Pagina 4 di 5 primaprima ... 2345 ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 47
[Huawei Ascend G330][Guida] CWM Recovery 6.0.1.2 (ext3/ext4 funzionanti)
  1. #31
    LG L90
    Ringraziato 30 volte in 22 Posts
    Non credo ci sia nulla a riguardo. Ma pare si possa utilizzare la TWRP dell'Y300
    https://www.androidiani.com/forum/mo...-cm10-2-a.html
    Senior Droid L'avatar di dark706i
    Ringraziato 114 volte in 105 Posts
    Ecco la conversazione tra me e daddelgreis
    Quote Originariamente inviato da daddelgreis
    Quote Originariamente inviato da andrea2107
    Hi,would be amazing to see g510 stock based rom on g330,here you can find miui v5 with the guide to automatically translate it http://www.htcmania.com/showthread.php?t=677955
    Or if you can,there is in the same forum fusion x and b196 slim,do you can port it?
    Another question:
    How you have ported cm10.1?
    Hi andrea2107
    No it is not possible for both of Rom lacks the device tree.
    Miui 5 G330 is not a good solution I've already tested it slower than the stock rom on my Y300...
    Greeting Daddel
    Hi and thanks
    Now i am seeing that joestone is playing with cm10.2,but we can't port it because our cwm doesn't support selinux,do you can compile twrp?here the most simple guide: http://forum.xda-developers.com/show...php?p=41815413
    Hi andrea2107
    You can take the TWRP recovery from Y300 which also runs on the G330 error free since I got it 5 weeks it
    Du kannst das TWRP Recovery vom Y300 nehmen das läuft auch auf den G330 Fehlerfrei ich hab es seit 5 wochen drauf
    Greeting Daddel
  4. Il seguente Utente ha ringraziato dark706i per il post:
    MyEvo (22-09-13)
  5. #33
    Senior Droid L'avatar di l30n4rd0
    Terni/Roma
    HUAWEI Ascend G330 (U8825-1)
    Ringraziato 72 volte in 53 Posts
    Grazie! Ma poi con la ext4 sulla micro-sd funziona?
    Nel senso che se faccio un backup o un restore mi prende il nandroid backup che ho fatto con la cwm?
    Smartphone: Huawei Ascend G330 (U8825-1)
    ROM: CyanogenMod 11
    Recovery: TWRP 2.7.1.0
    Root: Done
    Unloock bootloader: Done
    Tablet: Nexus 7 3G 32 GB
    ROM: CyanogenMod 11 for Tilapia
    Recovery: TWRP 2.6.3.0
    Root: Done
  6. #34
    Quote Originariamente inviato da l30n4rd0 Visualizza il messaggio
    I backup cwm non sono compatibili con quelli twrp
    Credo che la recovery supporti tutto (ext3 ext4..)
    Se poi non la vuoi piú riflashi la cwm
    Ultima modifica di dark706i; 22-09-13 alle 14:15
  7. #35
    Terni/Roma
    Quote Originariamente inviato da dark706i Visualizza il messaggio
    Ok. Allora faccio anche il backup della cm10 con la cwm, poi dopo metto la twrp e mi faccio i backup della cm10 e della stock anche con quella.
    Tra flash e ri-flash oggi mi scoppia :P
    ROM: CyanogenMod 11
    Root: Done
    Root: Done
  8. #36
    LG L90
    Hehe facci sapere come si comporta la twrp!!
  9. #37
    Terni/Roma
    Quote Originariamente inviato da MyEvo Visualizza il messaggio
    Per il momento pare che funzioni, la sto finendo di testare... Poi edito questo messaggio e apro anche una nuova discussione per la twrp.
    ROM: CyanogenMod 11
    Root: Done
    Root: Done
  10. Il seguente Utente ha ringraziato l30n4rd0 per il post:
    MyEvo (22-09-13)
  11. #38
    Per chi ha il build.prop con y300 la può flashare tramite goomanager
    Edit:flashata via flashify,per ora non ho tempo per provarla,piú tardi la provo,so solo che boota e il touch funziona
    Ultima modifica di dark706i; 22-09-13 alle 18:58
  12. #39
    agd
    agd non è in linea
    N/A
    nexus 5
    Ringraziato 52 volte in 51 Posts
    L hai scaricato dal playstore? Se si quale?
    Inviato dal mio Ascend Y300 usando Androidiani App
  13. #40
    questo,molto professionale e comodo,fa pure il backup della recovery attuale
    Editotremmo anche ricavare la recovery stock con questo
