Pagina 22 di 50 primaprima ... 12202122232432 ... ultimoultimo
Visualizzazione dei risultati da 211 a 220 su 496
[ROM] CyanogenMod 5.0 [06/19/2010 / 5.0.8] + TESTING/NIGHTLY
  1. #211
    Androidiano VIP L'avatar di nk02
    Mar 2009
    Ringraziato 506 volte in 260 Posts
    CHANGELOG
    +---- 5.0.5-N1
    +* New App2SD method built into the framework. See the wiki for instructions! HUGE HUGE thanks to Chris Soyars for coding the bulk of this, and Wysie for getting our asses moving on it.
    +* Launcher2 tweaked to honor fling velocity - code by Faruq (ruqqq's Profile - GitHub)
    +* MMS enhancements originally by rgv151, ported to Eclair by Faruq, ChainsDD, Wes Garner, and myself
    +* New V8 JavaScript engine - from Qualcomm/CodeAurora
    +* Added kernel network bridging and brctl
    +* Updated N1 RIL to EPE54B's version, and included AT&T acdb file
    +* Many kernel updates, from Google
    +* Orientation mode is fully controllable from the settings app now, and 360-degree rotation patch updated from Optedoblivion and Elanthis
    +* Trackball wake & music skip + volume button long-press track changing from metalhead8816 (Jon Boekenoogen)
    +* Lots of work on the build system by Koush and Chris Soyars
    +* Browser enhancements from Wysie - hide zoom controls and fullscreen mode (Wysie's Profile - GitHub)
    +* Tweaked the light sensor
    +* Kernel is slightly undervolted. The voltages match what are being used by Qualcomm.
    +* Scripting fixes from Stefan Tomanek (http://github.com/wetarbyte)
    +* Nexus Live Wallpaper includes dark background and new color schemes - "Dust" is the new default - work on this done mostly Chris Soyars and tweaked by me. Check out his "NexusMod" version on the Market too.
    +* Battery percentage shown on the status bar - toggle the option in Spare Parts - patch from canadiancow (will take a battery status change for it to update after switching the toggle)
    +* Included rsync (thanks to Dylex for the Android port), iwconfig, and iwlist
    +* Updated German translations from Matthias Büchner (thiasB's Profile - GitHub)
    +* Many patches and fixes from AOSP and contributors (Gerrit Code Review)
  2. Il seguente Utente ha ringraziato nk02 per il post:
    Zenith (18-03-10)
    Jul 2009
    Bolzano
    iPhone 5
    ma non è ancora uscita....
  5. #213
    Mar 2009
    Quote Originariamente inviato da Zenith Visualizza il messaggio
    infatti, però se nei sorgenti ha aggiunto il changelog.. vuol dire che è molto vicina ^^
    io comunque la sto usando, giusto perchè dovevo provare le nuove stringhe tradotte :P se faccio a tempo ad aggiornare il github prima che cyano rilasci la 5.0.5, dovrebbero venir integrate le localizzazioni italiane
  6. #214
    Jul 2009
    Bolzano
    iPhone 5
    ma te la sei compilata te dai sorgenti?
    sarebbe ottimo avere la localizzazione completa
    speriamo che rilasci presto!
  7. #215
    Jul 2009
    Speriamo esca a brevissimo! Sto avendo seri problemi di durata batteria fra upgrade di varie cyano+UV kernel .33, dovrei rifare tutto ma se esce a breve attendo la 5.0.5!
    Samsung Galaxy S2
    Htc Flyer
  8. #216
    Mar 2009
    per chi vuole testare, questa è la versione compilata da me, il kernel ho lasciato quello precompilato da cyano, so che è stato aggiornato ma non so se ha tutte le novità. mancano 2-3stringhe da tradurre ancora, devo riuscire a trovarle (fixate!)
    qui lo zip con i vari img: MEGAUPLOAD - The leading online storage and file delivery service (nuovo link)
    se avete la 5.0.4.1 e non volete perdere dati fate cosi:
    1) nandroid backup
    2) da fastboot date
    codice:
    fastboot flash system system.img
    fastboot flash boot boot.img
    3) da recovery riflashate le gapps (il solito zip che di solito flashate dopo la cyano)
    4) reboot
    se non vi interessa tenere i dati, flashate anche userdata.img con "fastboot flash userdata userdata.img" (o provate con il comando unico "fastboot -w flashall" che dovrebbe flashare tutti gli img in automatico)
    edit: sto cercando di ricompilare (se il pc si muove) poichè ci son varie novità e nuove stringhe... spero di riuscire prima di uscire
    Ultima modifica di nk02; 18-03-10 alle 21:43
  9. #217
    wsx
    wsx non è in linea
    Senior Droid L'avatar di wsx
    Feb 2010
    Sassari
    Note 4 - iPhone 2G 4GB :o
    Ringraziato 261 volte in 158 Posts
    Dopo mi dici una cosa.
    Se io faccio il nandroid backup (di solito uso titanium) e metto su la nuova rom, poi devo ripristinarlo per riavere tutto come prima?
    O è meglio usare titanium?
    Cosa mi dici?
    Cosi poi testiamo bene le localizzazioni, anche se credo saranno già perfette
    Samsung Note S4 Black SM-N910F
  10. #218
    Mar 2009
    Quote Originariamente inviato da wsx Visualizza il messaggio
    Cosa mi dici?
    beh fai in nandroid backup, butti sopra il system.img e boot.img mio (fra mezz'ora ne posto uno nuovo, con le ultime novità di cyano e alcune nuove stringhe), testi per bene, e poi restori il backup da recovery per tornare indietro!
  11. #219
    wsx
    wsx non è in linea
    Feb 2010
    Sassari
    Quote Originariamente inviato da nk02 Visualizza il messaggio
    Ok allora aspetto che uppi e poi metto la rom.
    Per sicurezza mi faccio anche un backup con titanium.
    Col nandroid le applicazioni e le impostazioni vanno perse o no?
    Non sono espertissimo dei backup.
  12. #220
    Mar 2009
    nandroid backup crea un immagine completa dello stato del tuo telefono, quindi se fai un backup X, flashi un altra rom, e poi ripristini il backup X.. ti trovi il telefono esattamente uguale a com'era al momento del backup!
Discussioni simili
  1. nexus two?
    Da Gnappy nel forum Android Cafè
    Risposte: 1
  2. Ciao a tutti e buon 2010
    Da rck969 nel forum Benvenuto
    Risposte: 0
  3. Risposte: 284
  4. CyanogenMod 3.6 vs 3.5
    Da fenz nel forum HTC Dream / Tmobile G1
    Risposte: 1
