Pagina 2 di 5 primaprima 1234 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 50
[MOD][20/04] BR CameraMOD 2X | V20Q | 10-15-30-40mbps | Final v0.3 Trunk&Stable
  1. #11
    Scusatemi, per ripristinare la camera(presente nella v20q stock) dopo questo mod come posso fare? Purtroppo con questa mod i video si vedono a scatti :-(
    Venezia
    S4 & G3
    Quote Originariamente inviato da mikymiky91 Visualizza il messaggio
    hai una sd lenta? hai il bitrate a 30 mb? ......
  4. #13
    Quote Originariamente inviato da redefined
    Ho una sandisk da 8 gb hc. Però nelle opzioni di registazione video on fhd ho notato che l'archivazione avviene nella memoria interna
  5. #14
    Feb 2011
    Quote Originariamente inviato da ANDROIDPC Visualizza il messaggio
    BR CameraMOD O2X-E
    Actually. v0.3
    - Small improvement on image quality
    - Stock FPS for 1080p
    - Bitrate selector from 10 to 30mbps.
    ( only for spainish and english the rest is the usual quality selector )
    - Few FPS tweaks.
    - MP4 as output file.
    - Higher camera performance ( less blurred movies under movement ).
    - Memory boost 50MB.
    - Added crazy media profiles, haha lol ( really it doesnt do anything )
    increased audio sampling rate to 44.1kHz
    BR CameraMOD O2X-EX
    Actually. v0.3
    - Same as O2X-E but with litle diferent style. ( Icons and UI )
    this is totally optional, and if you dislike there is the stock version.
    BR CameraMOD O2X-T
    Actually. v0.3
    - FPS for 1080p @ 30FPS ( require fast SD and overclocked to avoid "fps dropping" )
    - Bitrate selector from 15 to 40mbps.
    - Few FPS tweaks.
    BR CameraMOD O2X-TX
    Actually. v0.3
    - Same as O2X-T but with litle diferent style. ( Icons and UI )
    Possible bugs or errors.
    - Sometimes the FPS went down when the light changes.
    - The phone may freeze if you dont have a fast micro SD ( when writing the video )
    - Random performance issue when using apps on background, solution use External SD to store your videos.
    What i have in my mind.
    - I want to play with 60 FPS ( 1080P impossible, so 720P or WVGA )
    - Modify the weird LG UI, with another more Eye-like.
    - Try to enable ISO 1200.
    - Try to enable continous-autofocus.
    Comparisons STOCK vs MOD
    VIDEO COMPARISON 1080P - 3 BITRATES - SUNLIGHT
    I made a mistake when putting the bitrate on the middle image, that is 16MBPS.
    Downloaf flasheable ZIP:
    Optimus 2X - Wuala
    Per maggiori approfondimenti rinvio al LINK di XDA:
    [MOD] BR CameraMOD 2X | GB 2.3.4 | 9-36mbps | BETA v0.1 - xda-developers
    Scusa ma tra queste 2 quale installare?
    BR_CameraMOD_O2X-E_Final_v0.3.zip
    BR_CameraMOD_O2X-T_Final_v0.3.zip
    Mi sembrano perfettamente identiche, in cosa differiscono?
  6. #15
    Venezia
    S4 & G3
    Quote Originariamente inviato da prato06 Visualizza il messaggio
    BR CameraMOD O2X-E
    Actually. v0.3
    Stock FPS for 1080p
    Few FPS tweaks.
    MP4 as output file.
    Memory boost 50MB.
    BR CameraMOD O2X-EX
    Actually. v0.3
    BR CameraMOD O2X-T
    Actually. v0.3
    Few FPS tweaks.
    MP4 as output file.
    Memory boost 50MB.
    BR CameraMOD O2X-TX
    Actually. v0.3
  7. #16
    Feb 2011
    Questo l'ho visto anche io; scusa non afferro tanto l'inglese, volevo un consiglio del tipo..."meglio questa perché ....".
    Nessuno nasce imparato, se poi devo fare da me....allora é inutile partecipare al forum...e, considerando poi che il topic é recente, pensavo potesse interessare ad altri.
    Inviato dal mio LG-P990 usando Tapatalk
    XTRONS PB86UNVPV
    LG G4 Android 6.0
    MacPro 3.1 2008 Mac OS X 10.10.5
  8. #17
    Venezia
    S4 & G3
    Le due cam sono la tessa cosa, la differenza sono i settaggi. La T la puoi usre tranquillamente ma devi avere overclock e sd 10x (ma anche una buona 6X) per ottenere il massimo. Se usi il cell senza over e sd più lenta, monta la E. Se posso darti un consiglio, prova LGcamera pro (anche free sul market).
  9. Il seguente Utente ha ringraziato redefined per il post:
    prato06 (22-04-12)
  10. #18
    Apr 2011
    HTC One
    Diciamo che con la E il bitrate va da 10 a 30 mbps mentre la T è ulteriormente potenziata (da 15 a 40) e anche il numero dei frames per secondo è stato aumentato (a 1080p) da 24 (della versione E) a 30. Però.. devi avere l'overclock e una SD esterna veloce altrimenti i video risultano scattosi. Inoltre, è buona norma far stabilizzare un po' la camera facendo un po' di video e poi eventualmente cambiarla..
  11. #19
    Venezia
    S4 & G3
    la memoria interna e veloce, potresti avere bisogno di overclockare
  12. #20
    Feb 2011
    Quote Originariamente inviato da redefined Visualizza il messaggio
    Ora é un po piu chiaro
    XTRONS PB86UNVPV
    LG G4 Android 6.0
LinkBacks (?)
