2 allegato(i)
[ROM] Nessy #Hypnos (Froyo 2.2.2) | UPDATED 06 Maggio 2011
Ciao a tutti! Ho cucinato questa custom rom basata su Froyo 2.2.2 e mi piace un sacco! (: Spero vivamente che questa rom vi piacerà!
"Nessy" è il nome della mia musa e ciò che viene dopo "#" è il nome di un personaggio della mitologia greca
FEATURES:
- Android 2.2.2 (based on v10H EU)
- DookMatt kernel with new optimized OC (not drellisdee OC but new OC Optimized) (thank to mik_os for his patience) (BFQ I/O Scheduler) (smartass governor) {touch bug resolved by LG}
- Root + superuser + busybox
- Deodex & Zipalign apks
- HW acceleration enabled + JIT enabled
- BFQ I/O Scheduler
- StageFright disabled
+: Boost quadrant values, good for comparison purposes (no increase in performance)
-: Media playback problems - Heap size = 32MB
- Froyo AOSP 2.2.2 Launcher
- If you want to set "smartass" governor use setcpu, i prefer use smartass for high performance and low low low battery drain! ;)
- Custom boot animation
- Blink
- Original Froyo framework (except default wallpaper) and keyboard
- Removed more applications for more speed and free space
- File Manager
- Custom cpuclock script
- Original Hosts file
- Support for ext4 partition
- Build.prop hacks
- [K]Updated wireless.ko module
- [K]Updated yaff2s
- [K]Updated msm_sdcc
- [K]Updated KGSL driver (3D)
CHANGELOG #BRISEIDE (8 MARCH 2011):
- Remove ADW Launcher
- Add Zeam launcher
- Add custom Zeam preferences
- Set my favorite wallpaper by default
- Remove more System app for a speedy boot
- Sippolo kernel
CHANGELOG #CASSANDRA (10 MARCH 2011):
- Removed Zeam Launcher
- Add Launcher PRO
- Resolved first boot crash
CHANGELOG #DAFNE (16 MARCH 2011):
- Mik_os kernel from "CM7 Beta 2" {Need to be tested}
- CPU automatically set 245/768/ondemand {Need to be tested}
- New boot animation
- Original hosts file (many apps check this file)
- Blink and Market apps updated
CHANGELOG #EURIDICE (17 MARCH 2011):
- Mik_os kernel v1.1 (for more stability)
- CPU automatically set 245/729.6/ondemand
- Returned with old boot animation
- Apn list updated from CM7
- More, more little bugs fix (Example: black wallpaper in lockscreen)
- Added various tweaks
CHANGELOG #FENICE (27 MARCH 2011):
- New DookMatt Kernel (based on 2.2.2 kernel) (not drellisdee OC but new OC Optimized) (touch bug is resolved by LG)
- Support for VPN and btrfs partition (btrfs is experimental)
- Added various tweaks from HERE
- Changed default wallpaper
- Update some apps
Nei miei test, #Fenice ha un bassissimo consumo di batteria! Da stamattina (100%) ho tirato le 21.19 e ora sono a 71%! (:
CHANGELOG #GAIA (4 MAY 2011):
- New DookMatt Kernel (based on 2.2.2 kernel) (not drellisdee OC but new OC Optimized) (touch bug is resolved by LG) (BFQ I/O Scheduler) (smartass governor)
- Froyo AOSP Launcher
- Removed various tweaks from HERE
- Updated some apps
- Added some apps
- 245/729 MHz smartass DEFAULT
- Based on V10H EuroOpen
- Removed a2sd
- BFQ I/O Scheduler
CHANGELOG #HYPNOS (6 MAY 2011):
- Resolved smartass bug
- Optimized smartass governor
- Updated Froyo AOSP Launcher to 2.2.2 from 2.2.1
- Build.prop hacks
- [K]Updated yaff2s
- Resolved some bugs
DOWNLOAD: Nessy #Hypnos {Size: 77.7MB} (:
PS: Io non sono responsabile ad eventuali danni causati da questa ROM.
PPS: Se volete offrirmi una RedBull, cliccate su "Donate to me" (:
NB: Preferisco installare le varie applicazioni di default dal market perchè permettono un avvio più veloce del sistema (si saltano svariati check)
SCREENSHOTS:
