Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 17
Lista ROM con ANDROID 4.0 ICS per Wildfire
    Senior Droid L'avatar di JakoWildfire
    Lecce
    SGS2, HTC Wildfire, Folio 100
    Ringraziato 79 volte in 43 Posts
    Ecco a voi la lista di alcune rom basate su android 4.0 ics.
    Ringrazio Djdido per averne trovate altre!
    ( p.s. a quelle in cui è stato possibile ho allegato degli screenshot ufficiali )
    Chiunque ne conosce delle altre è pregato di scriverle nei commenti di questo post, in modo che aggiorni la discussione e diventi sempre più lunga.
    p.s. se le avete provate lasciate un commento con delle opinioni
    IL LINK DEL DOWNLOAD LO TROVATE NELLA PAGINA UFFICIALE DELLA ROM :
    CLICCATE SUL NOME DELLA ROM PER AVERE MAGGIORI INFORMAZIONI ( compreso download ) DAL SITO UFFICIALE
    [ROM][27/11][ICS] ICS4Fire [3G/DATA][v4][STOPPED]
    Wifi will never work on this ROM, because hero and buzz have different wifi chipset. If anyone can get a ICS rom with the BCM Wifi chipset ported I can get wifi to work.
    I have not got a full fix for the synaptics softkeys yet, flash the softkey mod if you have a synaptics screen or your softkeys do not work.
    SuperUser is included, but it fc's, you need to flash the 3.0.7 efgh zip file from Superuser
    Wifi will not work on this ROM
    [v4]Partially fixed synaptics touchscreen driver, only softkeys do not work with this ROM and that screen. You need to use the softkeys mod posted below if you want fully functioning softkeys.
    [v4]Added IDC file for synaptics touchscreen, should work, if not, I have another one.
    [v4]Added superuser binary and app - force closes so you need to download the zip and flash it at the link on the top of this page.
    [v3]Switched to full package update, if you are coming from another rom, wipe data, if you are upgrading this rom, just flash.
    [v3]Added SuperUser App due to request, seems to be not working, still need to flash the above file.
    [v2]Data/3G works, calling does too, and so does texting, not sure about mic so can somebody test from the other end of the call?
    [v2]Fixed build.prop with CM7 and original merge so now it picks up your network.
    [v2]Swapped existing libhtc_ril.so with the one for the wildfire
    [v1]Got touchscreen working and softkeys, but home softkey does not work, not so important though, back, menu and search work.
    [v1]Using InfinityPLAY+ kernel with atmel.c hack to enable touchscreen, sources on my github. It says #14 for version number but it is only #10 with tweaks compiled an extra 4 times for testing.
    What works:
    Touchscreen, this thread helped alot with it, just had to swap and switch a bit with the code because of differences between the MSM8X60 and the MSM722X boards.
    What does not work:
    Bluetooth, WiFi, some other stuff.
    This is just a ROM to play with, arco will bring us the real ICS.
    THERE IS NO BOOT.IMG, I USE A ZIMAGE INSTEAD!
    PERFORM A NANDROID BEFORE FLASHING, THIS ROM IS EXPERIMENTAL!
    I will not be held responsible for ANYTHING, thats right, I AM NOT RESPONSIBLE for any damage done to your device.
    Wipe data first, otherwise it will fc on com.android.phone.
    MODS
    UI Softkeys, thanks to koush for this, edited for buzz by me: http://dl.dropbox.com/u/13729847/buttons_mod.zip
    To undo the mod: http://dl.dropbox.com/u/13729847/undo.zip
    Screenshots for UI Softkeys:
    [DEV][ROM/TEST]schiznik's ICS w/ my kernel[WIFI?][DOWNLOAD LINK]
    Okay, schiznik has compiled AOSP for the wildfire from source, but he didn't get touchscreen to work, it is kernel related.
    I have took his update.zip, added my kernel to it and then repackaged it.
    In the kernel I have made the following modifications:
    - Fixed atmel driver for ICS touchscreen support
    - Fixed home button (thanks to arco for this)
    - Added my compiled wifi module to the rom, so theoretically wifi should work.
    As I do not have a wildfire anymore I have no way of testing it, so if people can test it for me I would be grateful.
    Download the ROM (flash it in recovery): Multiupload.com - upload your files to multiple file hosting sites!
    Link updated
    MAKE SURE YOU WIPE DATA/CACHE FIRST.
    Feedback needed, what does, and what doesn't work?
    This is mostly the work of schiznik, he deserves all the credit, I only fixed the touchscreen.
    Still, any thanks are appreciated.
    Keiran
    [DEV][ROM-AOSP]Htc wildfire icsV0.3 alpha (booting)(port from eris) discontinue[/B]
    Bugs so fare i know:
    Sound dont work.
    Wifi bt and gps dont work.
    chanelog: V0.3 :credits to KeiranFTW for fixing touchscreen.
    now you can call (you have singnal now).
    Credits to:
    KeiranFTW for fixing the touchscreen and maked a kernel.
    [DEV][ROM][Android 4.0]vanWeereld.BEMod | Suspend see thread | Alpha 4[/B]
    Hello all,
    The exams are coming. I have not acces to my computer anymore. So, the dev is suspend. You must to wait until 22 december. Sorry
    This a port from the Hero with Android 4.0. But no touchscreen
    So if anyone can help me, it will be very nice That's my "first" version.
    THIS IS A ALPHA VERSION ! IF YOU WANT A BETA OR STABLE RELEASE, PLEASE WAIT !
    Problems
    Everything...
    Working
    - Calls
    - Touchscreen
    Thanks to
    KeiranFTW for his kernel, Thank YOU !!!
    I need some developers that want to help me, I have not much time anymore (school)
    If I forgot to say anything, ask it
    Karting06
    PS: Sorry for my bad english :/
    Come ho già detto diteci se le avete provate o ne conoscete altre
    • Samsung Galaxy S2 (i9100) • HTC WildFire S-Off Roted •
    Rooted con : Alpharev X S-Off
    Versione Android: 2.3.7
    Versione Kernel: 2.6.35.13-nFinity arco@tubox #1
    Overclock cpu: MIN: 245 MAX: 729
    Versione MOD: CyanoGenMod 7.1 NIGHTLY buzz
    Versione browser: Webkit 3.1
    Se ti sono stato utile, clicca THANKS qui sotto
    Androidiano VIP L'avatar di nino90
    Oct 2010
    Barletta
    Ringraziato 207 volte in 128 Posts
    Ho provato la prima sembra carina peccato che non arriva il segnale.
    HTC Wildfire
    Rom: COSG3
    Il braccino mette il cippino
    Lecce
    Quote Originariamente inviato da nino90 Visualizza il messaggio
    Strano..dice che dovrebbe funzionare..è fluida?! va bene?!
    Oct 2010
    Barletta
    Quote Originariamente inviato da JakoWildfire Visualizza il messaggio
    Non tanto fluida, però solo inglese è.
    HTC Wildfire
    Rom: COSG3
    Lecce
    Peccato...
    Qualcuno HA notizie sulla CyanogenMod 9
    Se arrivera anche per il wildfire ??
    IO spero di si
    Lecce
    Quote Originariamente inviato da Djmark Visualizza il messaggio
    IO spero di si
    Molto probabilmente si!
  9. #8
    IO spero di si
    si pensa di si, ma si parla di febbraio per la RC a quanto si dice in giro, quindi per una stable ci vorrà ancora un pò...
  10. #9
    Lecce
    Quote Originariamente inviato da togno Visualizza il messaggio
    Credo che la prima la vedremo a gennaio..per la stable ci sarà da aspettare parecchio ancora :/
  11. #10
    Pazienza aspetteremo
