[LG G3s][KERNEL]Bread and Butter Kernel Lollipop D722/D724
    Senior Droid L'avatar di daniel13
    Roma (RM)
    LG Nexus 5X
    Ringraziato 65 volte in 56 Posts
    Salve a tutti,vi presento questo kernel per il nostro terminale. Il thread originale è questo: [KERNEL] Bread and Butter io ho solamente riportato e tradotto parzialmente il tropic.
    ATTENZIONE ! Nè io, nè il forum, nè nessun altro, siamo responsabili di eventuali danni provocati al vostro device - Eseguite la procedura a proprio rischio e pericolo.
    VALIDO SOLO PER G3S D722 E D724 CON FIRMWARE LOLLIPOP STOCK O PER CM 12.1
    FEATURES:
    Default I/O Scheduler: ZEN
    Altri I/O Schedulers presenti nel kernel: DEADLINE, NOOP, CFQ, SIO, BFQ, ROW, FIFO, FIOPS, ZEN, VR.
    Default CPU governor: OndemandPlus.
    Altri CPU Govs presenti: Conservative, Performance, Intellimm, OndemandPlus, IntelliActive, Powersave, Conservative.
    Supporto per Kernel HOTPLUG (Intelli HotPlug by @faux123)
    Puoi settare la massima Frequenza della CPU quando lo schermo è spento !
    Support for KSM
    Versione del Kernel 3.4.108
    Lo Zip Contiene Kernel, Init.d, Modules and tweak for Zram (more Zram)
    Compilato Usando ArchiToolchain GCC 5.2.0
    ZZMOOVE governor profiles:
    * currently available profiles by ZaneZam and Yank555:
    * - (1)'def' -> Default -> will set governor defaults -
    * - (2)'ybat -> Yank Battery -> a very good battery/performance balanced setting -
    * - DEV-NOTE: highly recommended! -
    * - (3)'ybatext'-> Yank Battery Extreme -> like yank battery but focus on battery saving -
    * - (4)'zzbat' -> ZaneZam Battery -> a more 'harsh' setting strictly focused on battery saving -
    * - DEV-NOTE: might give some lags! -
    * - (5)'zzbatp' -> ZaneZam Battery Plus -> NEW! reworked 'faster' battery setting -
    * - DEV-NOTE: recommended too! -
    * - (6)'zzopt' -> ZaneZam Optimized -> balanced setting with no focus in any direction -
    * - DEV-NOTE: relict from back in the days, even though some people still like it! -
    * - (7)'zzmod' -> ZaneZam Moderate -> NEW! setting based on 'zzopt' which has mainly (but not strictly only!) 2 cores online -
    * - (8)'zzperf' -> ZaneZam Performance -> all you can get from zzmoove in terms of performance but still has the fast -
    * - down scaling/hotplugging behaving -
    * - (9)'zzinz' -> ZaneZam InZane -> NEW! based on performance with new insane scaling active. a new experience! -
    * - (10)'zzgame' -> ZaneZam Gaming -> NEW! based on performance with scaling block enabled to avoid cpu overheating during gameplay -
    * - (11)'zzrelax'-> ZaneZam Relax -> NEW! based on moderate (except hotplug settings) with relaxed sleep settings -
    Istruzioni per l'uso: Flash da recovery
    Tips:
    Usa Adiutor per tweaksare il kernel
    Low memory killer values in Adiutor:
    Aggressive (ui piu veloce)
    Medium (ottimizzato il multitasking)
    Light (migliore multitasking)(increase empty applications to 128MB)
    Disable MPDecision and use Intelli Hotplug instead.
    Use OndemandPlus as CPU governor
    Set entropy to 1024 (read) and 2048 (write)
    Changelog:
    17/07/15 #3
    Added faux123 SoundControl v3.4
    Updated Intelli-Plug to v3.9
    Added check for scanned pages in KSM (skips already scanned pages)
    17/07/15 #4 OVERCLOCK UPDATE (D724 screen problem fixed)
    New CPU and GPU frequencies
    CPU: 192MHz - 1593MHz
    GPU: 100MHz - 533MHz
    30/07/15 #5
    Removed CPU Overclock
    Added init.d support (rom side)
    Added fast charge v2 (activate in Kernel Adiutor, battery menu)
    04/08/15 #6
    Google Snappy Compression
    I/O Boost
    ZRAM optimisation
    ZRAM init script tweak to give more zram.
    05/08/15 #7
    Updated Google Snappy to latest version
    More ZRAM optimisation
    Updated cross compiler version (GCC 5.2)
    07/08/15 #8
    Added LZ4 Compression/Decompression Algorithm
    ZRAM optimisations
    Added F2FS filesystem support
    Switched ZRAM compression algorithm to LZ4
    *ZRAM is faster now*
    08/08/15 #9
    Added mount point for f2fs /data & /cache only
    29/08/15 #10 UPDATE: #10 script fixed for CM
    GPU OC 600MHz (thanks to @thepietn1)
    Added Simple GPU algoithm
    Added Dynamic FSync
    Added Powersuspend v1.5
    05/09/15 #11
    Fixed DT2W for CM (Thanks to @nikita Pro Android)
    Changed Toolchain to Hyper-linaro GCC 5.1.1
    Remove Checksum from sound control
    Updated fast charge v2
    06/09/15 #12
    Removed debug from kernel
    Fixed reboot to recovery issue
    Back to ArchiToolchain GCC 5.2.0 (scores 20K+ on Antutu)
    08/09/15 #13
    Added VFPV4 and NEON support
    Cortex A7 optimisations
    Add AES and SHA1 routines
    Added Ofast flag for compilation
    GPU optimisations
    23/09/15 #14 (D724 touch problem fixed #14.1)
    Added new governors:
    zzmoove
    smartassV2
    abyssplug
    SmartassH3
    lagfree
    brazilianwax
    HYPER
    interactiveX
    lulzactiveq
    pegasusq
    sakuractive
    SavagedZen
    hybrid
    Overclocked BUS and RAM to 800MHz
    Added several new CPU frequencies
    O3 instead of Ofast optimisations
    Changed kernel and ramdisk compression to LZ4
    Added UKSM 0.1.2.3
    03/10/15 #15
    Released in Kernel Adiutor
    11/10/15 #15.1 (CM only)
    Updated RAMDISK for unofficial cyanogenmod for g3 beat
    *can be updated from kernel adiutor*
    *New host added: https://dl.cubeserver.eu/TheNotOnly/*
    12/10/15 #15.2(CM only)
    Fixed Bluetooth in CM (Thanks to @vm03)
    24/10/15 #15.3(CM only)
    LED fix
    Per problemi di audio per la CM 12.1 con Bread and Butter, ripristina mixer_paths.xml in /system/etc/.
    Contributors: OdinTech3
    Support for Updates has been added in Kernel Adiutor:
    For stock: No changes need to made.
    For CM: Add a line in build.prop
    D722: ro.product.device=jagnm
    D724: ro.product.device=jag3gds
    Downloads:
    Downloads:
    Kernel Adiutor: https://play.google.com/store/apps/d...ladiutor&hl=en
    Kernel: https://www.mediafire.com/folder/6jbh3xiki1mki/Lollipop
    Nuovo Host: https://dl.cubeserver.eu/TheNotOnly/
    Mixer_paths.xml: mixer_paths
    Github: https://github.com/TheNotOnly/android_kernel_lge_jagnm
    TUTTI I CREDITI VANNO A:
    @TheNotOnly
    Ultima modifica di daniel13; 12-11-15 alle 17:14
    HTC WILD FIRE S
    LG OPTIMUS SOL
    SAMSUNG GALAXY S3
    HTC ONE S
    SAMSUNG GALAXY S3 neo
    MOTOROLA MOTO G (2013)
    SAMSUNG GALAXY S4 mini
    LG G3
    LG G3 S
    LG G Flex 2
    MOTOROLA MOTO X STYLE
    BlackBerry PRIV
    LG Nexus 5X
  2. Il seguente Utente ha ringraziato daniel13 per il post:
    thekasper (10-11-15)
    S22 Ultra,Find X2 pro,Mi 10
    Quote Originariamente inviato da daniel13 Visualizza il messaggio
    FEATURES:
    Support for KSM
    Tips:
    Changelog:
    17/07/15 #3
    30/07/15 #5
    04/08/15 #6
    I/O Boost
    ZRAM optimisation
    05/08/15 #7
    07/08/15 #8
    ZRAM optimisations
    08/08/15 #9
    Added Dynamic FSync
    05/09/15 #11
    06/09/15 #12
    08/09/15 #13
    GPU optimisations
    zzmoove
    smartassV2
    abyssplug
    SmartassH3
    lagfree
    brazilianwax
    HYPER
    interactiveX
    lulzactiveq
    pegasusq
    sakuractive
    SavagedZen
    hybrid
    Added UKSM 0.1.2.3
    03/10/15 #15
    LED fix
    Downloads:
    Downloads:
    @TheNotOnly
    Anche qui sono necessari i warning e i disclaimer in testa al post. Grazie (comunque) per le guide.
    Sto Guidando (cit. Dieguccio)
  5. #3
    Jul 2017
    Kernel ADiutor is one of the best app to manage kernel
