Utente del mese: megthebest con ben 21 Thanks ricevuti nell'ultimo mese
Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 18
[ROM][16/4-11]TK-ROM Vanilla + LG = true. v0.5.6 (Fr12)
    Senior Droid L'avatar di marox
    Oct 2010
    Ringraziato 42 volte in 35 Posts
    [ROM][21/04-2011] TK-ROM v0.5.7 Vanilla + LG = true. v0.5.7 (Fr12)
    riporto di seguito questa bellissima rom che sto provando.
    INGLESE :
    Hi all!
    This is my mixture of the latest MoDaCo Vanilla ROM (Fr11) (Thanks Paul!).
    Ofcourse I don't take any responsibility for your devices... This works with mine, so is should on yours too!
    The only things removed from Paul's ROM are the prebaked apps (which you can get elsewhere if needed).
    Main features:
    -LG Contacts (Dialer with T9)
    -Launcher Pro
    -LG's wifi, sound, bluetooth, GPS and rotate toggles in statusbar
    -Black/white statusbar (seperate download links)
    -LG memo+widget (as I use it myself).
    -SmartShare
    -A custom boot screen (thanks aMpeX)
    -Touch keys notification (Thanks to hikari @swedroid)(have to be enabled inside the app "Optimus 2X Touch LED")
    -Optional overclocking. Set max/min with Pimp my CPU (included) up to 1300MHz. (Thanks Cpasjuste and kholk)!!
    -Multilanguage
    -LG keyboard
    -Battery prosentage
    -IO File manager
    -Flash player
    -ZIP-Aligned
    If you appreciate this ROM and wants to donate, please do so to the right guy which supports a very good cause: Paul!
    To thank me, please press the "thanks"-button
    Changelog:
    v0.5.7 - One version (black), updated LP, PMCPU, added reboot/recovery app, added battery percentage in statusbar.
    v0.5.6 - Removed ComfortAA, but added more fonts options. Reverted to flash 10.1 because of faulty install.
    v0.5.5 - Added OI File Manager, ComfortAA font. Upgraded flash to 10.2, and removed LGlauncher and Launcher2 to lighten up the ROM.
    v0.5.1 - Removed gingerbread keyboard due to bug, two versions black/white. The "smartshare" FC has been fixed also.
    v0.5 - Updated to Fr12, black statusbar, Pimp my CPU 2.2
    v0.4 - Changed OC kernel to kholk's version, updated to Fr11)
    v0.3.1 - Updated OC kernel to "bleeding edge", and Pimp my CPU
    v0.3 - Updated to Fr10 as base
    v0.2 - Updated LED notifications, added statusbar toggles
    v0.1oc - Made one version with OC posibilities
    v0.1 - initial release
    Download TK-ROM v0.5.6 white
    black 0.5.7
    http://xdafiles.net/roms/TK-ROM_v0_5_7.zip
    INSTALLAZIONE :
    1 scaricate il pacchetto zip.
    2 mettete il pacchetto zip in una micro SD esterna
    3 entrate nella clockworkmod recovery di modaco
    4 fate un bel WIPE completo
    5 andate ad installare il pacchetto e fate choose zip file
    6 installate la rom e attendete 2 minuti
    7 finito il processo fate reboot
    Ultima modifica di thay; 01-05-11 alle 12:33
    Terminali android :
    Sony Xperia S <3
    Galaxy note II Titanium Grey
    Oct 2010
    rom fantastica nessun problema
    Terminali android :
    Sony Xperia S <3
    Senior Droid L'avatar di Skizzo89
    Aug 2009
    Provincia di UD
    Ringraziato 113 volte in 39 Posts
    Ho modificato il titolo e aggiornato il post con i nuovi link
    Aug 2010
    Ciao a tutti si sa&lsquo; da qualcuno che l ha provata se e&lsquo; veloce? E il quadrant quanto fa&lsquo;?:-)
    Androidiano L'avatar di riky75
    Jan 2010
    Pisa
    si puo installare anche con il nuovo aggiornamento V10b ?
    Milestone-Desire-X10mini-Galxy S-Desire z-Desire hd-Nexus s-Galaxy tab 7p-Galaxy tab 10.1-Lg dual-SE Arc
    Senior Droid L'avatar di peppemb300
    Sep 2010
    SIRACUSA
    Ringraziato 85 volte in 73 Posts
    Quote Originariamente inviato da riky75 Visualizza il messaggio
    E si date qualche notizia in più per chi la sta provando!!!
    Ultima modifica di peppemb300; 17-04-11 alle 23:43
    Da Peppe
    Samsung Galaxy S3 NoBrand Italia EX Tre!!!
    firmware XXLH1
    ICS 4.0.4
    CF-Root 6.4 con root e CWM
    __________________________________________________ ______________
    Se ti sono stato d' aiuto clicca sul Ditone Giallo (Thanks) per ringraziare.
    A te non costa nulla a me fa piacere
    Oct 2010
    io e' da un po che la sto provando con adw launcher e sono contentissimo della rom, nessun bug o impallamento anzi, prima non potevo installare il sygic perche mi dava un problema nell'attivazione, invece con questa rom si e' risolto il problema.
    adesso sto cercando di mettere anche i comandi vocali offline.
    vi avviso sugli sviluppi futuri
    Terminali android :
    Sony Xperia S <3
  9. #8
    Aug 2010
    Ciao ma di quadrant quanto fa&lsquo;? Grazie mille
  10. #9
    Oct 2010
    aggiornato alla 0.5.7
    punteggio quadrant sui 3000
    Terminali android :
    Sony Xperia S <3
  11. #10
    Androidiano VIP L'avatar di chefare
    Dec 2009
    Torino
    Ringraziato 431 volte in 406 Posts
    Quote Originariamente inviato da marox Visualizza il messaggio
    Beh cmq qualsiasi ROM si utilizzi il punteggio di Quadrant è sempre ottimo ed è poco rilevante, l'uso di ROM alternative a quella stock ha senso secondo me più che altro nell'ottica di migliorare ad esempio la fluidità dell'interfaccia (cosa che non è misurabile con un benchmark), personalizzare e risolvere eventuali problemi.
