Pagina 84 di 302 primaprima ... 3474828384858694134184 ... ultimoultimo
Visualizzazione dei risultati da 831 a 840 su 3012
[ROM][LP 5.0.x] Stock modded by Cuoco92 per Nubia Z7 Mini [NX507J]
  1. #831
    Mar 2015
    Ringraziato 2 volte in 1 Post
    Quote Originariamente inviato da lelepanz Visualizza il messaggio
    prova a fare questa prova.
    Editing del build.prop
    persist.audio.fluence.voicecall = false
    per tornare indietro
    persist.audio.fluence.voicecall = true
    Hi All this is my first post i cant write in italian but i hope my english would be good enough.
    My phone also was having problem with heavy echo when in call!
    I'm on Cuoco latest Lolipoli ROM
    Solution was like lelepanz sayd change in build prop
    persist.audio.fluence.voicecall=true
    to :
    persist.audio.fluence.voicecall=false
    BUT also imprtant (didnt worked until i done both!)
    DISABLE Google Talk Back in apps manager!
    Hope it help someone else also
    P.S. Thanks Cuoco for great rom.
  2. I seguenti 2 Utenti hanno ringraziato Belgrade per il post:
    eddie1967 (29-05-15),lelepanz (28-05-15)
    Mar 2015
    Question for all
    in earlier ROM 1.8.2 by cuoco i got to use Go Sms Pro
    and it haved dual sim support which was great
    but now on latest Loli 3.0.1 (Cuoco edition)
    Go Sms no longer recognise its-a dual sim phone and there is no way i can force it.
    What changed about dual sim in these roms? Any ideas how to solve this?
    One more question did anyone sucesfully instaled Xposed Framework on this rom 3.0.1 (Cuoco edition)?
    Thanks
  5. #833
    Senior Droid L'avatar di Francy67
    Aug 2013
    Nubia z7 Mini
    Ringraziato 55 volte in 43 Posts
    Cuoco ho ancora problemi con la sveglia che seguita a non partire a telefono spento!!! Ho installato la tua ultima 2.79... Suggerimenti? Grazie 👍
    Inviato dal mio nubia z7 mini
    Nubia z7 mini by Francy
    Recovery TWRP 2.8.6.0
    Rom MIUI V7 5.8.21
    Profilo Google +
    https://plus.google.com/+FrancescoFrancy/videos
  6. #834
    Senior Droid L'avatar di Zopa
    Samsung s9
    Ringraziato 106 volte in 74 Posts
    Quote Originariamente inviato da daytek Visualizza il messaggio
    La probanbilita che succeda è alta, è già successo a qualcuno con un iphone :-)
    Daytek dal mio NX507J usando Androidiani App
    non è vero
  7. #835
    Ringraziato 60 volte in 57 Posts
    [quote name="ermyskat" post=6872021]No no... Non è il P8 ma il 4X... Costa meno di 200 e funziona da favola, per lavoro intendo... Per giochi e altro solo iPad...
    penso che cmq anche per i giochi faccia il suo sporco lavoro, no?[/QUOTE]
    Non voglio andare fuori ot ma purtroppo sto aspettando la custodia per utilizzarlo per lavoro. Direi che con real racing viaggia benissimo, telefono reattivo e al 5,5" ci si abitua subito, difficile tornare indietro... È il telefono che aspettavo! Oltretutto versione per l'Italia che si trovava l'altra settimana a 187 euro su a..... E la cinese a 167 su a.........
  8. #836
    Apr 2014
    Ringraziato 13 volte in 10 Posts
    Quote Originariamente inviato da ermyskat Visualizza il messaggio
    [quote name="lelepanz" post=6872677][quote name="ermyskat" post=6872021]No no... Non è il P8 ma il 4X... Costa meno di 200 e funziona da favola, per lavoro intendo... Per giochi e altro solo iPad...
    Inviato dal mio NX507J usando Androidiani App[/QUOTE]
    Non voglio contestare il tuo pensiero, ma il mio nubia funziona benissimo, ho acquistato lo Z7 mini in agosto 2014. Ora ho l'ultima versione dei cuochi, noto che anche la parte microfono é molto migliorata. Il mio giudizio rimane positivo.
  9. #837
    Senior Droid L'avatar di daytek
    Oct 2014
    mini-z7.LOL_5.1.1_ROW_v3.8.c92
    Ringraziato 311 volte in 230 Posts
    [quote name="Zopa" post=6873920][quote name="daytek" post=6866017]La probanbilita che succeda è alta, è già successo a qualcuno con un iphone :-)
    Daytek dal mio NX507J usando Androidiani App[/QUOTE]
    non è vero[/QUOTE]
    Credo sia meglio informarsi quii cara oppure su google
    Oppure non tanto lontano
    Ultima modifica di daytek; 28-05-15 alle 20:43
    Pensano tanto al futuro che dimenticano di vivere il presente, in tale maniera che non vivono nè il presente nè il futuro.
    [Dalai Lama]
  10. #838
    Anche il mio va benissimo... Ma con circa 300 chiamate al giorno in mobilità nei posti più disparati anche 10 chiamate che ti senti dire che non si sente bene dá fastidio per un telefono pagato 227 euro! Quando prima con un Honor 3C da 127 euro non ho mai avuto di questi problemi. Il telefono serve per telefonare... I cuochi fanno un lavoro sporco che non dovrebbero fare e ZTE se ne esce con lo Z9 e accantona lo z7 mini... Bravi!!! E grazie ai cuochi anche se ho sempre usato ROM stock... Eppoi tutte quelle batterie fallate? Non ci siamo ancora purtroppo perché a me piace questo mini...
  11. #839
    Apr 2015
    Ringraziato 8 volte in 5 Posts
    bb72, cuoco92 ciao e ho appena installato le nuove foto app di Google e si ferma in continuazione, si potrebbe risolvere il problema? Grazie per il vostro lavoro.
  12. #840
    Aug 2013
    Nubia z7 Mini
    Quote Originariamente inviato da Francy67 Visualizza il messaggio
    Sempre piu strana la cosa, ora se il telefono nn è collegato al carica batterie la sveglia funziona correttamente, se invece collego il telefono al carica batterie la sveglia non parte!!! boooo
    Rom MIUI V7 5.8.21
    Profilo Google +
