Pagina 13 di 44 primaprima ... 3111213141523 ... ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 434
[ROM]LeeDrOiD One M8 L | International | 4.16.401.10 | WWE | ROTD | Tweaks
  1. #121
    Androidiano VIP L'avatar di tammazz
    Jan 2011
    Htc one m8
    Ringraziato 281 volte in 241 Posts
    Non essendo un problema specifico della rom discutiamone qui https://www.androidiani.com/forum/mo...tc-one-m8.html
    Os 6.12.401.4
    Rom Leedroid MM v8. 0.0 r33
    Kernel stock
    S-off
    [GUIDA] flash fw senza pc, cavetti, strane congiunzioni astrali xD
    ONE PLUS ONE
    Rom cm 13 jgcaap
  2. Il seguente Utente ha ringraziato tammazz per il post:
    Andreasworks (06-04-15)
    Senior Droid L'avatar di Egge11
    May 2014
    HTC One M8
    Ringraziato 144 volte in 124 Posts
    @tammazz esce sto update?
    HTC One M8 (Gunmetal Grey) 16GB
    | S-OFF | Recovery: TWRP 2.8.4.0| Kernel: STOCK | CID: HTC__304 | Root |
    Seguimi su:
    https://twitter.com/EugenioMedd
    https://instagram.com/loading1113/
    https://plus.google.com/113548054696179100839/posts
  5. #123
    Androidiano VIP L'avatar di nightcervant
    HTC ONE
    Ringraziato 638 volte in 485 Posts
    LeeDrOiD M8 S7 V7.1.0 - Stable - April 12th 2015
    Build tagged as Android 5.0.2 (Merged)
    Updated to the latest Prism & applied tweaks
    Updated HTC IME 0 lag!
    Updated LockScreen and fixed Fast Unlock glitch (Off by default unless previously enabled)
    All other built in system app's updated
    Enabled multi-user support
    Removed H/K aroma option (Please use the switcher by @sneakyghost )
    New LeeDrOiD boot animation
    Updated larger % green battery icon
    Fixed inverted tweaks toggle's (added to db on install)
    System clean-up's
    And a bunch of other misc tune-up's & tweaks
    DOWNLOAD
    MEGA
  6. #124
    Androidiano VIP L'avatar di Andreasworks
    Sep 2010
    HTC One M8 silver
    Ringraziato 323 volte in 281 Posts
    Impressioni da chi la mette ...grazie
    HTC ONE M8 ​​
    silver
    SIM :Vodafone
    UNLOCKED /S-OFF/CID 405
    HBOOT :3.19.0.0000
    RADIO :1.25.214500021.06G
    OpenDSP :v48.2.2-00564-M8974_F0.1211
    FIRMWARE :4.16.401.10
    RECOVERY :Twpr 2.8.7.0 M8
    Rom : Leedroid 7.4.3
    Kernel : Lonelyx
  7. #125
    Jan 2011
    Htc one m8
    Aggiornato #2 post v7.1.0,stasera la monto
    Os 6.12.401.4
    Kernel stock
    S-off
    ONE PLUS ONE
    Rom cm 13 jgcaap
  8. Il seguente Utente ha ringraziato tammazz per il post:
    Andreasworks (13-04-15)
  9. #126
    May 2014
    HTC One M8
    scarico e monto, ecco il link mega https://mega.co.nz/#!KEI2zCjD!naNF0w...BYsFxono_wGwMQ
    EDIT: consiglio di scaricarla da utorrent
    fleshata, come sempre grande fluidità, per me la migliore sotto questo punto di vista, ho provato a mettere l'Android revolution ma in pratica avviavo il telefono e mi diceva che vari processi avevo smesso di funzionare ( all'infinito ok dovevo premere ) non riesco a cambiare bootanimation nè il suono del boot, rimane quello stock htc anche dopo aver messo la spunta ( questo però mi succede con tutte le rom ) ho provato con boot animation dal play store ma niente, pazienza, per altro rimane la migliore dal mio punto di vista
    Ultima modifica di Egge11; 13-04-15 alle 17:21
    Seguimi su:
  10. #127
    Jan 2011
    Htc one m8
    Si, l'ho scaricata da un'oretta, ed ha colpito subito per la fluidità (non so come faccia ma fa sempre meglio ad ogni release..) indubbiamente un esempio di solidità e funzionalità e assenza di bug in tutto il reparto sense 7.. Difficile da lasciare xD comunque io con mega in un'oretta lo scarico, è quello che ho sempre trovato più veloce, uso l'app mega v2 del play store..
    Os 6.12.401.4
    Kernel stock
    S-off
    ONE PLUS ONE
    Rom cm 13 jgcaap
  11. #128
    Ringraziato 37 volte in 35 Posts
    ottima come sempre la leedroid non delude mai l'unica cosa lo sblocco rapido con doppio tap non va ho risolto installando il kernel elementalx e settandolo dall'app
  12. #129
    Baby Droid L'avatar di Cosimo79
    Svizzera
    HTC one m8
    Fleshata 10 minuti fa..... Tutto ok e va alla grande! Grande Leedroid!!!
    @ubuntu da me il doppio tab funziona con kernel stock.
  13. #130
    Quote Originariamente inviato da Cosimo79 Visualizza il messaggio
    si hai ragione mi sono dimenticato di scrivere che uso xtended un po di personalizzazione mi piace
