Pagina 5 di 13 primaprima ... 34567 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 129
CM10 Android 4.1.2 versione unificata Defy/Defy+
  1. #41
    Androidiano L'avatar di pashadiablo
    Bari
    LG Nexus 5
    grazie mille, sei stato chiarissimo
    LG Nexus 5
    ROM: PA
    Samsung Galaxy Note 10.1
    ROM: Stock 4.1.2 + Root
    Bari
    LG Nexus 5
    edit, ho sbagliato a postare, cancellate pure
    Ultima modifica di pashadiablo; 06-11-12 alle 19:50
    LG Nexus 5
    ROM: PA
  4. #43
    Androidiano L'avatar di sdylan
    Feb 2010
    Domanda......mai il tethering funziona con questa versione ???
  5. #44
    Ringraziato 33 volte in 30 Posts
    Sì, da un po' ...
    Status:
    12.07: Boot up
    14.07: Phone, Mobile Data, USB, Mass storage, Sensors, Camera(Photo), GPS/AGPS.
    18.07: Audio (thanks to maniac103), Video rec/play, Panorama, FM-Radio.
    19.07: Install app to sdcard, mp3 codec, video codec fixes, rework fm-radio, cyan update.
    22.07: Usb fixes, USB Tethering, Data Usage, Preferred Network (umts/cdma) selection, CrystalTalk
    23.07: Fix audio lock-ups (thanks to nadlabak), a2dp, fix volume change, OS FMRadio and fm volume change in background by maniac103, leds
    26.07: Themes, button backlight, fix lag bootanimation, imei/mac... cyanogen updates.
    28.07: re-fix button backlight, holo fm-radio, Option for enable/disable On-Screen Button(36dp)
    04.08: Fix volume rocker music controls, Realtime switch of OnScreenButtons and size of it, Phone/SMS apps now in memory all the time, Enable CPU TLS Register, Auto-Backlight Settings, Boosted governor by default... maybe forgot some more..
    08.08: Improved stablity of camera (bayer have problem with sound), DroidSSHD, Trebuchet, common stablity fixes.
    10.08: update Moto RIL to v4, fm-radio to lockscreen, hwui blacklist on mb525, fix realtime OnScreenButtons, Fix MotoPortal, Disable get local ipv6 adress.
    12.08: Auto-backup battd, Port phone features from cm9, Add national data roaming and make it optional (from AOKP).
    22.08: Fix ability change brightness of buttons(Defyparts), compass fix, Apollo intent fix (which fixes last.fm etc), dalvik heap 128mb -> 48mb, wifi changes
    25.08: Disable lock in memory Phone and sms apps(by users requests), fix OnScreenButtons, ipv6 tweaks.
    28.08: Fix 00:00:00:00:00:00 SSID in apps, fix audio routing in dock modes
    03.09: Fix Audio in video rec(not ideal) and decrease fps in preview camera (not in video), 2Channels for audio, DSP-Manager in software which support JB (ex, apollo) it's not a bug, support multiboot, wifi-tethering (thanks ot devs of ml2, maybe have bugs, not tested)
    04.09: Fix compass, update sgx libs to JB, fix wallpapers, improve video perfomance, new touch driver (for test, only 2 fingers for now, more will be enabled in next build).
    12.09: Fixed touch driver (allow touches upto 10), Fix for data connection, thanks to SlugZero, also some more fixes for stability ril, disable fps limit in preview.
    24.09: Video rec fixes, add 720p rec (not by default, unstable),cyanogen updates.
    2ndboot builds: one build for mb525&526
    10.10 Android 4.1.2, CRT-Animation , custom kernel, experimental. Included patch for flashlght(not tested, but shouldn't burn it)
    11.10 Fix red camera, updated 2ndboot.ko, fix pds mount and permissions.
    18.10 Kernel update:fix wifi tether(reboot), reduce battery drain, fix charge only mode, cleanup unused drivers, fix button lights, fix slow boot and lags after boot.
    02.11 Add power hal, interactive governor+bootpulse(should be default in bootemnu for correct work power hal),kernel fixes from upstream, cleanup/disable unused drivers, fix SGX clocks, add bp_ptc service(only service), fix battery drain, add fuse rw-ntfs/extfat fs support(not tested, but should work), fix backlight settings, fix small problem with fm-radio on notfication drawer, add cm file manager(can work incorrect), restore live wallpapers, cm sync....
    Moto Defy MB525 lente verde Quarx's CM11 KK 4.4.4
  6. #45
    Feb 2010
    Quote Originariamente inviato da AlkaSeltzerPLUS Visualizza il messaggio
    Sì, da un po' ...
    Grazie, allora installo subito.........
  7. #46
    Feb 2010
    Perfetto, installata e perfettamente funzionante.
    Ma chiedo solo una cosa......come mai ogni tanto in tethering il telefono perde la connessione, nel senso che la connessione diventa grigia il che dovrebbe significare che la connessione non c'è, devo riavviare il telefono e poi ridiventa blu e quindi funziona di nuovo.
  8. #47
    Prova a vedere tra le impostazioni " reti mobili ... " se hai la spunta su " solo gsm "
  9. #48
    Napoli
    ma oggi è uscita un'altra relase???
  10. #49
    Succede solo a me che quando navigo con il 3g la batteria si scarica molto velocemente mentre se lo utlizzo a stessa maniera ma in 2g la batteria dura moooolto più a lungo.
  11. #50
    A me succede la stessa cosa,anzi a volte non si collega neppure a internet col browser.
    Io per riprendere la linea sconnetto e riconnetto il segnale wifi e faccio lo switch 2g/3g.
