Pagina 1 di 7 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 70
Lista Kernel
    Androidiano VIP L'avatar di nino90
    Oct 2010
    Barletta
    Ringraziato 207 volte in 128 Posts
    Lista Kernel
    Ciao ragazzi qui aggiungo i kernel disponibili per il nostro dispositivo.
    [Discontinue][no wifi n][default 518][fix hotspot] kernel based on CM7 & HCDRJacob's
    Changelog
    codice:
        Disable Wifi N mode (included in all mod changed kernels)
        Boot up with default max 518MHz and min 245Mhz cpu frequency (included in all HCDR mod changed)
        Apply same configuration as v4.1 to wifi driver, should be compatible with most froyo ROMs (included in HCDR mc2)
        wifi hotspot fix for Sense ROM. (included in nFinity mc2/3)
        update frequency table from #40. 480MHz return and 19MHz go away. (included in nFinity mc3)
        Fixed FM Radio with Sense. (included in nFinity mc4)
        Merged from based: add smaller footprint TinyRCU. Add missing cache routine. (included in nFinity mc4)
        Out of curiosity, i compiled kernel from CM7.1.0.1 with wifi N disabled. Not tested on Sense rom(buzz-kernel-2.6.35mc1.zip)
    Download:
    HCDR.Kernel_v4.2mc2_Flashable.zip
    nFinity 2.6.35 (Kernel included by default in CM7 - Do NOT use on the Stock ROM) by arco68
    Download:
    nFinity 2.6.35
    nFinity 2.6.32 by arco68
    Download:
    nFinity 2.6.32
    [CIFS][WiFi Sleep Fix][Multicast][NFS][AOE]Kernel based on HCDRJacob's/Arco's nFinity kernel source by s7mx1
    Changelog
    codice:
    1) wifi sleep fix. This is a killer problem for applications sensitive to latency when the screen is turned off. This is caused by the default aggressive wifi power saving policy. This is a permanent fix for anyone experiences voice drop when screen is off during wifi voip call.
    2) cifs support. This will enable you to access windows share on your wildfire.
    3) multicast. I believe not many people use multicast on their wildfire but its good to have an option.
    4) network file systems like nfs and aoe. Personally I have not tested them at all.
    5) other small changes which I can not remember
    I have built three versions so far and wildpuzzle room users (possibly other sense rom users) please try HCDR.Kernel_0593ef9.signed.zip to guarantee a working wifi. They are zip files can be flashed to any rom. Please take a backup before you flash the kernel and I will hold no responsibility for the result of such flash!!!
    HCDR.Kernel_v4.2_606a571.signed.zip this is the latest kernel based on jacob's 4.2
    HCDR.Kernel_v4.1_a91e73b.signed.zip this is the kernel based on jacob's 4.1
    HCDR.Kernel_0593ef9.signed.zip this is the kernel based on jacob's early version of build
    == update 2011-05-23 ===
    It looks like jacob has moved on with his zte blade and arco has taken over. I have grabbed arcon's latest stable kernel https://github.com/arco/htc-kernel-buzz/ and build my own with similar kernel configs to my previous modified kernels. The attached flashable zip file is called ARCO.Kernel_eaa7283-22.05.11.signed.zip and I have tested it with CM 7.0.3
        Working wifi with screen turned off
        Working Bluetooth
        Working GPS
        Working Wifi hotspot (tethering)
        Merge most kernel module into kernel. Now only aoe and wifi modules are installed separately.
    Download:
    [KERNEL][OC/UV][BFQ][AUFS][FTW][GPL] HCDR.Kernel v4.2 || Flash to any ROM
    Download:
    HCDR.Kernel_v4.2b_Flashable
    [KERNEL]InfinityPLAY[CM/AOSP][FLASHABLE ZIP]
    codice:
    [v10] - Added SIO (Simple IO) Scheduler
    [v10] - Enabled Deadline IO Scheduler
    [v10] - Enabled CFQ IO Scheduler
    [v10] - Use No-Frills CPU Control app in the market to set IO Scheduler
    [v9] - Tweaked SmoothAss CPU Governor to work at optimum speeds
    [v9] - Tweaked CPU Tables, MAX OC is now 780MHz - need to update zip script
    [v9] - Added Scary CPU Governor!
    [v8] - Made a super easy script for me to create a flashable zip in seconds!
    [v8] - Patched Interactive CPU governor with arco's updated sources
    [v8] - Fixed screen freezing
    [v7] - Seems to be a problem with screen freezing, checking it out
    [v7] - Left max OC at 800MHz, need to know what people want as the Max
    [v7] - added lines to sched.c for some governors
    [v7] - Added LagFree CPU Governor
    [v7] - Enabled SmartAss (v1)
    [v6] - Fixed CPU tables for 800MHz overclock
    [v5] - Added InfinityPLAY.zip for easy flashing.
    [v4] - Compiled with 4.4.3 arm-eabi toolchain.
    [v4] - Fixed SmoothAss CPU Frequency, now at 122 to 710MHz instead of 172 to 1041MHz
    [v3] - Min CPU Frequency Default @ 264MHz ----\ You can change these using
    [v3] - Max CPU Frequency Default @ 633MHz----/ setCPU or in cm settings.
    [v3] - left CPU tables the same, you can still OC to 800MHz if you want for now.
    [v3] - Added SmoothAss CPU governor
    [v2] - Added SavagedZen CPU governor
    [v1] - Added CPU governor InteractiveX
    [v1] - Tweaked OC speeds to 800MHz
    [v1] - Added MinMax CPU governor to source (doesn't work, won't compile so it is left out of the kernel for now)
    Download:
    InfinityPLAY
    Ho provato personalmento questo kernel sull'ultimo nightly della cyano e veramento sono rimasto impressionato dalla velocità.
    Ho usato queste impostazioni.
    Impostazioni>CyanogenMod>Performance>impostazioni CPU.
    Goverator disponibili: LAGFREE
    Minima frequenza CPU: 518 MHz
    Massima frequenza CPU: 768 MHz
    Selezionate imposta all'avvio.
    Tornate alla schermata precedente.
    Usa compcache: 18%
    Usa JIT, abilita dithering e Recupera memoria bitmap (devono essere selezionati)
    Ultima cosa, Dimensione Heap VM selezionate 32m.
    Riavviate il dispositivo.
    Ultima modifica di nino90; 11-04-12 alle 09:31
    HTC Wildfire
    Rom: COSG3
    Versione Android: 2.3.7
    Il braccino mette il cippino
  2. I seguenti 3 Utenti hanno ringraziato nino90 per il post:
    biondo17 (28-08-12),dalp25 (27-05-12),meland (22-08-12)
    Ciao, ho il kernel 2.6.32, ma spesso di disconnette la wifi, ho capito male o questo è confermato da quello che hai scritto?
    Ultima modifica di nino90; 18-11-11 alle 10:14
  5. #3
    Oct 2010
    Barletta
    Quote Originariamente inviato da Snakeforever Visualizza il messaggio
    Non c'era il caso di quotare tutto il post, ho modificato il tuo messaggio, comunque prova ad aggiornare la radio(clicca qui per scaricare l'ultima versione.)
    HTC Wildfire
    Rom: COSG3
  6. #4
    Quote Originariamente inviato da nino90 Visualizza il messaggio
    Cosa comporta l'aggiornamento della radio? e cosa sare di preciso la radio? tu hai installato questa che mi hai fatto scaricare?
    Mi confermi anche che il kernel 2.6.35 non si può installare con la rom originale 2.2.1?
    grazie e ciao
  7. #5
    Oct 2010
    Barletta
    grazie e ciao
    Allora la radio aggiorna diciamo "i driver" del wi fi, del gps del BT ecc. e io ho installato l'ultima versione(quella che ho indicato)
    Comuque se trovi scritto che non bisogna installarlo sulle rom originali, quindi io eviterei. Poi puoi fare come vuoi tu.
    HTC Wildfire
    Rom: COSG3
  8. #6
    Androidiano VIP L'avatar di djdido
    Apr 2011
    LG G4
    Ringraziato 218 volte in 121 Posts
    nino potresti mettere questa lista in rilievo?
    ps:scusa volevo scrivere questo messaggio in questa discussione https://www.androidiani.com/forum/mo...-recovery.html
    Ultima modifica di djdido; 29-11-11 alle 15:26
    HTC Wildfire White >Samsung Galaxy S GT-i9000/i9001 Black >Samsung Galaxy S3 White >Google Galaxy Nexus White >
    Samsung Galaxy Note 2 White>Samsung Galaxy S4 White >LG G2 White >Samsung Galaxy Note 3 White >LG G4 Leather Brown >
    Samsung Galaxy S7 Edge Black Onyx >
    Samsung Galaxy S8 Midnight Black
  9. #7
    Apr 2011
    LG G4
    come si fa a capire un kernel adatto ai propri usi? ho una cyano nighly e vorrei che il cell digerisca meglio i giochi, magari risolvo cambiando kernel? ho l'nfinityarco@tuxbox#1
  10. #8
    Apr 2011
    LG G4
    ragazzi come faccio a scaricare questo kernel [KERNEL]InfinityPLAY[CM/AOSP][FLASHABLE ZIP] - xda-developers
    ho creato anke l'account dropbox..
    ps:sono riuscito a scaricarlo
    Ultima modifica di djdido; 06-12-11 alle 22:14
  11. #9
    Oct 2010
    Barletta
    metto in rilievo
    HTC Wildfire
    Rom: COSG3
  12. #10
    Oct 2010
    Barletta
    Aggiornata la lista, ho aggiunto il kernel InfinityPLAY, il migliore secondo me.
    HTC Wildfire
    Rom: COSG3
  13. Il seguente Utente ha ringraziato nino90 per il post:
    Carletto74 (27-01-12)
