Pagina 4 di 5 primaprima ... 2345 ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 41
[ROM] [OSPREY] [ANDROID 6.X] Resurrection Remix
  1. #31
    Androidiano L'avatar di seth
    Ringraziato 21 volte in 21 Posts
    bene, grazie delle info
  2. Il seguente Utente ha ringraziato seth per il post:
    Stefa99 (10-04-16)
    May 2015
    Torino
    GT-I9070, Osprey, Kenzo
    Ringraziato 194 volte in 155 Posts
    Nuovo update: https://www.androidfilehost.com/?fid=24531172553916722
    Inviato dal mio Moto G 2015 (Stock 6.0.1)
    XiaoMi RedMi Note 3 pro 3/32
    ROM -> MiUI 9.1 Xiaomi EU
    Kernel -> stock
  5. #33
    May 2015
    Torino
    ResurrectionRemix #Marshmallow v5.6.9
    The Changelog
    Android 6.0.1_r30-> r43
    Introducing Resurrection Remix Rom stats thanks to +Akhil Narang​​​​​​​​
    SysUI:Custom Recents Style Taskviewheader colors
    Option to Hide carrier label based on notitication icons
    FWB: Carrier label font style
    Carrier Label Fonts Style
    Battery bar enhancements
    ActivityManager: fix perf boost NPE
    Qs: Add Audio Fx Visualizer Tile
    SystemUI : Re-order left statusbar icon layouts and paddings
    Custom Headers : Add new material design colorful headers
    batteryservice: Add support for segmented power LEDs
    QSPanel: Fix Reported SystemUI FC on Themes Tile
    SystemUI: avoid lock screen shortcut picker crash
    SysUI: Show keyguard when LLS dies and had focus
    pms: Skip reinstall of prebundles correctly per user.
    systemui: Fix the TrustDrawable animation state
    SystemUI: bail out of recents-to-home animation when losing focus
    Lockscreen : Bunch-o-fixes
    Themes: Expose manifest styles for framework activities
    Add new options for call waiting response in InCallUI
    SysUI: Make sure LLS focus is false when unlocking
    perf: Send the process name and pid for launch boosts
    am: Remove extraneous boostage
    batteryservice: Use Alpha channel for segmented LED power level
    ThemeTile: tighten up how we execute a theme change
    CmRes: Attach themed cmsdk resources to assets
    SystemUI: attach a queue to media player notifications
    SystemUI: fix play queue crash
    am: Don't protect apps that atttempt to grant uri perms
    SystemUI: fix potential NPE with Queue
    only use proximity checks on wakeup keys
    SysUI: Use VectorDrawable's for rendering battery
    Fix SystemUI FC on Media Notification Queue
    bootanimation: fix check for system bootanimation
    MediaScanner: Add support for default ringtones per sim
    Fix incorrect behavior for statusbar and quicksettings panel
    QS: fix performance profile tile observer
    SystemUI : Fix multi-user for keyguard
    SystemUI: Set circle battery path as untranslatable
    Update volume slider only if ringer mode changed
    SystemUITests: fix compile error
    Lockscreen : Disable left edge after showing keyguard
    Keyguard: Allow swiping up when trust managed
    SpamFilter : Hide option if notification cannot be filtered
    FWB: Move Pulse Configs to Secure
    LS:Fix Weather Panel Not hiding With Max Notif
    Acquire wakelock until dream service acknowledges dream state change
    Lockscreen : Only animate targets if launched via swipe
    Ensure camera is launched if doing screen off gesture
    Keyguard : Ensure we expand onIconClicked
    WindowManagerService : Ensure we update both size/position
    Fix Battery Icon Tint on Keyguard
    SysUI:Update a Custom Logo
    SysUI:Update some quick tile icons
    Speed up notification panel pulldown animation when called externally
    Lls: Use LlsController for checking LLS focus
    LLS: Don't change bar state when changing LLS focus
    LLS: Ensure LLS loses focus when showing bouncer
    ShutdownThread: Decrypt before stopping storage manager
    VisualizerTile: Use proper Techniques to unlink with Pulse
    Release alarm wakelock for blocked uid.
    SyncManager: Adjust sync remaining time calculation.
    Themes: Fix theming of cmsdk assets
    Fix isComponentProtected calls in package manager tests
    MSIM: Fix to resolve SIM PIN unlock in APM.
    SystemUI: Check current data subscription when updating signal cluster
    SysUI: Adjust battery dimensions for better look
    am: Handle unchecked activity starts for protected components.
    SysUI: Check swiping progress before collapsing KBA
    SystemUI : Fix left swipe when dismissing bouncer
    usb: ensure accessory detached sent on re-attach
    SysUI:Cleaup Observers and fix certain mem leaks
    SystemUI: fix NFC tile sometimes hiding
    SystemUI : Ensure bouncer is not shown for SHADE
    Port "Settings: add a way to not localize zone selections" to cm-13
    Telephony: fix crash if SubInfo isn't ready
    Settings:Close "Protected apps" activity during power cycle
    Settings: Move vibrator value restore to onActivityStop
    Settings: Use correct icon for*sim card
    Settings[http://forum]isable battery pulsing if segmented battery LED is enabled
    Settings:Update MultiTasking Category Icon
    Settings:Protected apps: fix rotation states
    Settings:LockPatternView: persist state across rotates
    Settings:LLS: Load title and summary from ext. package if avail.
    Settings: Make sure to rebuild on app entries loaded.
    Settings: fix backlight illumination wrong summary
    Settings: More Dashboard Customizations
    Fix Reboot on Call Waiting Scenario
    Update Translations
    All updates from CM
    For more info Track Github
    Download al primo post
    Stefa99
    Kernel -> stock
  6. #34
    Oct 2010
    Installata la 5.6.9, fantastica rom, sempre fluidissima e tutta tradotta in italiano. devo dire che dalla 5.6.7 la rom è migliorata parecchio, un sacco di toggle e configurazioni per ogni cosa.
    Anche il mio nexus 7 2013 e il moto g 2013 di mia moglie ringraziano Resurrection Remix
    Ultima modifica di toto; 17-06-16 alle 20:44
  7. #35
    May 2015
    Torino
    Nuovo update.
    Changelog v5.7.0
    Android Update 6.0.1_r43-> 6.0.1_r46
    Android N style "No recents" activity
    Add animations to quick settings tiles
    Add interpolators to qs tiles animation
    Add new bunch of alpha and smart layer headers
    Add per app controls for LP keyguard notifications
    Remove LightStatusbar dark icon mode & make statusbar gradient
    Configurable LockClock & Date Text Sizes
    Improve some headers
    BatteryService: Fully charged notification toggle
    Visualizer: Let visualizer fill the entire available screen
    Only show keyguard panel if on lockscreen + no activity on top
    Update sb headset vector
    Update keyguard weather layout
    SystemUI: fix NPE when configuring blur layer
    SystemUI: fix multi touch gestures and extra jank
    SysUI: Simplify Code for Battery Icon Tint
    SysUI:Fix a Recents Styles Default
    SysUI: Fix SystemUI Crash on Notification Guts Media
    Don't lookup application keyguard notification visibility unnecessarily
    SystemUI: Add support for persistent usb drive notification.
    SysUI: Fix Secure Lockscreen Pulldown Switch
    Fix possibility of slim recents icon fc
    Fix a glitch causing shadow not to be reset when header disabled
    DocumentsUI : Hide advanced menu option when in forced mode
    SystemUI: fix one more misbehaving shadow
    Settings: Update performance settings icon
    Settingsisable Weather Provider By Default
    Settings : Fix dashboard colors default and reset values
    Recovery : Update RR script banner
    Themes : Update statusbar notify icon
    SmartBar: Add app picker as an action
    Give Pulse & Fling a Little CPU boost
    Pulse:imrpove Reset Logic
    Update Translations
    All updates from CM
    Bugfixes and improvements
    For more info Track Github Activities
    Download: [url]https://www.androidfilehost.com/?fid=24591000424940460[/url
    Quote Originariamente inviato da toto Visualizza il messaggio
    Installata la 5.6.9, fantastica rom, sempre fluidissima e tutta tradotta in italiano. devo dire che dalla 5.6.7 la rom è migliorata parecchio.
    Se per te non è un problema, aggiungo la tua opinione al primo post ;-)
    Stefa99
    Inviato dal mio Moto G (3rd gen) utilizzando Tapatalk
    Ultima modifica di Stefa99; 16-06-16 alle 21:41
    Kernel -> stock
  8. #36
    Oct 2010
    Quote Originariamente inviato da Stefa99 Visualizza il messaggio
    Stefa99
    fai pure
  9. Il seguente Utente ha ringraziato toto per il post:
    Stefa99 (17-06-16)
  10. #37
    May 2015
    Torino
    #ResurrectionRemix - 5.7.1 - 20160711
    Download: https://www.androidfilehost.com/?fid=24591000424946697
    Aggiornamento
    Purtroppo Vatsal ha annunciato che questo sarà il suo ultimo aggiornamento.
    Vi è un altro sviluppatore che mantiene una RR per il moto G3, se per i moderatori va bene, continuerò ad aggiornare questo thread con gli updates dell'altro sviluppatore (inserendo il nome ed i riferimenti e chiarimenti al primo post, ovviamente)
    Stefa99
    Kernel -> stock
  11. #38
    May 2015
    Torino
    La situazione attualmente è confusa: Vatsal ha ripreso a mantenere la official (o cosí pare), usando il Google GCC.
    TheIncognito continua le sue builds (unofficial, a quanto pare) usando UberTC.
    Per ora qui continueremo con le builds di TheIncognito, in quanto, nonostante unofficial, si basano sui sorgenti della official e sono piú ottimizzate (io arrivo a 6 ore di SOT senza wifi), mentre quelle di Vatsal durano meno come batteria. Le performances sono equivalenti.
    Stefa99
    Inviato dal mio MotoG3 utilizzando Tapatalk
    Kernel -> stock
  12. #39
    Aug 2013
    Scusa ma ti sei sbagliato ? Che versione è 5.7.1 ?
    Inviato dal mio MotoG3 usando Androidiani App
  13. #40
    May 2015
    Torino
    Quote Originariamente inviato da 50ennedapoco Visualizza il messaggio
    Resurrection Remix, una ROM. Usa però i drivers del touch screen della stock, come tutte le ROM, difatti fino a qualche tempo fa il problema al touch si risolveva, in ambito modding, flashando i drivers di LolliPop.
    Stefa99
    Kernel -> stock
