Pagina 4 di 117 primaprima ... 234561454104 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 1163
[ROM] ViperOneM8 5.0.0 | Sense 7
  1. #31
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    Quote Originariamente inviato da DHD Visualizza il messaggio
    OT
    Beh, sirioo, se regalassi ad entrambi un M8, renderesti le traduzioni moooolti più veloci
    Beh, mica è una cattiva idea
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
  2. Il seguente Utente ha ringraziato sirioo per il post:
    DHD (07-05-14)
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    ViperOneM8 1.6.0 (May 11)
    • Added
      • Added immersive mode (toggable via apm)
      • Added exlusion list for immersive mode
      • Added three finger tap customization
      • Added screen off action to 3 finger swype
      • Added Homescreen layouts
      • Added screen off prism menu item
      • Added wallpaper scrolling back
      • Added back wide crop size for wallpaper
      • Added skip unlock animation
      • Added slide out dock on homescreen
      • Added slide out statusbar on homescreen
      • Added slide out dock/statusbar timeout
      • Added option to remove contact picture mask
      • Added auto maximize lockscreen widget
      • Added option to set an own default widget on lockscreen
      • Added Quick Pin Unlock back
      • Added mod that keeps the screen off after hanging up a call when having a bluetooth headset connected
      • Added HtcWeatherClockWidget theming
    • Fixed
      • Fixed Motion gestures defaults
      • Fixed gap in prism when using 4x4 layout + venom navbar
      • Fixed extended app drawer grid (5x6)
      • Fixed red square icon for sprint users in settings
    • Updated
      • HTC social apps plugins
      • HTC Dot view
      • HTC Sense TV
      • All user apps
    Disponibile sia la full rom che l'OTA accessibile da Settings - About - Software Update
    Ultima modifica di iLuke; 12-05-14 alle 10:53
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
  5. I seguenti 3 Utenti hanno ringraziato iLuke per il post:
    Cosimo79 (12-05-14),sirioo (12-05-14),ultimo125 (12-05-14)
  6. #33
    Naples
    Oneplus 11 16/256
    Aggiornamento effettuato !!! Rom fantastica..!!!
    Ultima modifica di sirioo; 12-05-14 alle 09:58
  7. #34
    Apr 2014
    o installato questa bellissima rom pero mancano diversi widget. come si fa ad avere quelli della stock
  8. #35
    Androidiano VIP L'avatar di ultimo125
    Brindisi (Prov)
    new "HTC ONE M8"
    Ringraziato 1,479 volte in 1,230 Posts
    Quote Originariamente inviato da puffo56 Visualizza il messaggio
    Quale widgets mancano ?
    SE TI SONO STATO UTILE PUOI RICAMBIARE CON UN "THANKS"
    Twitter ---- Google+
  9. #36
    Apr 2014
    il primo e il meteo con orologio yutube preferiti ed altri che sono sulla stock. come mai la viperon e solo 1.4g contro le altre rom da 1.9g?
  10. #37
    Brindisi (Prov)
    new "HTC ONE M8"
    Forse perché, come hai fatto notare tu stesso, hanno eliminato alcune cose (es: i widgets) ...
  11. #38
    Apr 2014
    ok grazzie per la risposta in caso volessi instalarli e possibile. e come
  12. #39
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Quote Originariamente inviato da ultimo125 Visualizza il messaggio
    I widget di cui state parlando non sono stati rimossi.
    Riflashate la 1.6.0 senza rimuovere niente da aroma e li avrete.
  13. #40
    Brindisi (Prov)
    new "HTC ONE M8"
    Considerando che la viper ha la stessa base della ROM stock, è sufficiente estrapolare gli apk da un altro zip è copiarli nel telefono alla posizione system/ app ...
