[ROM] HTC One X - CyanogenMod 10 Preview 6 (July/22) - 4.1.1
Finalmente ci siamo! spuntano le prime rom Jelly Bean funzionanti quasi al 100%!
Le funzioni fondamentali non hanno problemi ( fotocamera, videocamera, wifi, rete, BT ecc ecc.) resta ancora qualche piccolo bug, ma la rom e' davvero una scheggia! fluidissima, veloce ( DANNATAMENTE VELOCE!) e stabile!
Se volete un assaggio di Jelly Bean provatela! Ovviamente essendo una cyanogenmod, scordatevi la sense, ma vi assicuro che non le manca nulla! Se installate poi APEX o Nova launcher l'esperienza e' ottima! ( Stanno ancora facendo il merge dei sorgenti, quindi non e' presente la personalizzazione del launcher, sono presenti pero' le personalizzazioni per la statusbar e la lockscreen) ;););)
Bugs:
- - WiFi direct doesnt work
- - Wifi tether
- - In call volume adjustment works, but not fully well in Speaker mode (more info here)
- - MHL output is rotated incorrectly to portrait in horizontal mode (but workaround added since alpha 8 for hw decoded videos/youtube. Use bsplayer from playstore, almost all videos play with it in correct rotation in hwoverlay)
- - No FM radio app in ROM. But Spirit FM works from market (it's commercial!)
Changelog:
codice:
preview 10:
- Latest CM changes (synced 29.07.2012)
- Updated kernel
- Fully fixed echo and call volume (by pabx)
- Other small fixes, tweaks and cleanups
preview 9:
- Latest CM changes (synced 28.07.2012)
- New stable kernel (based on latest htc source)
- Added Center clock options
- Added Hardware key custom rebinding (Settings -> System)
- Added noise suppression for phone calls options (Dialer -> Settings)
preview 8:
- Latest CM changes (synced 27.07.2012)
- Fixed low freqs (51, 102, 204MHz)
- Fixed buttons backlights (lags)
- Fixed music lags (stuttering)
preview 7:
- Latest CM changes (synced 26.07.2012)
- Echo fixed (by pab)
- Theme Manager
- Stk fixed (again)
preview 6:
- Latest CM changes (synced 25.07.2012)
- Wi-Fi Hotspot fixed
- Vibration settings fixed
preview 5:
- Latest CM changes (synced 24.07.2012)
- Android 4.1.1_r3 JRO03H
preview 4:
- Latest CM changes (synced 23.07.2012)
- Tweaked power HAL (475mhz max screen off freq / 306mhz min screen on freq)
- Various kernel tweaks / dirty hacks
- Fixed Stk app issues
- Fixed HOLO gradients
- Fixed battery charging LED
- More...
preview 3:
- Latest CM changes (synced 22.07.2012)
- Updated kernel with changes from show-p1984
- Removed HTC crap from kernel
- Added endeavoru power HAL
- Fixed touchscreen in games
- Improved gradients
- Other minor cleanups and fixes
preview 2:
- Latest CM changes (synced 21.07.2012)
- Disabled face detect
- Fixed mobile network search
- Fixed APN edit
preview 1:
- Initial release
Screenshots:
