check system setting for rotation before prism tweak
    • Added wallpaper scrolling back
    • Added screen ON stats in power manager
    • Dock now locks also with workspace
    • Some minor fixes and optimizations in VenomTweaks
    • Updated Easter egg
    • Updated Google Play Services 6.1.74
    • Updated Google Play Store 5.0.32
    Ultima modifica di iLuke; 19-10-14 alle 17:28
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
  4. I seguenti 3 Utenti hanno ringraziato iLuke per il post:
    carminuccio (19-10-14),salvy931 (19-10-14),ubuntu (19-10-14)
  5. #383
    Jan 2011
    New rom is out! Enjoy!
    Download:
    LEGGERE PRIMA DI FLASHARE!!
    • NO OTA, solo FULL Rom!
    • Verizon e Sprint are NOT supportate.
    • T-mobile (con WIFI calling) e ATT sono supportate!
    • Bisogna avere obbligatoriamente l'ultimo firmware 3.28.401.6/7 oppure il WIFI non funzionerà.
    • Se l'intallazione si blocca e il cellulare resta fermo sulla scritta HTC, questo è normale. Il setup iniziale richiede molto tempo per avviarsi sulla nuova base..
    Maggiori dettagli QUI
    Ultima modifica di iLuke; 19-10-14 alle 19:04
  6. Il seguente Utente ha ringraziato iLuke per il post:
    ultimo125 (19-10-14)
  7. #384
    Apr 2010
    Ragazzi non trovo più hell'hub la mod per eliminare la linea sopra la navbar....
  8. #385
    Jan 2011
    Quote Originariamente inviato da anomalos Visualizza il messaggio
    probabilmente non è ancora pronta per la nuova rom, devi attendere
  9. Il seguente Utente ha ringraziato iLuke per il post:
    anomalos (21-10-14)
  10. #386
    Ringraziato 7 volte in 4 Posts
    hò finito l'aggiornamento del firmware ora è rimasto sulla scritta htc e barra di avanzamento sottostante ferma quindi è normale ad ora è passato circa 10 minuti
  11. #387
    alexis77
    Quote Originariamente inviato da mastersix Visualizza il messaggio
    Se non dai il comando
    fastboot reboot
    o
    fastboot reboot bootloader
    il telefono rimane fermo li
  12. #388
    Ringraziato 37 volte in 35 Posts
    Sapete qualcosa della 3.0.1 che novità ci sono grazie
  13. #389
    Naples
    Oneplus 11 16/256
    Quote Originariamente inviato da ubuntu Visualizza il messaggio
    ViperOneM8 3.0.1 (October 20th)
    • Fixed wallpaper issue same having when using none stock navbar height
    • Removed wallpaper scrolling again...for above fix
    • Included new ATT Message.apk to provide proper MMS size limits
    • Fixed MMS over Wifi for Tmous - thx for Jbb3393 for the hint
  14. I seguenti 2 Utenti hanno ringraziato sirioo per il post:
    iLuke (21-10-14),ubuntu (20-10-14)
  15. #390
    Puglia/Brindisi
    Attualmente un One Plus 3
    Se io ho la versione precedente e voglio aggiornarla a quella nuova mi basta flashare la rom 3.0.1? o c'è qualche passaggio in piu?? grazie
    Ultima modifica di ANTHONY91; 20-10-14 alle 16:41
