[Kernel] Per ROM Stock - CM7/MIUI - CM9
    Super Droid L'avatar di ANDROIDPC
    Mar 2010
    Ringraziato 526 volte in 374 Posts
    In questa pagina saranno riportati i Kernel in auge sviluppati per ROM Stock, CM7/MIUI e CM9 rinviandovi per maggiori specifiche, changelog e download alla pagina corrispondente di XDA.
    Kernel per ROM Stock:
    HorsePower 2x eXtreme 24BPP for stock MCR GB
    *[12-MAR]*[SR3R2][OTF V2.0][KERNEL]HP 2x Xtreme Final SR3R2 for MCR GB - xda-developers
    AdrenalinForce Kernel su base HP SR3R
    (KERNEL-STOCK ROM) AdrenalineForce Kernel based on SR3R sources-Dedicated to KM Spica - xda-developers
    Per discussione su Androidiani:
    https://www.androidiani.com/forum/mo...roms-only.html
    Gueste2X Kernel
    [JUNE 03][KERNEL] guestekrnL-v1.8.1-HighOC | stable, smooth, goodBattery [4 STOCK] - xda-developers
    FPS Kernel
    [KERNEL] fps v0.4 kernel for stock/MCR [2012-02-08] - xda-developers
    Neoblaze
    [kernel][290911] NeoBlaze Kernel for stock/MCR - Now works on Gingerbread - xda-developers
    SwiftExtreme for FROYO
    [Kernel] SwiftExtreme for MCR/Stock - v10e - ABANDON - xda-developers
    Kernel per CM7/MIUI:
    ETaNa OTF-OC-1504MHz (ex Vadonka)
    [CM7/MIUI Kernel][MAY30/JUN05-BETA] ETaNa v3.0.33 OTF-OC-1504MHz - xda-developers
    IronKernel by Setiron
    Changelog e info: https://plus.google.com/110793801028128089370/posts
    Download: https://github.com/SetiroN/lge-kernel-star/downloads
    SwiftExtreme Final
    [MIUI/CM KERNEL] SwiftExtreme-20112011 - FINAL - xda-developers
    Imperticus Kernel 3.0.27
    [Kernel] [GB 3.0.27] Imperticus kernel for CM7/MIUI (Build-1304) UPDATED - xda-developers
    Kernel per CM9:
    (scaricare la versione ICS)
    kernel 3.0.8 ODM/NVRM tegra forward porting:
    [KERNEL][ALPHA] kernel 3.0.8 ODM/NVRM tegra forward porting - xda-developers
    ICS 3.0.32 Harsh Kernel:
    [KERNEL][ICS 3.0.32] Harsh Kernel P990 Build-0306 [IO Tweaked][ZRAM][SNAPPY] - xda-developers
    Kernel Hourse Power ICS by Spica:
    *[April-05]*[RC1-R][CM9-ICS KERNEL] Horse Power 2x eXtreme ICS RC1-R [OTF] - xda-developers
    Nova Kernel basato su Linux 2.0.33
    [KERNEL][ICS][LINUX 3.0.33][JUN05] Nova Kernel v1.0.6 | 1.4GHz | Lightning Speed - xda-developers
    Per maggiori INFO su Kernel e Modding ICS SuperNova vedi anche la discussione di CarloLG:
    https://www.androidiani.com/forum/mo...ily-tweak.html
    Kernel Jarvis v4
    [KERNEL][ICS]JARVIS-v4 for LGP990 - xda-developers
    Ultima modifica di ANDROIDPC; 08-06-12 alle 09:28
    Smartphone: Samsung Galaxy NeXuS i9250
    ROM: Stock JOP40D - JB 4.2.1 Rooted
    Kernel: Stock 3.0.31
  2. I seguenti 5 Utenti hanno ringraziato ANDROIDPC per il post:
    Byteater (25-04-12),MajinJoko (30-04-12),Marco95 (20-03-12),mattia76 (16-04-12),vismo (06-03-12)
    Mar 2010
    Aggiornata la prima pagina con kernel 3.0.8 ODM/NVRM tegra forward porting per CM9/ICS
    ..attualmente è in versione Alpha.
    Rinvio alla discussione su XDA per i Feedback e il download
    PS: Oggi è stato aggiornato anche il GuesteKernel giunto alla versione 1.4.
    Lo trovate sempre nel medesimo link in 1° pagina.
    Ultima modifica di ANDROIDPC; 20-03-12 alle 21:47
  5. #3
    Mar 2010
    Continuano a proliferare Kernel per ICS/CM9!
    Karsh Kernel e HP Kernel (Si, Spica stà lavorando adesso su questo fronte).
    Aggiornati in prima pagina!!!
  6. #4
    Mar 2010
    Aggiornamento al Gueste Kernel 1.5 per ROM Stock!
    Changelog:
    - versions with normal, lite and DS battery driver (credits to their initital creators, I got lite+DS from vadonka's git repo)
    - Android Logging completely disabled in kernel (saving some juice)
    - changes in cpu speed stepping (eye on good battery)
    - enormous and unbelievable increase in smoothness (scrolling,..) while keeping power consumption low at the same time, no trade-offs - achieved through many days and nights of testing; special THX to Horst77 (mod @ handy-faq.de) for his outstanding testing work!!
    - exclusively introducing GuesteOC tool for overclocking and 2nd Core testing; tool mady in mane hours of work by TrymHansen exclusively for guestekrnL (you are my hero, Trym, thank you very much!! ) -- attention, tool won't work with other kernels
    - first and only kernel featuring "liquid-scroll" technology introduced by me for best scrolling smoothness
    - reverted/deleted cherry-picks from SR3 kernel out of 13 files (git is showing 15, I mistakenly altered additional files); it increased the smoothness even more
    - lowered max. ScreenOff frequency to 456 MHz for better power saving - wakeup from sleep is still quick
    - various power consumption tweaks
    - Switched from fb_earlysuspend to console_earlysuspend and thus breaking compatibility with AndrevOC -- but we have GuesteOC now as full replacement -- the screen-off settings are gone as they have no effect because limit of 456 Mhz on screenOff is hard-coded directly in kernel
    - attempt to fix Fast Dormancy bug directly in kernel -- please test on an un-patched ROM, didn't have time for. fd log spamming should eventually be gone -- Edit: not possible to test as I disabled kernel logging will have to test separately!
    - slightly increased low corner voltages for better stability
    - lowered power comsumption during sleep (and use too of course)
    - smallest stock-based kernel (+ smallest kernel modules)
    - additional build flags by spica1234 for better performance
    - removed BLX
    - init.d now working on all ROMs, doesn't matter on which ROM you flash the kernel, even on ROMs with non-working init.d it will work afterwards
    Secondo l'autore dovrebbe aumentare la fluidità del cellulare contenendo sempre il risparmio energetico.
    Da testare.
    Link sempre in prima pagina..
  7. #5
    Mar 2010
    Anche Spica continua i suoi sviluppi del Kernel HP sulla CM9 giunto già alla versione RC1!
    Sempre in prima pagina il LINK!
  8. #6
    Mar 2010
    Nuovo Kernel per Gingerbread CM7 3.0.26 by Imperticus.
    Prime versioni Beta.. ..presentano alcuni BUG sul GPS.
    Aggiorno la 1° pagina!
    Ultima modifica di ANDROIDPC; 03-04-12 alle 14:32
  9. #7
    Mar 2010
    Aggiornamento Kernel ETANA per CM7/MIUI
    ..basato su Kernel 3.0.27 di Imperticus
    Si aggiorna anche Hourse Power per ICS di Spica alla versione RC1-R con le seguenti modifiche:
    +(RC1-R) Fully Optimized for 10% more responsiveness and UI fluidity than all previous HP ics builds (RC1-R)
    +(RC1-R) very quick application opening and multi tasking than all previous HP ics builds (RC1-R)
    +(RC1-R) Low Latency Relatime Processing optimized, Application opening extra smooth than all previous HP ICS builds (RC1-R)
    +(RC1-R) Fully optimized for 2D accelarated UI smoothness and responsvieness(Although in impresence of full GPU accelaration) (RC1-R)
    +(RC1-R) OTF gpu ram hack(Thanks to vadonka) (RC1-R)
    +(RC1-R) Full fixed mobile data usage limit ( Thanks to harsh bhaila) (RC1-R)
    +(RC1-R) Fully KSM(Kernel Samepage Merging) compatible (RC1-R)
    +(RC1-R) hybrid tool chain compilation. Modules seperately compiled with gcc-4.5 for more run time stability, while seperately kernel compilation with gcc-4.7(seems stable than 4.6) (RC1-R)
    +(RC1-R) More Robust charging BSOD prevention than all previous HP ics builds (RC1-R)
    +(RC1-R) More freeze free than all previous HP ics builds (RC1-R)
    +(RC1-R) OpenGL and ELS optimized by GCC Flags(smoother game play) (RC1-R)
    +(RC1-R) OTF application now saving values after re-opening (RC1-R)
    +(RC1-R) 20% more battery life rather than previous hp builds (RC1-R)
    +(RC1-R) More ROBUST memory management after days constant usage (RC1-R)
    +(RC1-R) More CrystalClear voice definition(16Bits/96KHz) during media playback and optimized InCall volume frequency(RC1-R)
    +(RC1-R) Fully overall optimization to feel not the impresence of GPU accelaration (RC1-R)
    +(RC1-R) Multi-Thread Thumb-2 GCC optimizations for cortex-a9 multi-core performance (RC1-R)
    +(RC1-R) Fully GCC ARM Graphite code implementation for faster loop unrolling and faster do -go to- kernel codes access (RC1-R)
    ..aggiornata la 1° pagina..
  10. #8
    Mar 2010
    Nuovi aggiornamenti Kernel:
    Per ICS
    Karsh Kernel ICS 3.0.28
    Kernel SuperNova RC4 by hei1125
    Per CM7
    Etana 3.0
    Per ROM Stock
    GuesteKernel 1.6.1
    Aggiornate in prima pagina le diciture, tenendo fede che in ogni modo quando viene aggiornato un Kernel automaticamente venite reidirizzati al link della nuova versione su XDA.
    Rinvio sempre a XDA per changelog e download.
    Ultima modifica di ANDROIDPC; 21-04-12 alle 09:09
  11. #9
    Mar 2010
    AGGIORNATO IN PRIMA PAGINA:
    Per ROM Stock
    1) AdrenalineForce Kernel based on SR3R
    Per ROM CM7/MIUI:
    1) Etana Kernel
    Per ROM CM9:
    1) Harsk Kernel
    2) Nova Kernel
    3) Jarvis Kernel
  12. Il seguente Utente ha ringraziato ANDROIDPC per il post:
    sreeprajay (08-06-12)
