Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[ROM][5.1.1_r18][OFFICIAL][NIGHTLY] Android Ice Cold Project 10.0
    Androidiano VIP L'avatar di RolanDroid
    Motorola moto g 2014 lte
    Ringraziato 239 volte in 203 Posts
    AICP
    AICP is known by everyone as Ice Cold Project that started on Desire HD and since then evolved into a mature ROM with the BEST community you can find!!!
    Until Lollipop, Rom has always been AOKP based. Unfortunately, since AOKP either stopped development or will make a comeback later this year, we changed our base to CM when it comes to hardware, drivers and some features.
    If there are any bugs, either we will sort them or CM team if it concerns their modifications. This rom isn't CM supported so no need to report errors or bugs to them!!
    Features:
    • 10.0 Stable Features:
    • Sources updated to 5.1.1_r18
    • SlimPIE
    • Slim Recents
    • Floating Windows
    • Breathing notifications
    • Dynamic tiles
    • Music tile
    • Return of Silent mode
    • Force Expanded Notifications
    • Signal cluster updates
    • Statusbarheader items: CAF TaskManager, HeadsUp, PowerMenu
    • RestartSystemUI to dev settings, as Tile, as part of Reboot menu
    • Ambient Display brightness setting
    • Call recording format
    • Notification Ticker is back
    • App Sidebar
    • Over Scroll Effects
    • Snooze option to HEADSUP
    • Torch to PowerMenu
    • TaskManager, HeadsUp and PowerMenu on Notification Drawer
    • AICP_OTA fixes and improvements
    • Smart Mute. Flip phone to mute
    • Smart Call
    • Proximity Speaker. Speakerphone starts automatically whey you remove phone away from your ear.
    • Clear All Icon color added to Custom Colors
    • Battery Light: 100% Charged Level
    • Gesture Lockscreen
    • Reorder items under Notification Drawer settings
    • Storage notification enhancements. Now we have Mount/Unmount in statusbar.
    • Battery saver color selection is back
    • Linked volume implementation changed
    • Membar added to recents options
    • LS Shortcuts increased from 5 to 7
    • InCallUI fixes and enhancements
    • Whole bunch of fixes and enhancements for all included packages
    • Selinux Switch
    In the beginning we would like to thank:
    • CM team
    • maxwen
    • SlimBean rom team
    • CarbonRom team
    • LiquidSmooth rom team
    • Omni rom team
    • DU team
    • Community
    • @LorD ClockaN
    • @zipsnet
    • @n3ocort3x
    • @semdoc
    • @eyosen
    • @alienmind
    • @Chezbel
    • @Drgravy
    • @eboye
    We are now paying for servers that build nightlies and everything that comes with it, so EVERY DONATION will really be appreciated and be used to cover those expenses.
    Thank you!!
    Latest Stable Release Version 10.0
    Download
    Full Changelog link: Complete change log by the download link
    • Nothing
    • Tell me
    ROMS should contain everything you need to enjoy Lollipop. You are not required to install any Add Ons, simply download the latest ROM, gapps, flash it, and go!
    You are STRONGLY recommended to fully wipe your device before flashing, and if possible avoid restoring system apps and system data with Titanium Backup - these can cause stability issues that are very hard to debug. If you believe you know what you're doing - then fine, go ahead, but please don't complain if you experience strange behavior.
    How to flash:
    • Don't do it if you don't know it
    • ROM has gapps persistance in between dirty flashes
    KERNEL:
    Kernel in this rom follows CM source with custom additions.
    PREREQUISITE FOR OTA:
    To be able to flash over OTA app, TWRP recovery is needed.
    You can still use CWM and OTA app, but only to download zip file and flash it manually from within recovery. Zip gets saved under AICP_ota folder on your internal SDcard.
    If you want to contribute to the AICP or wanna see what is being worked on/merge feel free to visit our gerrit, link is at the bottom!!!
    IceColdJelly AICP G+ community
    rom gerrit
    You want to see a normal night at the DEV office, click here!!
    XDA:DevDB Information
    [ROM][5.1.1_r18][OFFICIAL][NIGHTLY] Android Ice Cold Project 10.0, ROM for the Moto G 2014 LTE
    Contributors
    RolanDroid
    Source Code: https://github.com/AICP
    Thanks to:
    • Team AICP
    • Motorola
    • LuK1337
    • Luca020400
    È normale che il tasto home e multi tasking non funzionino, come anche lo schermo che si spegne solamente e non si blocca?
    Inviato dal mio Moto G 2014 LTE usando Androidiani App
    Quote Originariamente inviato da Maxxxx Visualizza il messaggio
    Non so cosa tu abbia fatto
    Fai un FULL wipe e reinstalla SOLO la rom più le gapps
    E le gaps dove le trovo?
    O meglio mi servono proprio?
    Per ora mi basta che funga la ROM
    e cosa intendi per un full wipe, cioè cosa comprende?
    Non mi sta per niente piacendo sta rom, e tanto meno il supporto, senza offesa eh
    Ultima modifica di solocchi; 26-09-15 alle 19:23
    Moderatore L'avatar di solocchi
    Pixel 9 Pro XL
    Ringraziato 982 volte in 793 Posts
    Evitiamo post consecutivi editando i precedenti grazie.
  9. #8
    era per attirare l'attenzione
  10. #9
    Pixel 9 Pro XL
    Lo immaginavo ma per regolamento lo puoi fare solo dopo 24 ore.
  11. #10
    Se non ti piace la rom vai ad un altra parte e dal regolamento google dovrebbe essere tuo amico.
