Utente del mese: bluemask con ben 31 Thanks ricevuti nell'ultimo mese
[ROM] S'Perience ROM ® [17-12-12][NIMS/BE]
    Androidiano VIP L'avatar di Orla001
    Caserta
    LG G7 ThinQ
    Ringraziato 1,281 volte in 609 Posts
    - - S' P e r i a n c e´ F i n a l - -
    Cos'è la S'Periance ROM?
    La S'Periance ROM è una CustomROM basata sulla XWKTS Stock, creata dall'user SnowPuralism. Questa ROM offre una buona durata della batteria, ma allo stesso tempo ottime prestazioni, accompagnate da uno stile molto gradevole. La ROM è in due versioni, una con il Kernel Battery Extender 1.6 e un'altra con il Kernel Nims11.
    Ultima versione : Final [17-12-12]
    FEATURES:
    • Fully Built From Stock XWKTS, No Sacrambling This Time (Latest Release at Build Time)
    • Zip-Aligned, Deodexed & Rooted
    • Two Version's / Two Kernel's - Battery Extended 1.6 & Nims11 Memory Hacked By PSN With SwappAll 3.0
    • Custom Bootanimation S/ACE Themed
    • SIII Nature UX Themed ( Fully UI Sounds, Frame )
    • Custom Boot Sound On Nims11 Version ( On BE Version In system/etc/ rename poweron.ogg.bak to poweron..ogg after first boot )
    • Modded Settings To Look Like SIII/SII
    • JB Toggles
    • 6 Mod Lockscreen ( Changable From Settings )
    • 16 Steps Volume Steps
    • SIII JB Volume Slider
    • About Status Bar I Left It Stock ... I Did Themed It But On Testing It Looked ... Not That Great ... So To Fully Work We Should Be On ICS or JB and the end of the day ... This Only Ginger Bread
    • Themed Holo Launcher
    • New Adreno Libs and Tweaked 3D Graphics for Better Gaming Experience
    • SII Keyboard
    • Modded Mms.apk To No Mms Convertion and No Recepient Limit
    • Call Screen Like ICS
    • Journalism Disabled
    • SmoothScrooll
    • Adrenaline Engine
    • DSP Manager & MegaBassBeats Audio Libs
    • Fully Tweaked To Max Performance
    • OC And UC Capable ( OC Only On Nims11 Kernel Version )
    • Changable Governors
    • QuickPick as Default Gallery
    • Latest GAAPS
    • SIII Digital Clock
    • Modded MIUI Music Player to Look Like SIII Music Player
    • SIII and Some JB Wallpaper
    • Deleted Tones Of Crap
    • Besided All of That Mentioned Above 40 mb Free on System ( If u Want More Delete Media Files )
    • Hacked Services Jar To BLink Once On Misse Notification
    • SIII Dialer
    • RAM Optimized
    • New 4.2 Platlogo ( Keep On Touching Android Version )
    • SuperSU User App On Nims Kernel and Superuser on BE
    • Flash Player Working ( Not On Stock Browser Use on Opera Browser or Dolphin Browser, Naked Browser Also Do The Job )
    • CRT-Off Enabled
    • Hacked Host Files For No Ads
    • Modded Samsung Lockcreen
    • Screen Capture
    SCREENSHOTS:
    (Tanti)
    SI CONTINUA GIU'
    Ultima modifica di Orla001; 06-05-13 alle 20:30
  2. I seguenti 2 Utenti hanno ringraziato Orla001 per il post:
    PeppeGSR (28-07-13),thecicci70 (06-11-13)
    Caserta
    LG G7 ThinQ
    DOWNLOAD:
    REQUISITI PER L'INSTALLAZIONE:
    • ClockWorkMod 5 o 6 (Indifferente, non cambia niente)
    • Galaxy Ace GT-S5830, (SENZA LA i FINALE)
    • Più del 50% di batteria
    • Un cervello
    GUIDA INSTALLAZIONE
    1. Scaricare la ROM dal Link Sopra
    2. Copiare il file .zip nella SD
    3. Accedere alla CWM
    4. Fare un Wipe Data/Factory Reset , Wipe Dalvik Cache (Da advanced) , Format /System (Da mount e Storage)
    5. Andare su Install Zip From SDCard
    6. Scegliere la ROM e installarla
    7. Alla fine dell'installazione, eseguire un ulteriore Wipe Data Factory Reset
    8. Riavviare
    CREDITS - GRAZIE A :
    -> SnowPuralism Developer di questa ROM
    -> Tutti quelli che aiuteranno a tenere pieno di info questo Thread
    -> Me per la guida
    Se ti sono stato utile, premi il tasto Thanks!
    Ultima modifica di Orla001; 06-05-13 alle 20:34
  5. Il seguente Utente ha ringraziato Orla001 per il post:
    PeppeGSR (28-07-13)
  6. #3
    Senior Droid L'avatar di connor97
    Galaxy s3
    Ringraziato 41 volte in 40 Posts
    orla a te come va questa?
  7. #4
    Caserta
    LG G7 ThinQ
    Molto bene. Come vedi dalla mia firma ho la versione con il Battery Extender 1.6, che però ho "downgradato" all'1.5.1 OC.. Molto buona, ottime prestazioni e buona durata della batteria.
  8. #5
    Ringraziato 145 volte in 126 Posts
    Quote Originariamente inviato da Orla97A Visualizza il messaggio
    Te la consigliai io a suo tempo
    Inviato con il mio galaxy ace con la lockscreen dell'xperia z
  9. #6
    Caserta
    LG G7 ThinQ
    E' vero mi ricordo che tu avevi la versione con Nims11
  10. #7
    Che differenza c'è di preciso tra le due versioni?
    Ultima modifica di kingbaldesar; 13-06-13 alle 10:21
  11. #8
    Caserta
    LG G7 ThinQ
    Quote Originariamente inviato da kingbaldesar Visualizza il messaggio
    Solo una cosa: Il kernel
  12. #9
    scusate, ragazzi, mi resta bloccato all'avvio perchè? come risolvo?
    Ultima modifica di arancia1; 05-12-13 alle 16:58
