Pagina 1 di 7 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 68
[ROM] CyanogenMod 10 (LG L9 II)
    Ringraziamo Varcain per il lavoro svolto
    19/02: La CM10 è disponibile anche per CWM
    THREAD UFFICIALE
    [ROM][UNOFFICIAL] CyanogenMod 10 for D605 - xda-developers
    GUIDA PER LA CWM
    Per installare la CWM occorre il root.
    Guida per il root: [ROOTING][L5,L7,L9]without flashing KDZ[easy/secure] - xda-developers
    ClockworkMod v6.0.4.6 download :
    Dev-Host - d605_cwm_6_0_4_6_v1.zip - The Ultimate Free File Hosting / File Sharing Service
    How to flash (you need adb on your PC):
    1. Extract contents on your pc
    2. Connect the phone with USB debugging ON (phone has to be rooted)
    3. adb push loki_flash /data/local/tmp
    4. adb push recovery.lok /data/local/tmp
    5. adb shell
    6. $ su
    7. # cd /data/local/tmp
    8. # chmod 777 loki_flash
    9. # ./loki_flash recovery recovery.lok
    10. # reboot recovery
    Alternatively (to flash without adb directly from phone):
    1. Extract contents on your PC
    2. Copy loki_flash and recovery.lok to you phone's SD card via MTP connection
    3. Download and start Android Terminal Emulator from Play Store
    4. From terminal emulator type:
    $ su
    5. Then type (assuming files from zip were copied to external SD card root) :
    # cp /storage/external_SD/loki_flash /storage/external_SD/recovery.lok /data/local/tmp
    6. # cd /data/local/tmp
    7. # chmod 777 loki_flash
    8. # ./loki_flash recovery recovery.lok
    9. # reboot recovery
    Guida per la CM10:
    The installation procedure was tested with unbranded phone (OPEN_EU variant). This might not work with branded ROM (but it would be good if someone check it).
    Sources can be found at:
    https://github.com/Varcain/android_kernel_lge_d605"]https://github.com/Varcain/android_kernel_lge_d605
    https://github.com/Varcain/android_device_lge_d605"]https://github.com/Varcain/android_device_lge_d605
    Things that I already know that don't work at all or are bugged:
    - NFC (no support at all yet)
    - USB tethering (no support at all yet)
    - Bluetooth tethering (no support at all yet)
    - IR port (no support at all yet)
    - Manual service network selection (only auto supported right now)
    - FM radio (no support at all yet)
    - Moving apps to SD card (this is a technical problem with insufficient support for emulated+external sd combination in CM10)
    For best battery life keep bluetooth off if you are not using it. It will keep constant wakelock if left on right now
    Stuff that I included but didn't test (due to lack of device to test against):
    - WiFi direct
    - SIM card PIN1, PIN2, PUK entry or changing (do not try this with your normal SIM card, try with some cheap starter card!)
    THIS ROM IS NOW A CWM FLASHABLE ZIP
    The ROM Release #3:
    http://d-h.st/Zr4
    GAPPS:
    Goo.im Downloads - Downloading gapps-jb-20121011-signed.zip
    Flashable stock ROM zip in case you want to go back (it's big):
    https://dl.dropboxusercontent.com/u/...d605_stock.zip
    How to install:
    1. Flash CWM (from here: [RECOVERY] ClockworkMod v6.0.4.6 for D605 - xda-developers [RECOVERY] ClockworkMod v6.0.4.6 for D605 - xda-developers
    2. Download the ROM and gapps to sdcard
    3. Boot to recovery
    4. Wipe all userdata
    5. Install CyanogenMod first then gapps
    6. Reboot.
    Now wait for CM to boot... (first boot will take longer as always).
    Ultima modifica di Whirring; 28-02-14 alle 09:36
  2. I seguenti 2 Utenti hanno ringraziato Whirring per il post:
    DjMoGnA (19-02-14),galaxygt (08-04-14)
    Senior Droid L'avatar di galaxygt
    Ringraziato 63 volte in 58 Posts
    Meno male tra poco avremo la recovery
    samsung s-plus,nitrox 4.0 nell'avatar la mia bimba da rally
    Se ti sono stato d'aiuto clicca su THANKS!
  5. #3
    Aug 2013
    Ringraziato 5 volte in 2 Posts
    un'altro paio di settimane e un giovane di xda anticiperá gli aggiornamenti di LG previsti per fine Marzo,incredibile O.O
  6. #4
    Apr 2011
    Ciao
    Scusa ma dove hai trovato la notizia che eventuali aggiornamenti sono previsti per fine marzo ?
  7. #5
    Aug 2013
    si parla di fine primo trimestre..
  8. #6
    Apr 2011
    e questo comprenderà anche il knock on ? da quello che leggo in giro io dovrebbe essere diverso da un aggiornamento versione completo e pare pare pare pare pare pare pare dovesse arrivare per la fine di gennaio 2014...........
  9. #7
    Aug 2013
    siamo quasi a metá febbraio e quando faccio il controllo dice sempre "stai usando l'ultima versione"
  10. #8
    Aug 2013
    forse ancora non ho ricevuto nulla per via del brand TIM dimmerda
  11. #9
    No, non è arrivato ancora nulla da nessuna parte.
  12. #10
    Androidiano L'avatar di Santuzzo98
    Google Nexus 5
    Per sbrandizzare come posso fare?
