Utente del mese: bluemask con ben 31 Thanks ricevuti nell'ultimo mese
Pagina 1 di 29 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 288
LeeDrOiD MM V8
    Androidiano VIP L'avatar di tammazz
    Jan 2011
    Htc one m8
    Ringraziato 281 volte in 241 Posts
    LeeDrOiD MM V8
    My stuff, has been kicking around longer than your stuff... be it hacks, mods, tweaks or ideas.... hehe .... I don't complain that it's spread wider than a porn stars legs.... we are all open source developers with the ability to share and get along, it's common courtesy to ask and give a thanks!
    Some of you know me, some of you don't...
    My Name: Lee Bailey (AKA LeeDrOiD)
    My Hobby: Android Rom & Kernel Development
    [HIDE]So I decided to make a comeback thanks to @the Great Dane, if you aren't familiar with the name, work or the history of LeeDrOiD, do a quick Google search..... Many of the mods used across XDA originated with LeeDrOiD Rom's, from the likes of the Advanced Power Menu by the awesome @snq- & Long press key hacks - I have made some truly awesome friends, had some fantastic experiences along the way & I am really excited too be back! [/HIDE]
    @A5J4DX l @snq- l @scar45 | @baadnewz | @Damo | @TEAm RC | @m-deejay |@ klquicksall | @rmk40 | @SteelH | [COLOR="DarkGreen" @the Great Dane (The reason I returned!)[/COLOR] | @j4n87 | @Daniels7 | @Pg101 | @Irvysan | @Scabes24 | @showP-1984 |@broncogr | @lyapota | @mwilky | @patensas | @SvaDev @captain_Throwback
    LeeDrOiD Accepts no responsibility for:
    Any damage to your device
    Any loss of data
    Lack or loss of sleep - Due to but not solely caused by ROM flashing addictions
    The end of the world
    Or your granny's Alzheimer's (It's a disease, it had nothing to do with me)
    All of my builds are tested personally & by a number of close friends, I only develop for devices I own & use
    • [HIDE]
      ROM FEATURES TO BE UPDATED FOR MM SVN RELEASE
    • ROM - Based On: HTC Europe 6.12.401.4 Official base
    • Android 6.0
    • HTC Sense 7
    • Rooted with the latest SuperSU thanks to @Chainfire
    • De-odexed
    • Zip-aligned
    • init.d support
    • Disable error reporting
    • Cleaned up bloat
    • BusyBox installed
    • SQlite3 support
    • Bash and Nano shell support
    • External SD write permissions
    • Removed lots of HTC logging junk
    • Package Signature Checking Disabled
    • Clear cache at boot time
    • Lots of configuration changes and speed enhancements
    • Improved battery vs. Stock builds
    • Created and added Android Logo font pack (Selectable in settings)
    • Enabled blinking LED whilst charging
    • Enabled flashlight shortcut in power menu
    • Enabled auto selfie feature
    • Enabled voice activated capture
    • Multi user support
    • Advanced Power Menu
      Reboot, Download, Recovery, Bootloader & Safe Mode
    • China Sense recent apps with RAM display and kill all button
    • Home shortcut menu (enable and hit menu in Prism)
    • Improved battery stats
    • SystemUI Tuner - long press settings icon in pull down to enable
      ---Aroma---
    • Aroma - Optional exchange mail admin hack
    • Aroma - Optional stock boot animation and audio
    • Aroma - Remove HTC App's
    • Aroma - Remove HTC Widget's
    • Aroma - Remove Google & misc apps
    • Aroma - Centre status-bar clock
    • Aroma - Big Caller Photo
    • Aroma - Nav Bar height 50%/75%
    • Aroma- Hide Battery / Stick Battery / % Battery
    • LeeDrOiD Tweaks!
    • Tweaks - Sweep nav bar to sleep
    • Tweaks - Enable large Blinkfeed pictures
    • Tweaks - Prism landscape
    • Tweaks - Infinite apps in folders
    • Tweaks - China Sense
    • Tweaks - Quick settings brightness slider
    • Tweaks - Quick settings quick pulldown from top right corner
    • Tweaks - Traffic indicator
    • Tweaks - Traffic Indicator colour wheel selection
    • Tweaks - Display 4G for LTE*
    • Tweaks - Modify recent app button behaviour (press & long press)
    • Tweaks - Long press back
    • Tweaks - Double tap status bar to sleep
    • Tweaks - Long press power for flashlight when screen off
    • Tweaks - Toggle boot audio
    • Tweaks - Set default app installation location
    • Tweaks - Allow dynamic Navigation Bar colour's (Material design app's only)
    • Tweaks - Volume key cursor control
    • Tweaks - Toggle fast dormancy
    • Tweaks - Fix Permissions*
    • Tweaks - Zipalign apk's*
    • Tweaks - mount system RO/RW*
    • Tweaks - Wipe battery stats
    • Tweaks - Wipe Cache
    • Tweaks - Wipe Dalvik Cache
    • LeeDrOiD custom build trickery
    • LeeDrOiD Boot animation, audio & wallpapers
    • System clean-up's
    • And lots more........
    • Custom LeeDrOiD Locales & Language support
    • Supported Languages: English, Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Korean, Greek, Turkish, Swedish, Danish, Portuguese, Finnish, Thai, Korean, Vietnamese, Chinese, Japanese, Portuguese, Croatian & More
    • Too much to list
    [/HIDE]
    Known Issues
    • None - you tell me!
    Moved to SVN - Live change log available at LeeDrOiD.co.uk
    Please make sure you have the latest HTC Hima firmware installed prior to installing this ROM
    The current ROM base is 6.12.401.4...
    A full wipe is not always necessary, although always recommended to avoid issues.
    First boot will take approximately 10 minutes due to Art optimization
    (If your device gets warm during ART optimization, don't panic, the M8's super sleek alloy body is like 1 big heatsink)
    A quick whistle stop tour of flashing a custom build
    1. Unlock your device boot loader via > HTC Dev
    2. Flash the latest TWRP recovery image
    3. Insure you have the correct firmware version
    4. Nandroid backup your entire stock system or previous build
    5. Reboot your device and copy the LeeDrOiD rom. zip to your internal memory
    6. Reboot to recovery (Power off > Hold Vol down & power > reboot to bootloader > reboot to recovery
    7. Select the install option and locate the LeeDrOiD rom zip on your sdcard
    8. Follow the Aroma installer & be patient
    Hosting thanks to the awesome @Leefear & @soldier9312
    Full ROM Nightly Download's can be found here at www.LeeDrOiD.co.uk
    The automated build script runs at approximately 22:30 GMT daily
    Alternatively you can clone my SVN & zip up your own build
    svn checkout leedroid-m8 - Revision 27: /trunk
    Enjoy & welcome to the world of LeeDrOiD
    XDA:DevDB Information
    LeeDrOiD One M8, ROM for the HTC One (M8)
    Contributors
    LeeDroid, mwilky
    ROM OS Version: 6.0.x Marshmallow
    ROM Kernel: Linux 3.4.x
    ROM Firmware Required: 6.12.401.4
    Based On: Sense 7
    Version Information
    Status: Stable
    Current Stable Version: 7.4.2
    Stable Release Date: 2015-06-02
    Current Beta Version: 8.0.0
    Beta Release Date: 2016-02-06
    Created 2015-02-01
    Last Updated 2016-02-07
    TUTTI I CREDITI A LEEDROID ED AL SUO STAFF
    DONATE TO LEEDROID
    Ultima modifica di tammazz; 09-02-16 alle 10:33
    Os 6.12.401.4
    Rom Leedroid MM v8. 0.0 r33
    Kernel stock
    S-off
    [GUIDA] flash fw senza pc, cavetti, strane congiunzioni astrali xD
    ONE PLUS ONE
    Rom cm 13 jgcaap
    Jan 2011
    Htc one m8
    Link al thrade originale su xda, sarebbe gradito che chiunque mastichi un po di inglese postasse di eventuali bug anche sul thrade originale di xda (così mi è stato chiesto di dirvi), grazie
    http://forum.xda-developers.com/htc-...1-0-5-t3019102
    Ultima modifica di tammazz; 09-02-16 alle 19:42
    Os 6.12.401.4
    Kernel stock
    S-off
    ONE PLUS ONE
    Rom cm 13 jgcaap
    Jan 2011
    Htc one m8
    LeeDrOiD r67
    R67LeeDroid:-V8.1.2
    Update LeeDroid Tweaks v7.7.0
    Add Clock am/pm options-Large,Small or Hide-Thanks @baadnewz
    Fixed Ambient Display
    Fixed SystemUI force close with Textra, Whatsapp etc.-caused by heads up missing resource
    LeeDrOiD-m8-r67
    R68 - LeeDrOiD V8.1.3
    Configuration updates for Doze / Ambient display
    Additional Doze / Ambient display modes
    Re-added adaway (optional in aroma)
    Rolled back world clock to stock (possible alarms fix)
    Big tweaks re-work!
    * New Seek dialogs
    * Any Nav Bar size selection
    * Fully customizable ambient display
    * Updated layout
    * Code clean-ups
    Leedroid R68 + Clumsy Kernel 2.1.1
    LeeDrOiD-m8-r68
    R72 - LeeDrOiD V8.1.7
    Added 5x6 app drawer layout option
    Fixed Landscape oprentation layout
    Thanks @OMJ!
    R71 - LeeDrOiD V8.1.6
    Sense 8 app's added & default:
    HTC Sense 8 Home
    HTC Sense 8 Messages
    HTC Sense 8 Lock Screen
    HTC Sense 8 Mail & Optional Exchange Hack
    HTC Sense 8 Contacts Dialer
    HTC Sense 8 Power Manager
    HTC Sense 8 Settings
    HTC Sense 8 Clock Widget
    HTC Sense 8 Wallpapers
    HTC Sense 8 Boost+ (Memory management and optimization)
    Aroma - Sense 8 Camera
    Aroma - Sense 8 Keyboard (TouchPal HTC Version)
    Added HyperLapse & Slow Motion in Sense 8 camera app
    Tweaks V8.0.2 - Fix FC when no data connection is present
    Updated LeeDrOiD Boot Anim (Blinking red eye)
    Added HTC 10 Down Animation
    Leedroid 8.1.4 R69 stable + Clumsy Kernel 2.1.1
    LeeDrOiD-m8-r72
    [B]LeeDrOiD-m8-r75
    Ultima modifica di tammazz; 18-04-16 alle 22:55
    Os 6.12.401.4
    Kernel stock
    S-off
    ONE PLUS ONE
    Rom cm 13 jgcaap
    Jan 2011
    Htc one m8
    La rom e ancora una nightly, non ho ancora avuto il tempo di flaharla
    Os 6.12.401.4
    Kernel stock
    S-off
    ONE PLUS ONE
    Rom cm 13 jgcaap
  6. Il seguente Utente ha ringraziato tammazz per il post:
    Andreasworks (09-02-16)
  7. #5
    MartaHTC
    Salve a tutti oggi pomeriggio stavo pensando di flasharla....qualcuno la usa gia??è buona per l'uso quotidiano??La vecchia lee la misi quando gia era versione stable queste nightly come si comportano di solito?
  8. #6
    Androidiano VIP L'avatar di Andreasworks
    Sep 2010
    HTC One M8 silver
    Ringraziato 323 volte in 281 Posts
    Quote Originariamente inviato da MartaHTC Visualizza il messaggio
    ...no io non l ho ancora messa e per ora qui non ho ancora sentito nessuno che l ha messa ...
    Prova tu ?
    Ora siamo alla svn 27
    HTC ONE M8
    silver
    SIM :Vodafone
    UNLOCKED /S-OFF/CID 405
    HBOOT :3.19.0.0000
    RADIO :1.25.214500021.06G
    OpenDSP :v48.2.2-00564-M8974_F0.1211
    FIRMWARE :4.16.401.10
    RECOVERY :Twpr 2.8.7.0 M8
    Rom : Leedroid 7.4.3
    Kernel : Lonelyx
  9. #7
    MartaHTC
    Oggi ho il pomeriggio libero e penso che mi ci metterò di buon intento....diciamo che sarò io la tester....
  10. #8
    Sep 2010
    HTC One M8 silver
    Bene ..brava aggiornaci .
    Anche se poi alla fine pare che anche contro twrp 3.0.0 funzioni ...magari fai il tutto con la 2.8.7.0 che alla fine è meglio .
    HTC ONE M8
    silver
    SIM :Vodafone
    HBOOT :3.19.0.0000
    Kernel : Lonelyx
  11. #9
    MartaHTC
    Quote Originariamente inviato da Andreasworks Visualizza il messaggio
    Messa in download l'utlima nightly....tra poco comincio con lo sblocco del bootloader backup rom stock e si comincia.....comunque penso che farò tutto con la 2.8.7.0 per stare tranquilli poi più avanti se non darà problemi aggiornerò la recovery...
  12. Il seguente Utente ha ringraziato MartaHTC per il post:
  13. #10
    MartaHTC
    Flash andato a buon fine....sto installando tutte le app...è ancora presto per le prime impressioni...m
