Utente del mese: megthebest con ben 44 Thanks ricevuti nell'ultimo mese
[MOD][CAM] 1920x1088@30fps@20mbps + auto-focus on CM7
    Senior Droid L'avatar di marox
    Oct 2010
    Ringraziato 42 volte in 35 Posts
    [MOD][CAM] 1920x1088@30fps@20mbps + auto-focus on CM7 - xda-developers
    --------------FullHDmod 1.1-prealpha---------------
    Just adds auto focus (and 25/30fps if you're on nightly), no change to bitrate.
    --------------FullHDmod 1.0---------------
    ->Video:
    HD: 1920x1088@30fps@20mbps
    High: 1280x720@30fps@12mbps
    --------------FullHDmod_high 1.0---------- (works for some, requires fast sd card)
    ->Video:
    HD: 1920x1088@30fps@26mbps
    --------------FullHDmod_mid 1.0---------- (Recommended)
    ->Video:
    HD: 1920x1088@30fps@17mbps
    --------------FullHDmod_low 1.0----------
    ->Video:
    HD: 1920x1088@30fps@14mbps
    --------------FullHDmod_LG 1.0----------
    ->Video:
    HD: 1920x1088@30fps@9mbps
    High: 1280x720@30fps@4mbps
    ----------BitrateMod(720p only)---------- (Does not replace Camera.apk. Works for 64mb ram hack, until we find other solution)
    ->Video:
    HD: 1280x720@30fps@20mbps
    High: 1280x720@30fps@10mbps
    All audio is 128 kbps and all stills are:
    Super fine: 100
    Fine: 90
    Normal: 80
    --------------------------------CHANGELOG----------------------------------------
    1.0 Initial release.
    ---- Small bugfix of CM7s camera app + tegra 2 specific stuff.
    1.1-pre-alpha
    ---- Enables autofocus prior to video capture. Cannot be turned off(I don't do UIs,lol). Need to restart app for each video.
    ---------------------------------------TODO----------------------------------------
    Touch to focus.
    Continues auto-focus.
    interessante ! cosi anche per la cyano possiamo usare la camera mod
    Terminali android :
    Sony Xperia S <3
    Galaxy note II Titanium Grey
    ah le cam mod non funzionano indifferentemente dalla rom che si ha?
    in caso negativo, le hanno fatte per tutte le rom (originale compresa) o per qualche rom non hai i video a 30fps alto bitrate?
    Oct 2010
    da quel che ho capito si hanno due versioni.
    1 per froyo 2.2
    2 per gingerbread 2.3
    quindi tutte le rom tranne la cyano utilizzano la prima cam mod 2.2
    Terminali android :
    Sony Xperia S <3
    ah ho capito... dici che è così? sarebbe ottimo, tutte le rom possono usufruirne.
    confermate?
    Apr 2010
    Ringraziato 33 volte in 15 Posts
    Io non ho capito una cosa..
    attualmente sto utilizzando una Cyanogen mod v0.41... devo applicare la modifica della cam?
    se si, quale ??
    Samsung Galaxy Note N7000
    Stock Rom xxxLB1
    Come installare una ROM su Milestone? Segui la mia guida QUI
    Come installare una ROM su Ideos? Segui la mia guida QUI
    Per tutti colore che usano l'IPHONE e dicono che è meglio degli Android... Siete dei 2.2!!!
    Apr 2010
    scaricate Autofocus e set cam MID, ma nessuna miglioria.
    Stock Rom xxxLB1
