Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 17
[ROM][4.0.4][DEV] PARANOIDANDROID for Wildfire - v1
    Senior Droid L'avatar di JakoWildfire
    Lecce
    SGS2, HTC Wildfire, Folio 100
    Ringraziato 79 volte in 43 Posts
    Jakowildfire e' tornato
    <br>
    DOWNLOAD V1: Click Here To Downlaod.
    <br>
    <br>
    big thanks to:
    - paranoid team
    paranoid android - home
    - everyone who worked for wildfire's cm9
    - everyone who worked for galaxy mini's paranoid rom (all the list of people it's here: http://forum.xda-developers.com/show....php?t=1873227)
    - pm me if i forgot someone
    working:
    The same as cm9
    bugs:
    - same as cm9
    - some apps may not look well in tablet mode
    - 4g settings
    - nexus settings
    - some things at 1st boot aren't in the correct language, just reboot and they will work
    - changing framework to tablet mode causes bootloop
    - you tell me
    please read:
    All the paranoid settings are untested, i reccomend to setup the rom as you like, do a nandroid backup and then play with them! There is an high chance that if you change them, you will end in bootloops.
    Installation:
    1- make a backup of your current rom
    2- wipe data/factory reset in recovery
    3- wipe dalvik-cache
    4- flash paranoidandroid rom zip
    5- reboot
    6- flash gapps
    7- reboot & enjoy!
    Changelog and download #2 post!
    If you liked my work, please hit the thanks button!
    Immagini allegate
    Ultima modifica di JakoWildfire; 07-10-12 alle 20:07
    • Samsung Galaxy S2 (i9100) • HTC WildFire S-Off Roted •
    Rooted con : Alpharev X S-Off
    Versione Android: 2.3.7
    Versione Kernel: 2.6.35.13-nFinity arco@tubox #1
    Overclock cpu: MIN: 245 MAX: 729
    Versione MOD: CyanoGenMod 7.1 NIGHTLY buzz
    Versione browser: Webkit 3.1
    Se ti sono stato utile, clicca THANKS qui sotto
    Non so se è corretto rispondere qui ma volevo fare i complimenti è una rom fantasticaaaaaa e la sto testando e volevo darvi qualche info skype si installa ma non funziona (skype a smesso di funzionare appena fai il log), il microfono sulla tastiera android non si attiva e la torcia non si attiva
    sperando di essere stato utile grazie ancora .........
    p.s. in fase di installazzione del pacchetto gapps mi ha dato errore e non ne usciva piu fuori cosi ho dovuto fare l'install di paranoid da recovery .... mi chiedo non dovevo farlo da rom manager la prima install di paranoid ?????
    ciao e grazie ancora
    Ultima modifica di Woltrinus; 30-10-12 alle 22:32
    Androidiano L'avatar di elia222
    Sony Xperia S, Nokia Lumia 920
    Ringraziato 496 volte in 161 Posts
    Ciao! sono l'autore della paranoidandroid su xda che hai postato qua.. posso solo chiederti di mettere un link anche al mio thread "ufficiale" di xda? Grazie
    ciao elia222 ho aggiornato la tua creazione alla V. 2.1. come da istruzioni su xda :-) ma una curiosità ......
    sul mio wildfire continua a dirmi che ho la V.1. O.o ...... cmq i cambiamenti ci sono stati ^_^ ...... in meglio ;-)
    attendo con ansia i nuovi aggiornamenti
    p.s. non so se ti è utile farti sapere come reagisce la tua creazione, cmq ribadisco è fantastica
    ciao e grazie
    che bug ha ancora? , molto più lenta della cyano 7?
    Quote Originariamente inviato da Woltrinus Visualizza il messaggio
    ciao e grazie
    È normale che segni v1, mi sono dimenticato di aggiornare il numero di versione xD
    lol immaginavo .... cmq anche se piu lenta non riesco a farne a meno ^_^
    segno un po di bizze che fa sul mio W.F.
    skype si installa ma quando faccio il log dopo un po mi dice che ha smesso di funzionare prima ancora che sinisce il login O.o
    la torcia non si accende dai comandi sulla barra ma se installo una qls app va bene ^_^
    il microfono per la scrittura un si attiva ..... ero riuscito a farlo apparire sulla tastiera ma..... nulla
    ciao e grazie ^_^
  9. Il seguente Utente ha ringraziato Woltrinus per il post:
    atos (07-11-12)
  10. #8
    Baby Droid L'avatar di ShuradiCapricorn
    si potrebbe postare il link per il download della versione 2 o eventuale successiva?
    su xda non riesco a trovarlo
    Ultima modifica di ShuradiCapricorn; 16-01-13 alle 12:20
    -ZenFone 2 ZE551ML-
    Android 5.0 rom stock ASUS + root
    -Zopo ZP998-
    Android 5.1.1 custom rom Degrus
    -AinolNovo7 ELF-
    Android 4.1.2 custom rom Shaun
    MAI E POI MAI FARSI PRENDERE DALL'ANSIA DEL BRICKKAGGIO PRECOCE
  11. #9
    come non detto l'ho trovato
    se mi date l'ok posto anche il link xda
    -ZenFone 2 ZE551ML-
    -Zopo ZP998-
    -AinolNovo7 ELF-
  12. #10
    Baby Droid L'avatar di BleedingX
    Mi sono letteralmente innamorato di questa Rom, praticamente l'ho messa oggi e viaggia che è una meraviglia dopo averla aggiornata alla versione 2.1, tuttavia andando su XDA ho visto che c'è la versione 3.0 e sta di fatto che non riesco a scaricarla, quindi la mia domanda è: è normale che non riesco a scaricarla? XD
