[ROM] SENSEaY - XE35 v2.0.0 | 2.3.5 | Sense 3.5 | Tweaks | AmazeCAM | BEATS!!
    Androidiano VIP L'avatar di skanky80
    Apr 2011
    Udine
    Ringraziato 205 volte in 182 Posts
    Ed ecco la rom with Sense 3.5
    di casa CdTDroiD
    Su base (sperimentale) 2.08.401.1
    Importante:
    se si passa da una rom Sense 3.0 ad una Sense 3.5 è importante fare un wipe approfondito del terminale...vedere thread in rilievo...
    • Brand new 2.3.5 Base 2.08.401.1 RUU
    • BEATS Audio Fully working - Thanks Baadnewz!
    • CdTDroiD Tweaks - HUGE Thanks to Romanbb and RCTeam For the base files! > Optional
    • Speed & RAM Scripts
    • Latest Superuser
    • Zipaligned on every boot for speed
    • Custom Black boot animation
    • Full HTC Sense 3.5 3D
    • Custom boot sound
    • Clean fast and stable ROM perfect for everyday use
    • Secure SMS unlocked
    • Stock Battery icon with %
    • Extended quick settings
    • Stock battery percent
    • Advanced power menu
    • CRT animation
    • Great battery life
    • Lots of optional MODs > See POST #3
    • Sliding keyboard animation
    • Disabled HTC Snooping
    • Resized small fonts
    • White over glow
    • Custom "Darky" keyboard as 2nd Option - Thanks thoughtlesskyle
    • Adfree base
    • MULTI LANGUAGE
    • WiFi Driver improvements & greater range
    • Fast as hell
    • Disabled APK signature check
    • MMS Hack for bigger files
    • Hardware Acceleration Enabled (GPU UI Enabled)
    • Rooted and Latest Superuser added
    • Extra languages such as Chinese
    • ROOT File Manger Included
    • Unsecured boot.img
    • Lots of tweaks for speed and memory improvements
    • Fully Zipaligned
    • Fully de-odexed
    • init.d scripts (BusyBox run-parts) support
    • EXT 4
    • Modified Rosie nav bar without text - Thanks m-deejay for mod
    • Very Fast & Fluid!
    S3N5EaY XE35 v2.0.0 - Full ROM Release Date: 30 October 2011
    **Full wipe raccomandato**
    • Added 2nd QuickLaunch widget (resized again) - Thanks again Shnizlon & Maxdroid
    • Re-Zipaligned with latest Android SDK
    • Updated Tweaks in addons section > Lockscreen now works for Honeycomb + AOSP Options, Overglow settings work, No Bootlooping on Quicksettings
    • Added ICS "Roboto" Fonts with patch for stock fonts
    • Removed divider lines in menus for a cleaner look
    • Lots of minor speed tweaks
    • Fixed wrong data icon in power menu
    S3N5EaY v1.9.0 - Small Update Release Date: 23 October 2011 THE DAY THE ALL BLACKS WON THE RUGBY WORLD CUP!!!
    **Flash over v1.8.0**
    • Added UltraSmooth Rosie (Launcher) as default with flashable 3D Launcher - Thanks hamdir ported to S3N5EaY By me
    • Changed second splash "CdTDroiD" to "S3N5EaY"
    • Added properly re-sized QuickLaunch Widget - Thanks [B]Shnizlon & Maxdroid
    • CRT animation OFF as default with patch to add
    • Improved dial out speed
    • If you have tweaks installed you need to reflash them after updating
    S3N5EaY v1.8.0 Release Date: 19 October 2011
    • Removed CdTDroiD Tweaks (Will make Addon patch for those who want it)
    • Added Amaze Camera v4 > Includes Amaze gallery with Detection folders for, Panoramic, Clear shot, Perfect shots etc...
    • Added QuickLaunch Widget resized - Thanks Baadnewz
    • CRT Animation stays
    • Added SpeedTweaks script
    • Added stock resized fonts (Instead of the slightly stretched out ones)
    • Replaced ASTRO File Manager with OP File Manager (Cleaner)
    • Removed my un-needed RAM Hungry apps > HTC News > E Reader
    • Added 4EXT Recovery Updater - Thanks madmaxx82
    • Slightly improved volume with Beats Audio
    • Added Beats Wallpaper
    • Still Updating, More to come!!
    Ultima modifica di skanky80; 30-10-11 alle 16:06
    Ready for HTC M8....
    Apr 2011
    Udine
    Riservato...01
    Apr 2011
    Udine
    Riservato...02
    Apr 2010
    Stasera quasi quasi la provo...
    Inviato dal mio HTC Sensation Z710e usando Androidiani App
    qualcuno ha provato questa ROM? Ho visto che è uscita la versione 1.4.2 con una nuova versione del kernel.
    cosa mi potete dire?
    Apr 2011
    Udine
    Quote Originariamente inviato da ciccio4242 Visualizza il messaggio
    Io la flasharò oggi, poi ti dico.
    Edit: Il primo impatto è decisamente buono anche se ho dovuto ripetere il flash 2 volte perchè la prima volta mi resatava impallata sulla boot animation. Comunque sembra molto veloce e reattiva ora staremo a vedere come si comporta sulla lunga distanza.
    Ultima modifica di skanky80; 09-10-11 alle 16:58
    ho flashato anch'io. anche la mia impressione è più che buona. veloce e reattiva anche se il market si è impallato 2 volte (è apparso il messaggio di interruzione forzata di android) e all'uscita dalla fotocamera si è freezato il telefono (ho dovuto togliere la batteria).
    Ho scaricato CPU Info per capire il carico della CPU ma mi dice che il secondo core è spento... come mai? (stessa cona con la rom android revolution)
    Altra curiosità: volendo sostituire il solo kernel quale consigliate?
  9. #8
    Apr 2011
    Udine
    Io l'ho tolta perchè dopo mezza giornata ha cominciato a darmi problemi superuser che non accettava più i permessi per nessuna app.
    Per il core posso dirti con certezza che è l'app CPU info che funziona male nel senso che era spento quando lo ha analizzato, il secondo core entra in funzione solo quando il primo è in difficoltà.
    Per il kernel..se proprio lo vuoi cambiare..metti il fauxperò prima fai un backup della rom.
  10. #9
    Per ora non ho avuto i tuoi problemi. Io la terrò qualche giorno per vedere come si comporta anche con i consumi. Solo per curiosità: a quale ROM sei tornato?
  11. #10
    Apr 2011
    Udine
    Ho messo la Pyramid3D 7.9.2 l'altra rom cdtdroid con sense 3.0 flashata ieri sera che per il momento non ha problemi..speriamo..
    Comunque sono abbastanza convito che sia colpa della recovery se le rom si installano male spesso e volentieri, quindi ho deciso di rimettere la versione che installa revoultionary dopo aver fatto s-off e vedere come va, nell'attesa che ci facciano la recovey buona e sarà sampre ora!!!
  12. Il seguente Utente ha ringraziato skanky80 per il post:
    ciccio4242 (10-10-11)
