[ROM]eXoSeNSe[Sense6.0][KitKat4.4.2][STABLE/SPEEDY/LIGHT]
    Androidiano L'avatar di electrostatus
    Casa mia
    HTC One
    Ringraziato 79 volte in 48 Posts
    Ed eccola una delle prime rom con sense 6 a bordo pronta per i test.
    Caratteristiche:
    -Based on 1.12.401.4 Release Keys
    -Android 4.4.2 Kitkat
    -HTC Sense 6.0
    -INT/TMOUS/ATT
    -Zipalligned
    -Deodexed
    -Rooted with SU
    -Busybox
    -Init Scripts for performance
    -Debloated
    -Stripped
    -Blazing Fast
    -Louder Sound (Ported from older base)
    -APM
    -Speed Tweaks
    -JDR0iD Optimisations
    -Aroma Options
    -Customisable Sense themes
    -Customisable Fonts
    - HTC Boomsound and Beats Audio- Fantastic sound
    -App Ops included
    -Custom Apps added
    -More to come after initial Release
    Installazione:
    Scaricate la rom e mettetela nella root del vostro one
    Riavviate in recovery(Dovete essere in S-OFF)
    Full wipe
    Installate
    Wipe cache e Dalvik
    Enjoy it!
    Changelog:
    eXoSeNSe v1.0C - 27th March 2014
    -Renamed to eXoSeNSe so another dev can continue with NuSeNSe
    -Battery power saving added (under Power in settings) <b>Fantastic battery saver</b>
    -Implemented myHub into build.prop ready for release
    -Added Widgets removal to Aroma
    -Added 4G tweak to aroma
    -Added Mail tweak to Aroma
    -Added NFC tweak to Aroma
    -Added proximity tweak to Aroma
    -Added Truer colour tweak to Aroma
    -Fast Dormancy added to Aroma
    -Updated SU files
    -Remove sys bar from Camera
    -Many optimization tweaks for <b>much better</b> performance
    -<b>FULL</b> zipalign on every boot
    -Fixed sound quality on unreleased version of 1.0C
    -Updated Permissions and Symlinks in Updater Script
    -Other tweaks but forgot.
    -Super Stable and Fanastic Battery!
    -Lag Fix (props Baadnwz)
    26th March 2014
    -Replaced system files and framework files
    -Used items from a different stock base to avoid conflict
    -Fixed status bar on camera (thanks Mr Bartek)
    -Added HTC Native EQS (thanks Jonny)
    -Removed system files
    -Build.prop tweaks
    -fixed issues with updater script
    -Added some apps
    -Fixed issue with Mail.apk
    -Fixed wipe status of Rom
    -Fixed the missing keyboard dictionary
    -More speed tweaks
    -Optimized system files for performance
    -More scripts for better performance
    -Zipalligned with latest SDK
    Questa è una release iniziale siamo alla prima versione sono già in download dopo posterò delle impressioni per ora vi lascio scaricare
    Download!-Pesa 785 mega!!!
    Crediti:JDR0iD,mwilky,badnez, mike, Tbaldwin, Troby86(base)
    Ultima modifica di electrostatus; 31-03-14 alle 15:30
    Io cerco di fare del bene postando quello che so e aiutando per quello che so. Se gradite mettete un mi piace!
    HTC One REGNA!
  2. I seguenti 2 Utenti hanno ringraziato electrostatus per il post:
    Actuamy (25-03-14),Senso41 (25-03-14)
    Androidiano VIP L'avatar di Senso41
    Apr 2011
    XIAOMI MI A2 4/64
    Ringraziato 2,334 volte in 1,670 Posts
    La sto provando da stamattina ed è già amore a prima vista con la sense 6. Ha potenzialità strabilianti e la HTC sta davanti a tutti con questa interfaccia.
    Ho notato qualche bug evidente:
    - la galleria non visualizza nessun Cloud (dropbox, drive o skydrive)
    - mancanza dell'account HTC
    - non funziona l'applicazione ZOE, ma credo che dipenda da mamma HTC che sta spettando la presentazione di oggi.
    Novità evidenti:
    - Sfondo home e lockscreen diversificabili
    - Blinkfeed con o senza orologio a secondo se si mette come home oppure no
    - Blinkfeed con una montagna di collegamenti e rispetto al sense 5.5 molto più completo
    - Diverso sblocco, con la possibilità di sbloccare normalmente nella home, oppure scegliere Blinkfeed o altra pagina.
    - Colore di base diverso per ogni apllicazione, carina l'idea.
    - Fotocamera graficamente diversa, sembra tutta funzionante.
    - Icona 4G+ invece della solita H, un pò coatta però si vede bene.
    Ultima modifica di Senso41; 25-03-14 alle 15:17
    Xiaomi Mi A2
  5. #3
    Androidiano VIP L'avatar di Actuamy
    Martina Franca (TA)
    Samsung S8+
    Ringraziato 1,439 volte in 1,268 Posts
    Electrostatus la stai testando?
    Smartphone: Oppo Find 7
    Operatore: H3G
    Rom: Stock
    Kernel: Stock
    Recovery: TWRP 2.7.1.0
    ColorOS Version: 1.2.3i
  6. #4
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Riaperto
    Ultima modifica di iGuich; 25-03-14 alle 23:34
  7. #5
    Casa mia
    HTC One
    Update out
    HTC One REGNA!
  8. Il seguente Utente ha ringraziato electrostatus per il post:
    Senso41 (31-03-14)
  9. #6
    Apr 2011
    XIAOMI MI A2 4/64
    Aggiungerei che la rom ha cambiato nome in eXoSeNSe
    Xiaomi Mi A2
  10. #7
    Casa mia
    HTC One
    Quote Originariamente inviato da Senso41 Visualizza il messaggio
    Non ho il permesso di modificare i titoli e l'idea di base è sempre la dense 6
    HTC One REGNA!
  11. #8
    e compatibile con htc one mini mi piacerebbe provare boomsound
