Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 38
[ROM][4.2.2][HBOOT 2.16] MIUI v5 - Multi Language support | r4.5.23
    alexis77
    MIUI è una distribuzione personalizzata di Android 4.2.2 Jelly Bean, che offre una semplice interfaccia utente con alti livelli di personalizzazione, questa ROM e' su base Sense 4.06.401.1
    1. Download ROM e Google e copiare tutto nella SD
    2. Riavviare il telefono in recovery (TWRP, CWM)
    3. Wipe Data, Cache and Dalvik Cache
    4. Flash the ROM
    5. Flash Gapps
    ROM Download
    [SIZE="3"][B][LEFT]Main: xiaomi.eu_multi_ville_4.5.23_jb-4.2.zip
    Google Apps: gapps-jb-20130812-signed.zip
    XDA:DevDB Information
    MIUI v5, ROM for the HTC One S
    Contributors
    dd98, LlabTooFeR, MIUI ROM Developers
    ROM OS Version: 4.2.x Jelly Bean
    ROM Kernel: Linux 3.4.x
    ROM Firmware Required: Leaked Firmware (HBOOT 2.16)
    Version Information
    Status: Stable
    Current Stable Version: 4.5.16
    Stable Release Date: 2014-05-16
    Created 2014-05-18
    Last Updated 2014-05-18
    Thanks to dd98 on XDA
    Original Thread fo dd98 on XDA
    Ultima modifica di alexis77; 25-05-14 alle 14:08
  2. I seguenti 6 Utenti hanno ringraziato alexis77 per il post:
    camelot79 (19-05-14),iLuke (19-05-14),Maco92 (30-05-14),maestropaolino (19-05-14),salvo_94 (19-05-14),ultimo125 (19-05-14)
    alexis77
    changelog
    ora rom multilanguage
    25-05-2014
    switched from official miui.com to unofficial miuiandroid.com
    multi language support
    24-05-2014
    4.5.23
    [messaging]
    optimization - support recognizing time information in a message and adding it to calendar (5-21)
    [lockscreen, status bar, notification shade]
    optimization - the two arrows of the data toggle always show when connecting data (redmi 1s wcdma/cdma, mi3 wcdma/cdma) (5-20)fix - sometimes, the no sim card icon would not disapper (5-21)
    [camera]
    fix- sometimes camera lost focus when flashlight was turned on (mi3 wcdma/cdma) (5-22)
    [music]
    optimization - popup menu of online music list (5-20)
    fix - some bluetooth earphones wouldn't show music information on it's screen (mi3 wcdma/cdma) (5-20)
    [weather]
    new - added two weather types: Freezing rain and hail (5-20)
    [settings]
    fix - incoming calls from people in the exceptions list of dnd did not ring (5-20)
    [system]
    fix - sometimes could not register xiaomi account using the current phone number (mi1/1s) (5-22) fix - could not use vpn (mi3 wcdma/cdma) (5-22)
    [calendar]
    fix - sometimes app would fc in opening (5-20)
    [blocklist]
    fix - dnd exceptions list and blocklist exceptions list caused conflict (5-20)
    [clock/calculator]
    fix - sometimes alarm clock delayed in ringing (5-21)
    [mi cloud]
    fix - after choosing do not merge in the popup window of merging mi cloud data, it did not direct to the next step (5-20)
  5. #3
    Androidiano L'avatar di camelot79
    Taranto
    HTC One S
    Rom davvero interessante, aspetto di avere ulteriori informazioni...Thanks Kalel
    Inviato dal mio HTC One S usando Androidiani App
  6. #4
    Senior Droid L'avatar di gerikoo
    Apr 2011
    Ringraziato 60 volte in 52 Posts
    provata ieri, non male, peccato che non ha la lingua italiana, ritornato alla viper, mi mancava la sense.
  7. #5
    alexis77
    Quote Originariamente inviato da gerikoo Visualizza il messaggio
    C'è lo zip al primo post per la lingua italiana
  8. #6
    Apr 2011
    Quote Originariamente inviato da kalel77 Visualizza il messaggio
    ormai l'ho limata, cmq grazie.
    Edit: lo zip x la lingua non funziona o meglio si installa ma non fa partire più la rom.
    Ultima modifica di gerikoo; 19-05-14 alle 21:25
  9. #7
    alexis77
    Lo zip per la traduzione non e' quello giusto, sto aspettando mi diano risposta su XDA, se flashate quello il telefono non si avvia
  10. #8
    Ringraziato 16 volte in 5 Posts
    quello in download non va quindi? sarebbe meglio toglierlo allora perchè io per fortuna ho appena scaricato ma non flashato XD
  11. #9
    alexis77
    Quote Originariamente inviato da inter2010 Visualizza il messaggio
    Stavo per aggiornare, testato ora e flashando quello non si avvia, rimane sul logo.
    Attendiamo
  12. #10
    Senior Droid L'avatar di blackmonger
    Ringraziato 50 volte in 44 Posts
    sono curioso di provarla questa miui, ne sono sempre stato lontano per via dell'interfaccia troppo stile iOS, dopo aver visto però alcune prove dello xiaomi mi3 mi è venuta voglia di testarla, qualcuno sa dirmi se la qualità degli scatti è allo stesso livello di quelli fatti con una rom sense?
