Pagina 361 di 445 primaprima ... 261311351359360361362363371411 ... ultimoultimo
Visualizzazione dei risultati da 3,601 a 3,610 su 4444
[ROM] InsertCoin SixthSense | Android 4.4.2 Sense 6 | ROM Kontrol - Tweaks | myHUB |
  1. #3601
    Androidiano VIP L'avatar di Andreasworks
    Sep 2010
    HTC One M8 silver
    Ringraziato 323 volte in 281 Posts
    Quote Originariamente inviato da EaglesGPC Visualizza il messaggio
    Have a nice week
    Quindi la 45 è l ultima di sto giro ...fino a lunedì ?
    EDIT: Comunque ho provato a metterla ma a me continua a dare li stessi problemi in Note e Blinkfeed....mentre la 4.0.1 è ok , attendiamo novità .
    Rilasciata 4.0.2 "ufficiale" Qui
    Ultima modifica di Andreasworks; 30-08-14 alle 19:34
    HTC ONE M8
    silver
    SIM :Vodafone
    UNLOCKED /S-OFF/CID 405
    HBOOT :3.19.0.0000
    RADIO :1.25.214500021.06G
    OpenDSP :v48.2.2-00564-M8974_F0.1211
    FIRMWARE :4.16.401.10
    RECOVERY :Twpr 2.8.7.0 M8
    Rom : Leedroid 7.4.3
    Kernel : Lonelyx
    Androidiano VIP L'avatar di nightcervant
    HTC ONE
    Ringraziato 638 volte in 485 Posts
    Devo dire che il nuovo changelog non è niente male:
    Updated Playstore apps
    Update HTC Playstore apps
    Optimized Aroma install percentage indicator
    Added HTC Notes as optional
    Added HTC Zero as optional
    Added fourth theme in settings-personlize-theme (blue theme)
    Seperated HTC Backup and HTC Advantage/tips in Aroma
    Chrome Browser Sync is present at all times (non removable anymore)
    Removed InsertCoin Additional Plugins menu (blinkfeed doesn’t like when those are removed)
    Added HTC Boot Sound as optional
    Set persist.sys.scrollingcache to 4 (all times) as default but still optional choices in aroma
    Some reports say they have a massive memory usage, there for i deodexed stock apps but didn’t debugged them. This is only for testing to see if the memory issue is solved. my tools could be the culprit
    Removed EasyAccessService as optional, need for custom gestures with a cutom kernel but many delete it and then complain that it doesn’t work and don’t read the explanation in Aroma
    Added optional IC-Blue-Theme for testing only, won’t be added in final release!
    Fixed NFC while screen off tweak
    Possible fix for camera manual mode
    Fixed HTC apps which have to be updated via PlayStore
    Redone and cleanup Aroma / folders / addons folders / ect for better maintaince
    Fixed sudden reboot on setupwizard
    Fixed perapp color for blinkfeed which turned grey instead of the chosen color
  4. Il seguente Utente ha ringraziato nightcervant per il post:
    SLiM94 (30-08-14)
  5. #3603
    Agrigento
    HTC One - Desire Z
    Ringraziato 34 volte in 31 Posts
    Molto abbondante questo changelog
    Non so voi ma pur avendo su la Viper, al momento posso dire che la IC è la migliore per ME.
    HTC_ONE 32gb Silver
  6. #3604
    Sep 2010
    HTC One M8 silver
    Quote Originariamente inviato da SLiM94 Visualizza il messaggio
    E come ti trovi con la viper ?
    HTC ONE M8
    silver
    SIM :Vodafone
    HBOOT :3.19.0.0000
    Kernel : Lonelyx
  7. #3605
    Agrigento
    HTC One - Desire Z
    Ti ripeto, per l'uso che ne faccio io la IC è il top per me.
    Comunque la viper potrei definirla un Open world Ti permette di fare la qualsiasi.
    Molto stabile e fluida ed una buona durata della batteria.
    Per toglierti ogni dubbio puoi sempre provarla
    HTC_ONE 32gb Silver
  8. #3606
    Sep 2010
    HTC One M8 silver
    Sai qual'è il problema è che tutta in inglese da settare e io non lo mastico e quindi son c.....
    HTC ONE M8
    silver
    SIM :Vodafone
    HBOOT :3.19.0.0000
    Kernel : Lonelyx
  9. #3607
    HTC ONE
    Quote Originariamente inviato da Andreasworks Visualizza il messaggio
    È un problema secondario quello, visto che noi del team di traduzione ci stiamo lavorando
  10. I seguenti 2 Utenti hanno ringraziato nightcervant per il post:
    Andreasworks (30-08-14),sago (01-09-14)
  11. #3608
    Agrigento
    HTC One - Desire Z
    [quote name="SLiM94" post=6034343]Ti ripeto, per l'uso che ne faccio io la IC è il top per me.
    Sai qual'è il problema è che tutta in inglese da settare e io non lo mastico e quindi son c.....[/QUOTE]
    Alla fine solo le app ufficiali venom sono in inglese..
    HTC_ONE 32gb Silver
  12. Il seguente Utente ha ringraziato SLiM94 per il post:
  13. #3609
    Sep 2010
    HTC One M8 silver
    Ho letto su xda che anche ad un altro crasha app note quindi non è solo un mio problema che imputavo al fatto di non aver fatto fullwipe (l avevo fatto solo 10 g al cambio del firmware ) vediamo che diranno...al Max settimana prossima lo rifaccio se non risolvo ..
    HTC ONE M8
    silver
    SIM :Vodafone
    HBOOT :3.19.0.0000
    Kernel : Lonelyx
  14. #3610
    Androidiano VIP L'avatar di EaglesGPC
    Ciociaria
    HTC One ViperOne 4.3.0
    Ringraziato 1,092 volte in 890 Posts
    Questa è una ROM che obbliga (sorvolando mo lo specifico caso dell'app note) a fare spesso full wipe.. Lavorano su talmente tante parti che si incasina spesso tutto... E' il pegno da pagare per avere un eterno work in progress
    HTC One Silver 32GB
    SIM: H3G
    S-OFF
    - UnLocked - SuperCID
    HBOOT: 1.61.0000
    RADIO: 4T.35.3218.16 OPENDSP: v35.120.274.0718 FIRMWARE: 7.19.401.2
    RECOVERY: TWRP 2.8.1.3 Unofficial
    ROM: SkyDragon V1 Sense 7
    KERNEL: Xceed™
    MOD: Project ERA v23.1 - V4A - Xposed Framework Alpha2
