Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 18
[ROM][KitKat][4.4.x] CyanogenMod 11 [UNOFFICIAL]
    Senior Droid L'avatar di vocoderism
    Sep 2013
    Ringraziato 140 volte in 97 Posts
    Cool
    CM11.0 Unofficial (KitKat) 4.4.2 builds for the Motorola MOTO G (Unstable Developer preview)
    Kernel 3.4.75 OC /configure in performance menu after developer options enabled)
    Hi all
    here is first compilation of cm11 unofficial for Motorola Moto G (falcon_umts) v.3 27.12.2013
    It Boots!!!!
    Prerequisite
    Unlocked bootloader(follow guide on motorola site)
    Twrp 2.6.3.0 or CWM 6.0.4.5 (follow guides on associated xda threads for moto G)
    Rom Download link v3
    https://mega.co.nz/#!rp4UATZS!zLy9kG...-WARhfUDIsHCko
    Gapps Download Link(art supported)
    https://www.androidfilehost.com/?fid=23269279319196266
    V3 ChangeLog
    Fix gallery crash for error unable to find external storage
    Fix msm8226 Audio now speaker and headset work fine
    Fix screenshot now work fine
    Fix audio recording.now you can save and listen it with your favourite player
    What's not working:
    Probably most everything else, including, but not limited to:
    Ril
    Wifi
    Bluetooth
    Camera
    ART, as it is still in heavy development upstream (same as for all other 4.4-Roms) !!!experimental!!!!
    Some other bugs that you'll find
    What's working:
    All other things not listed in "What's not working:"
    Credits
    Thanks to
    Immortayash for device tree
    https://github.com/immortalyash
    razrqcom-dev-team for kernel and custom media-msm8226
    https://github.com/razrqcom-dev-team...torola_msm8226
    https://github.com/razrqcom-dev-team..._media-msm8226
    xplodwild for Packager App Focal
    https://github.com/xplodwild/android...ges_apps_Focal
    CyanogenMod Team for complete cm-11.0 complete sources
    https://github.com/CyanogenMod/android/tree/cm-11.0
    Christopher83 xda for some compilation fixes
    xda-developers - View Profile: Christopher83
    Installation for TWRP
    Wipe (swype to wipe dalvik cache and factory reset)
    Install rom from Install tab
    Install gapps from Install Tab
    reboot Tab ---->>>> reboot System
    Installation for CWM
    Wipe cachet
    Data Factory reset
    Format System (menu mount ad storage)
    Wipe dalvik(menu advanced)
    Install zip from sdcard
    fisr install rom and then gapps
    Reboot System now
    Have a fun witk KitKat
    Ultima modifica di vocoderism; 01-01-14 alle 22:10
  2. Il seguente Utente ha ringraziato vocoderism per il post:
    simona70 (25-12-13)
    Sep 2013
    qualcuno testa?
    thx
    Ultima modifica di vocoderism; 01-01-14 alle 22:06
  5. #3
    Ringraziato 58 volte in 52 Posts
    Ragazzi volevo porre una domanda. Ho provato a informarmi ma non ho trovato nulla a riguardo. Sto provando la cyano 11 unofficial trovata su xda e devo dire che mi trovo molto bene , come la stock la rom è performante e almeno per il momento non ho riscontrato bugs. La mia domanda è questa , ma il nostro terminale non dovrebbe ricevere il supporto ufficiale della cyanogenmod ?? oh ho capito male ??
    cmq la cyano unofficial la trovate qui
    [Rom] [4.4.2] Cyanogenmod 11 Unofficial for Moto G - xda-developers
  6. #4
    Androidiano VIP L'avatar di Salvoza
    Campobello di Licata
    motorola moto g
    Ringraziato 91 volte in 86 Posts
    Ma tu seriamente hai messo la cm11 e ti trovi bene? Nessun bug? Batteria e prestazioni uguali alla stock?
    PREMI IL TASTO THANKS SE TI SONO STATO D'AIUTO
  7. #5
    Quote Originariamente inviato da Salvoza Visualizza il messaggio
    Allora la stock va un po' meglio ! La cyano cmq è molto preformante , la betteria mi sembra duri un po meno ,per quanto riguarda i bugs,per adesso non ancora mi ha dato problemi di alcun genere a parte il led che non funzionava ma è stato risolto con l ultimo rilscio. Cmq la sto utilizzando da un gg quindi non ho potuto testare molte cose come il navigatore e molte altre cose.
    Cmq tutto sommato mi ci trovo bene e la comodità della personalizzazione gli da quel quid in più che mi piace. Mi sembra di aver letto cmq che a breve dovrebbe essere rilasciata una versione ufficiale della cyano per il nostro moto g ma non ho trovato conferme e volevo sapere se qualcuno aveva saputo qualcosa.
    su antutu la stock mi dava un punteggio di 18000(ma non ricordo beene il valore forse era anche maggiore) e la cyano 17000.
  8. #6
    Androidiano VIP L'avatar di Sammy854
    Moto G (2014), Asus ZenFone 2
    Ringraziato 876 volte in 688 Posts
    Il moto g sarà ufficialmente supportato dalla cyano?
    iPad Air: iOS 9.x beta
    Motorola Moto G (2014) ROM: Stock (LL 5.1.1)
    Asus ZenFone 2 32GB
    My projects:
    HydrogenROM - S Advance
    JellyKit - S Advance
    SlimBean - S Advance
    CM PURITY KK/LL - Moto G 2013/2014
    Euphoria-OS - Moto G 2014
    Dirty Unicorns - Moto G 2014
  9. #7
    Sep 2013
    Per ora no cmq ho compilato una Paranoid per moto G
    Thread
    http://forum.xda-developers.com/show....php?t=2614690
  10. #8
    Quote Originariamente inviato da vocoderism Visualizza il messaggio
    Per ora... Quindi più avanti suppongo di sì! Sennò farei solo un buco nell'acqua
    Asus ZenFone 2 32GB
    My projects:
  11. #9
    Sep 2013
    Quote Originariamente inviato da Sammy854 Visualizza il messaggio
    Sicuramente.dhacker29 ha fatto la cm11 io la paranoid e la fix per la twrp segui il thread inviato
  12. #10
    Sassari
    LG G2, LeMax 2
    Ma WiFi, Bluetooth e fotocamera non funzionano?
    Smartphone:
