domanda su cyano 7.2
ragazzi è uscita la build 7 xda-developers - View Single Post - [ROM][NIGHTLY][GWK74/2.3.7] CyanogenMod 7 Nightly Builds
però ci sono due versioni, With scrolling cache enabled [Androids default] With scrolling cache disabled [mod]
qualcuno sa dirmi quale differenza c'è?
Me lo chiedo anche io aspettiamo risposte da chi ne capisce un po' di più :-P
ma per quale motivo avete aperto un nuovo topic quando c'era quello già delle night? cmq mo chiedo e vi dico
ecco la risposta:
In essence, it is an option that allows applications to generate a cache for the content of a list in which you are scrolling in. In principle it should make scrolling troughout that list more faster (as the content is cached), but this feature also uses more memory (because of the fact it has to generate a cache, next to displaying the scrolling content itself). So if you do not have much memory and you're scrolling in a big list, it will lag because your app has to 1. display the content you are scrolling in and 2. build up a cache for that content (which occupies a significant amount of memory as the list, and thus the cache, is big).
Or this is what I've understood from it :)
Basicly, I have noticed that you can scroll faster troughout a big list (no difference when the list is small). This can be a folder on your phone, but also for facebook etc, faster scrolling is reported. More info on that toppic can be found here.
The only negative drawback I've found, is that the CRT on/off animation doesn't work with it.. Which I think is very unfortunate, because I like that :)
Io ovviamente e credo come djdido volevavo una risposta in italiano :-)
Edit:
QUI LA RISPOSTA DEL SIGNIFICATO RICHIESTO -----> https://www.androidiani.com/forum/mo...builds-20.html
ma porca miseria ho sbagliato a scrivere lo messa nel thread sbagliato ._.
che c'è di nuovo, comuque se mi metti il link del download in questo link https://www.androidiani.com/forum/mo...builds-21.html
nino90
nino ci sono già se non hai visto
Qui chiudo allora, ho allegato al primo post i link.
