[ROM] [UFFICIALE] [KK 4.4.2] CyanFox 2.0.2
Bene ragazzuoli :D
Visto che ho già pubblicato il thread su xda ho deciso di metterlo anche qui
CyanFox is a brand new custom aftermarket Android firmware (ROM) which is based on CyanogenMod 11.0 and Android 4.4.2 (AOSP) source bases with some new essential features added in.
Attention! CyanFox and it’s team hold no responsibility to any damage caused to your phone, loss of earnings as a result of damaging your phone or anything else that is connected to the development of this ROM.
CHANGELOG
Changelog for CyanFox 2.0.2:
Screen Recorder – added ability to record audio from microphone; also – in notification: to show touches while recording and stop button.
Status Bar: double-tap status bar to put device to sleep mode.
Lock screen security settings: lock screen slide delay, lock screen dots pattern size, vibration while unlocking, menu/home key buttons unlock, etc.
Screen recorder: info-warning about device requirements.
Speed up statusbar ant notification drawer expand/collapse actions.
Halo.
Navbar: custom height/width in portrait/landscape modes; switch to enable/disable navbar.
Sound settings: show DPS manager.
Advanced low battery indicator options.
Status bar: notification count, signal icon styles, show/hide clock, brightness control by sliding status bar.
Enable software-navbar options aslo for devices with hardware nav-buttons only.
Camera shutter sound toggle.
Network metter in status bar (up and down).
RAM bar in Recent Apps window.
New battery icon style: battery percentage without icon.
Many changes to Camera, Bluetooth, etc.
Full sync with CM
Installation:
Make sure you're using the latest CWM or TWRP
Flash ROM
Flash Google Apps (GAPPS)
Reboot
Download:
ROM: http://cyanfox-rom.com/downloads/?fo...2.0.2-p880.zip
GAPPS: http://cyanfox-rom.com/downloads/?fo...2013-12-15.zip
BUG:
gli stessi della cm11
Source:
G+: https://plus.google.com/communities/...05102439103284
Github: https://github.com/CyanFox
Official Site: Android 4.4.2 KitKat ROM - CyanFox ROM
Bug reports: Report a bug - CyanFox ROM
Non sto a tradurre anche perché non c'è molto da capire, per installarla è il solito procedimento, ricordatevi di avere la recovery aggiornata.
Divertitevi :)rotfl
