Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 18
[ROM][CM7.2][RC4] Reincarnation Rom Series v.5 | Touchwiz Nature UX Edition 22/02/14
    Androidiano L'avatar di bannab
    Spilamberto (MO)
    samsung galaxy ace gt-s5830i
    Ringraziato 70 volte in 58 Posts
    CM7.2 Reincarnation ROM Series v.5 | Touchwiz Nature UX Edition
    Screenshot
    Performance
    > 2.3.8 Bluetooth versions
    > Reincarnation Engine v.1 (the most minimal script and will publish soon)
    > Adrenaline Boost PRIME
    > BLN work
    > Better Battery life
    > Build.prop tweaks (very clean tweaks)
    > Built in flash player 11
    > Camera flash fix included
    > Faster GPS lock
    > Full GPU rendering
    > Integrated host file for adblocker
    > Media profile tweaks
    > Reincardio Engine, give excellent music quality and best overall audio engine
    > Removed beep volume panel
    > WIfi tehering really work fine
    > Pre-Installed (optional) in2extv2+ script to expand your internal storage..
    Features and Interface
    > S4 Launcher
    > S4 Lockscreen with real flare effect and sound effects,
    > S4 Styled Statusbar
    > Stock My files
    > Stock Memo, modded and renamed to S Memo
    > Stock CM Calendar modded and renamed to S Planner
    > Stock CM Calculator modded
    > Stock Touchwiz Desk Clock
    > Stock Accuweather from Galaxy S2
    > Samsung Keypad
    > S4 Music player (base is MIUI Music Player)
    > Quicpic gallery
    > Samsung stock task manager
    > Samsung digital clock widget
    > Added Proximity Lockscreen
    > Videos like stock samsung video app
    > Beautifull CyanogenMod Lockscreen
    > Added Photo Clock Widget
    > Modded and Included Camera Flash fix
    > 2.3.8 Screenshot apps
    > Android 4.x title bar
    > Android 4.x notification panel
    > Android 4.x window animation and transition.
    > Android 4.x security lockscreen
    > New Touchwiz boot animation
    > 29 Beauty touchwiz Wallpaper included in Launcher
    Bugs
    Installazione
    partendo da CM7
    1. Wipe Data
    2. Wipe Cache Partitions
    3. Wipe Dalvik Cache
    4. Format system
    5. Format cache
    6. Format data
    7. Mount system
    8. Mount Data
    9. Mount cache
    10. Install Zip from SD Card
    11. Reboot
    Download link
    Download Link :
    - 22/02/2014 CM7.2 Reincarnation V.5 Touchwiz Nature UX Cooperve1
    - Patch for fix Call Audio 22/02/2014 :http://forum.xda-developers.com/atta...3&d=1393137145
    Credits
    > Imbawind for part of Adrenaline Engine and Adrenaline Boost
    > Slaid480 for Part of Fly On Mod
    > Geva28 for Beats Manager
    > Probcomp for SMS Popup Notifier
    > Amarullz for AROMA INSTALLER
    > UOT Kitchen for Room Theming
    > Shlnarang for S4 Launcher
    > RedX Entertainment for Video Manager.apk
    > VavanL for Guide to remove beep volume panel
    > Ace i Team, sniper killer and iamareebjamal for give me some knowledge with on off settings guide
    > SladyMhmd for On Off Setting Source
    > Team nexus, get some knowledge with their Sources
    > iamareebjamal for Guide add custom image to about phone and Add JB easter egg
    > Spacecaker for some icon from their rom SGS III / IV JB Rom and Guide 4.2 Statusbar for GB
    > Zeppelinrox for fixfc script binary
    > Stryke for Unofficial Script Int2extv2+
    > All developers of TouchWiz Resurrection ROM, my inspire ROM and some sources file.
    Un Thanks a Rhievaldo per la rom http://forum.xda-developers.com/show....php?t=2657812
    Ultima modifica di bannab; 25-02-14 alle 17:16
    Se ti sono stato d'aiuto clicca il tasto thanks!
    Device: Samsung galaxy ace-i (gt-s5830i)
  2. I seguenti 4 Utenti hanno ringraziato bannab per il post:
    Giupy_99 (24-02-14),xXx_Enzo_xXx (26-02-14),smile68 (22-04-14),sorrygladiatore (06-03-14)
    Androidiani Power User L'avatar di xXx_Enzo_xXx
    Jan 2014
    Sotto allo stesso cielo
    Samsung S5830i / S5 + GEAR Fit
    Ringraziato 636 volte in 602 Posts
    se possibile altri screen
    interessa provarla, ma bisogna partire per forza dalla CM7 ? Quindi da un altra ROM poi a stock e mettere quella non è fattibile?
    PS: Se vuoi ringraziarmi per il supporto, puoi cliccare su questo tasto che si trova in basso a sinistra del mio profilo di ogni mio post.
  5. #3
    Spilamberto (MO)
    provvederò a mettere altri screen
    si puoi partire da stock...ma ricordati di flashare il kernel per cm7
    EDIT:altri screen aggiunti
    Ultima modifica di bannab; 25-02-14 alle 15:13
  6. Il seguente Utente ha ringraziato bannab per il post:
    Ace56 (11-05-15)
  7. #4
    Senior Droid L'avatar di felix7417
    Romito Magra-La Spezia
    Nexus5- Galaxy Ace-Ideos
    Ringraziato 316 volte in 242 Posts
    ..interessante...
    Nexus 5_Pure Nexus 7.7.1-Galaxy ACE S5830I
    Operatore Mobile: 3_Opzione/Tariffa: ALL IN Teen (1000-100-10GB)
    Mediacom SmartPad MP-8S4B3G
  8. #5
    Motorola Moto G 8 GB
    Vorrei flasharla domani...
    Bug noti?
    Per i fix bisogna applicarli dopo il primo riavvio?
    Che kernel è consigliato?
  9. #6
    Spilamberto (MO)
    bug... mi sembra di aver letto che dopo aver acceso il wifi.. i dati non vanno (bisogna riavviare per forza)
    i fix si meglio se li applichi dopo il primo avvio (e ricordati ti fare mount /system )
    puoi usare o il thunderkernel ( [DEV][KERNEL][2.6.35.7] ThunderKernel 2.1 [UPDATE 22/10/2013] - xda-developers ) oppure il kernel di biel ( kernel_CM7_v3.0 )
  10. #7
    Jan 2014
    Chiedo scusa, una precisazione dato che un amico vuol flashare il suo Ace:
    come Kernel va bene l'Hells Fusion o ce ne vuole un altro?
    Grazie.
  11. #8
    Spilamberto (MO)
    No, ne serve uno apposito per cm7 (vedi post sopra dove link i possibili kernels
  12. #9
    Androidiano L'avatar di sorrygladiatore
    Gangi
    Ho applicato la Patch for fix Call Audio ma in chiamata non si sente lo stesso...
  13. #10
    Spilamberto (MO)
    riaflasha e fai mount /system (ti assicuro che funziona perche l'ho provato io stesso..
  14. Il seguente Utente ha ringraziato bannab per il post:
    sorrygladiatore (05-03-14)
