Utente del giorno: hobin con ben 2 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 13 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 126
[ROM] ViperOneM9 6.1.0 • 4.28.401.3 | Tweaks | HUB | Sidebar | Theming | OTA
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Ultima modifica di sirioo; 16-03-17 alle 10:55
  2. Il seguente Utente ha ringraziato iGuich per il post:
    kaos80 (13-04-15)
    Cattolica
    All downloads now on:
    ViperOneM9 6.1.0 (14th April)
    The rom is based on the new HTC's base! The full wipe is recommended!
    Additions & Updates
    • Rebased to 4.28.401.3
    • Updated to Magisk 12.0
    • Updated to MagiskManager to 4.3.1
    • Reorganized and cleaned up VenomTweaks
      • Reduced the settings per tab to make it clearer
      • Introduced more subsections for those instead
      • Extracted some settings to own tabs
      • Moved some settings to the right place
    • Double Tap anywhere on homescreen to turn off the screen
    • Swipe Down anywhere on homescreen to expand the statusbar
    • Datausage info line (longpress opens data usage settings)
    • Option to choose the desired networkmodes you want to toggle with the neqs networkmode tile
    • Option to choose to toggle to LTE Only instead of LTE Auto for the HEQS LTE Quicksetting
    • Custom colored notifications can expand child notifications now
    • Change the background, text and icon color of all info lines at once
    • Improved disable vibration systemwide - vibratepattern was not handled
    • Option for Signal Icons on left
    • Option for Battery on left
    • Option to remove app drawer, places all your apps on your homescreen instead
    • Change switches track and thumb color system wide
    • Settings icons take color of the one you select for the checked thumb switch state.
    • Custom calender shortcut now also working for the header
    • Option to hide the date in the header
    • Added additional html time formats in VenomTweaks, includes now three new ones with date included
    • Swipe Up on homescreen to open appdrawer
    • Random Animation and Interpolation type
    • Whitelist for random Animation and Interpolation types
    • Custom shortcut for appdrawer (previous option was just for custom applications)
    • Option to hide lock icon on lockscreen
    • Option to set a custom image for your lock icon
    • Made signal strength tweaks visible again, adds option to show signal strength with either dbm or asu level
    • Three finger gesture will show a short toast now for toggable modes
    • Updated HTC Lockscreen with current playstore version
    • Updated HTC Sense Home with current playstore version
    • Made switch track color visible when preference is disabled
    • All incompatible preferences are disabled when AOSP lockscreen is selected
    • Option to swap volume keys when in 90° landscape orientation
    • Custom ListView animations
      • 13 different animations
      • 9 different interpolations
      • blacklist option
      • customize duration
    • Opening apps in VenomSidebar, Quicklaunch, HEQS and NEQS will bring the app to the top now, instead opening a new instance
    • Readded Overlay warning dialog when granting permissions - Google removed that for some reason
    • Added "Ignore" Button to the overlay warning dialog
    • Added option to hide header footer text (Like on active VPN connection "Device may be monitored")
      • You find the option in VenomTweaks->Statusbar->Customize->Header with clock
    • Custom Appdrawer Background color with transpareny support
    • Set dimming level of lockscreen
    • Set dimming level of secure lockscreen (pin/pattern)
    • Last app action brings app to the top instead of starting a new instance
    • Longpressing sync tiles in neqs opens sync settings now - very hacky implementation, sry google for messing up your code.
    • Several UI enhancements in VenomTweaks
      • Nougat seekbars
      • Nougat toggles
      • Fixed title font size of seekbar preferences
      • Material like revert buttons
      • Changed ColorPicker Dialog layout, so the keyboard does not interfere
    • Added "Sync All" QS Tile (Syncs all accounts in Settings->Sync & Accounts)
    • Added QS Tile to toggle AutoSync
    • Increased column count to 5 in the QS Customizing Panel
    • Added option to disable child notifications
    • Sense Home custom open app animations
      • Bounce
      • Fade
      • Push Down
      • Push Left
      • Push Right
      • Push Up
      • Rotate
    • Added screenshot and partial screenshot action to three finger gestures
    • Added partial screenshot as button mapping action
    Fixes & Cleanups
    • Fixed headsup timeout
    • Fixed clock color resetting temporarily when expanding and collapsing the statusbar
    • Fixed Last app still starting a new instance, instead of bringing an already open app to foreground
    • Fixed lockscreen opacity value not sticking in VenomTweaks
    • Fixed FakeIMEI not working
    • Fixed three finger tab vibration not happening
    • Fixed custom weather shortcut for weather widget in notification pulldown
    • Fix Google Now mappings not working on stock navbar
    • Fixed Ambient Notifications Whitelist not being accessible in VenomTweaks (No one reported it, so it seems no one is using that feature, wasted days on it to get that working, LOL)
    • Fixed Sprint bootanimation (Fullrom only)
    • Revert to official Sense Home
    • Fix three finger gesture "Go to previous app" action
    • Fixed three finger gestures: Moved implemenation to native framework. Works instantly after boot now and does not require selinux to be permissive.
    • Fixed custom overscroll color not working
    • Fixed cropping images with google photos in VenomTweaks not taking right aspect ratio
    • Fixed decrease neqs panel causing empty panel after reboot
    • Fixed Notification Screen On Setting not working
    • Fixed wrong description in color settings
    • Fixed custom weather, clock, calender shortcuts not working
    • Fixed folder transpareny default values
    • Fixed Sense Home force closing when resetting to default settings in VenomTweaks
    • Fixed perms of bootsound..didn't work before when enabled in VenomTweaks
    • Fixed custom autobrightness not working at all
    • Fixed notifications with child notifications not expanding
    Ultima modifica di sirioo; 18-05-17 alle 14:09
  5. Il seguente Utente ha ringraziato iGuich per il post:
    s22 (14-04-20)
  6. #3
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    Appena installata la 1.2.0 ...rispetto alla viper del m8 pensavo meno matura..invece mi sono ricreduto..!!!
    Ultima modifica di sirioo; 24-04-15 alle 00:58
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
  7. #4
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    Aggiornata alla 1.3.0
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
    Naples
    Oneplus 11 16/256
    Quote Originariamente inviato da iLuke Visualizza il messaggio
    fake ..!!!!
  9. #6
    Jan 2011
    ViperOneM9 1.4.0 (03 May)
    Updates & Additions
    • Major battery life and overheating improvements
    • Added real per app navbar color
    • Added coloring Navbar for all apps
    • Added per app statusbar color
    • Added coloring statusbar for all apps
    • Added navbar color matching theme
    • Added hiding lockscreen widget
    • Added Hiding Sunset on Lockscreen
    • Added Showing Alarm on Lockscreen
    • Added different Emergency Call behaviors (Shortpress/Longpress/Hide)
    • Added Hiding Sprint GPS Testicle Icon
    • Added headsups blacklist allow all toggle
    • Added Custom Lockscreen Weather Location (No need to have location in settings enabled)
    • Added Custom Blinkfeed Weather Location (No need to have location in settings enabled)
    • Added Motion Launch custom actions
    • Added ambient notifcations
    Fixes:
    • Fixed distorted VZW Advanced Calling Icon
    • Fixed motion launch gestures breaking when restarting statusbar in VenomTweaks
    • Fixed wrong behavior of headsup notification
    • Fixed notification count showing by default
    • Fixed weak haptic feedback on recent apps button
    • Fixed haptic feedback not working at all on 4th navbar button
    • Fixed small apps (floating apps)
    1.4.0 is available via OTA. Grab it by going to Settings->About->Software Update.
    The OTA is offered to be installable from 1.3.0 and 1.3.5 on!
    Fullroms as usual downloadable on:
    (You might need to ctrl+f5 to clear the cache to see the new links)
    For people having issues with the links not showing:
    Incremantal OTA:
    ViperOneM9 1.3.0/1.3.5-1.4.0
    Fullroms:
    Main: AFH
    Mirror 1: US Sense Host
    Mirror 2: NL/EU
    Mirror 3: NL/EU
  10. Il seguente Utente ha ringraziato iLuke per il post:
    kaos80 (12-05-15)
  11. #7
    HTC DESIRE/ONEX/M7/8/9/10
    Ringraziato 448 volte in 266 Posts
    ViperOneM9 1.5.0 (09 May)
    Additions & Updates
    • Added headsups whitelist ignore score
    • Added fully customizable statusbar header view
    • Added CPU control for 4-7 cores
    • Added statusbar weather widget
    • Added Infoline multiline suppport
    • Added double press recent
    • Added Emulating Back key action to map to any key
    • Added Force Hiding Menu Key (no need for menu button when you got an action mapped to navbar button to trigger menu action)
    • Added option to hide googles searchpanel on longpress home button
    • Added AutostartManager
    • Added disabling google searchpanel when longpressing home
    • Added repositioning of appdrawer icon
    • Refactoring of header, quicksettings, quicklaunch visibility and behavior
    • Refactoring of Venom Button Management
    • Unlimited tether for TMOUS Added (Full ROM only)
    • Updated Russian translation(SystemUI, Tweaks, Framework)
    • Updated and ported Lockscreen and Sense Home to latest
    • Updated all /system and /data apps (Full ROM only)
    Fixes:
    • Fixed statubar header buttons position
    • Fixed statubar header height calculation
    • Fixed statubar quick launcher
    • Fixed QS flashlight icon in rearrange list
    • Fixed HTC bug where core 4-7 not disabling after reboot when having powersaver enabled
    • Fixed Haptic Feedback for buttons
    • Fixed Menu Button staying on homescreen or other apps, although they shouldnt appear there.
    • Fixed app drawer icon alignment on custom icon themes
    • Fixed fake IMEI tweak for TMOUS
    • Fixed keyboards and widgets remove restore (Full ROM only)
    • Fixed preload partition removal (Full ROM only)
    Some previews:
    Weather widget big/small:
    Multi Infolines, fully customizable:
    Positioning of Appdrawer Button:
    Extended CPU Control & Autostart Manager
  12. I seguenti 2 Utenti hanno ringraziato carminuccio per il post:
    iLuke (09-05-15),kaos80 (12-05-15)
  13. #8
    Jan 2011
    ViperOneM9 1.6.0 (10 May)
    Additions
    • Added color control support - Change RGB, saturation, contrast and more to get your desired display color
    You can access that settings in VenomTweaks->Misc->Advanced Display Control
    video demonstration:
    Credits to savoca for the initial mod. You can find his thread here.
    Credits to flar2 for making an easy module to use it. Use his app to thank and support him.
    His app additionally supports creating different color settings profiles, that you can change on the fly.
    1.6.0 is available via OTA. Grab it by going to Settings->About->Software Update.
    Fullroms will be available tonight on:
    Incremantal OTA:
    ViperOneM9 1.5.0-1.6.0
  14. Il seguente Utente ha ringraziato iLuke per il post:
    kaos80 (12-05-15)
  15. #9
    Jan 2011
    Ringraziato 4 volte in 2 Posts
    ciao a tutti,
    non mi funzionano i comandi vocali,li ho installati dal play store ma quando vado a fare una chiamata si impalla e non si attivano.sapete dirmi che vuol dire l'icona di una stella nella status bar? quali sono i Must della Viper, chi la conosce bene cosa consiglia?
  16. #10
    Senior Droid L'avatar di kaos80
    Ringraziato 65 volte in 51 Posts
    Sono tornato indietro di 2 anni ma nulla è cambiato!ViperOne è una garanzia.Super personalizzabile e veloce con una batteria in formato extra.
