Pagina 37 di 61 primaprima ... 27353637383947 ... ultimoultimo
Visualizzazione dei risultati da 361 a 370 su 602
Anteprima MIUI ROM LG optimus 2X
  1. #361
    May 2009
    Quote Originariamente inviato da Sknoke Visualizza il messaggio
    perfetto! ora aggancia il gps velocemente. grazie
    figurati... io mi sa che tornerò alla stock per ora, troppo instabile questa miui, ora mai aspetto il rilascio di domani... speriamo che LG rilasci presto 2.3.3 altrimenti com l ho preso lo rivendo...
    Super Droid L'avatar di ANDROIDPC
    Mar 2010
    Ringraziato 526 volte in 374 Posts
    MIUI 1.9.16
    Recommended updates this week:
    1. Defy, HD2, DHD and Desire Z replaced with new kernel
    2. MI-Button support for Lock / Wake screen shortcut
    3. Download Manager support for SD card status free download of Themes, Music, Apps and other documents.
    Read on for full list of updates…
    System:
    New account registration system (Added Nickname / handle support)
    HD2 R12 Kernel update
    DHD replaced with new Kernel optimisations
    DesireZ replaced with new Kernel optimisations
    Defy replaced with new Kernel optimisations, optimisation of SD card and Wi-Fi driver
    Optimisation of system updates and music when no SD card is present, more unified style
    Lock / Wake shortcut added for MI-Button
    Optimisation of clearing user data / clear all data (Factory defaults)
    Fix issue with Gmail settings, selecting some items leads to FC
    Fix rating stars display problem for Market
    Phone:
    Adding call fails logging to call log
    Optimisation of database
    Fix lockscreen phone notification interface does not display missed call information
    Fix USSD / MMI interface leads to unable to call issues
    Fix pick up quieten ringer and flip to silence triggering incorrectly
    Fix problem with Bluetooth device unable to answer first call when paired problem
    Fix pop-up to answer incoming call problems when selecting headset devices
    Fix call volume problems with HD2
    Messaging:
    Fix can’t send text messages to contact number with +86 (Overseas service)
    Contacts:
    Optimisation of import contacts to MIUI guide
    Fix problem where contacts showed incorrect MiTalk account details for contacts
    Fix abnormal issue with read-only contacts leading to FC
    Themes:
    Fix download theme without SD card, insert SD card cannot mount for migration of data problem
    Fix replacement system notification sounds, the sound using the system to alert the application is not updated with new notification sound
    Fix in some cases the “Current” ringtone label recurring problem
    Camera:
    Optimisation of camera shake detection time (Less than 5 seconds)
    Open camera settings menu optimisation, if the shutter button takes pictures using hardware key the panel will disappear
    Use of volume keys to optimise camera sounds has no effect
    Fix Auto Focus issue and anti-shake causes camera to not respond leading to system restart
    Fix issue switching to front facing camera duplicating “effect” when switching
    Backup:
    New interface for Cloud backup results and details
    Fix removal of local copy of application during off-screen lead-free response questions
    Fix inconsistency in Cloud backup progress indicator
    Superuser:
    Pop up optimisation tips / reminders for Root privileges
    File Explorer:
    Optimised remote FTP management, fixes for notifications as well.
    Compass:
    Beginner guide tips added
    E-mail:
    E-mail interface optimisation, new compose, and search message body interface
    Settings:
    Optimisation for Headset, Bluetooth headset default volume settings
    Download manager:
    Fix download large number of files / batch operations (pause / open) causes application to not respond
    Smartphone: Samsung Galaxy NeXuS i9250
    ROM: Stock JOP40D - JB 4.2.1 Rooted
    Kernel: Stock 3.0.31
  4. #363
    May 2009
    a me su MIUI rom downloader non me la da....
  5. #364
    Mar 2010
    Quote Originariamente inviato da tobyax Visualizza il messaggio
    Da qui si riesce a scaricare la ROM:
    MIUI, Redefining Android – MIUI Android Developers
    ..ovviamente dovrebbe essere in cinese o al massimo in inglese.
    Domani dovrebbero essere postate le traduzioni ITA.
    Comunque per il nostro DUAL non vedo grandi novità..
  6. #365
    Boscagoo
    mhhh...salve a tutti! Ho installato da poco la miui 1.9.9...solo che non trovo il "menù" con tutti i programmi installati...è normale o devo abilitare qualcosa?
  7. #366
    Jan 2011
    Quote Originariamente inviato da Boscagoo Visualizza il messaggio
    É normale.. la miui funziona così, non c'è nessun menù tutte le app sono nella home..
    Inviato dal mio Optimus 2X usando Tapatalk
  8. #367
    Mar 2010
    Quote Originariamente inviato da Lapidus Visualizza il messaggio
    Si infatti è proprio il LAUNCHER di Base che mette TUTTE le icone nelle schermate! Molti utenti, compreso il sottoscritto, non lo gradiscono tanto..
    Comunque puoi usare sempre dei Launcher alternativi scaricabili dal Market come GO LAUNCHER EX ma perderesti - purtroppo - la possibilità di mettere i widget della MIUI ed una serie di funzionalità tipiche della interfaccia MIUI..
  9. #368
    Qualcuno sa dirmi perche non vedo i contatti sulla scheda sim !!!!!
  10. #369
    Venezia
    S4 & G3
    la versione lg sarà la 2.3.4
  11. #370
    Mar 2010
    napolii
    Ringraziato 19 volte in 14 Posts
    Raga per chi ha installato la nuova miui posto questo zip creato da me va flashato da recovery contiene il kernel di roadrunner che fixa il mount delle memorie quando colleghiamo il cell al pc e lo si usa come memoria di massa , in più c'è un file gps che migliora il fix e la vista dei satelliti
    DOWNLOAD
