[CM 7.1.1] NIGHTLY Alpha 6 - Basata su Gingebread
    Super Droid L'avatar di ANDROIDPC
    Mar 2010
    Ringraziato 526 volte in 374 Posts
    CyanogenMod 7.1.1 NIGHTLY-Spica-alpha6
    >>Thanks To Tom3q<
    ATTENZIONE: Il caricamento della MOD potrebbe danneggiare il vostro dispositivo! L'operazione di aggiornamento viene eseguita a Vs rischio e pericolo consapevoli che il dispositivo potrebbe incorrere in un cossidetto BRICK!
    ISTRUZIONI PER L'INSTALLAZIONE (READ BEFORE STARTING TO DO ANYTHING FROM THE LIST!)
    1. (Only if you have alpha 5 installed now) Go back to your previous ROM or 2.1 + root using "how to go back to old roms" instruction
    2. Start your phone in recovery mode by 3 key combo (volume down + call accept + call hang up), not using "reboot to recovery" is very important.
    3. Do full binary tar backup of all partitions, also called "Samdroid Backup (for Odin)", and a standard tar backup of EFS. VERY IMPORTANT, makes returning back much easier
    4. Select "Install zip from sdcard" and then continue selecting "Toggle script asserts" until it displays "Script Asserts: Enabled" at the bottom.
    5. Apply flash_kernel.zip.
    6. Check if it didn't display any errors. If yes, flash any kernel suitable for your current ROM and post your problem in discussion thread. IMPORTANT
    7. Select "power off" from recovery menu to power the phone down (very important!).
    8. (Only if you have ever had alpha 5 installed, needed only once) Start your phone in recovery mode by 3 key combo (volume down + call accept + call hang up).
    9. (Only if you have ever had alpha 5 installed, needed only once) Apply unmark_blocks.zip.
    10. (Only if you have ever had alpha 5 installed, needed only once) Select power off again.
    11. Start your phone in recovery mode by 3 key combo (volume down + call accept + call hang up).
    12. Recovery may display some errors, but this is normal, since file systems aren't initialized yet, continue with next steps.
    13. Select "Install zip from sdcard" and then continue selecting "Toggle script asserts" until it displays "Script Asserts: Enabled" at the bottom.
    14. Apply rebuild_ubi.zip.
    15. Check if it didn't display any errors. If yes, use the "how to go back to old roms" instruction to go back and post your problem in discussion thread. IMPORTANT
    16. Select power off again.
    17. Start your phone in recovery mode by 3 key combo (volume down + call accept + call hang up).
    18. Apply cyanogen_spica-ota-eng.tom3q.alpha6a.zip.
    19. Check if it didn't display any errors. If yes, use the "how to go back to old roms" instruction to go back and post your problem in discussion thread. IMPORTANT
    20. Make sure that your SD card is mounted - select "mounts and storage" and select "mount /sdcard" if present. IMPORTANT
    21. Go back to main menu and select "wipe data/factory reset". IMPORTANT
    22. Choose reboot to system and wait for your new ROM to load.
    Installation instructions from alpha 5.x
    1. Apply cyanogen_spica-ota-eng.tom3q.alpha6a.zip from recovery.
    2. If experienced any hangs/reboots previously (if not, it's still recommended), mount /sdcard and perform factory reset (data wipe) from recovery. IMPORTANT
    3. Wipe dalvik cache.
    STATUS
    + GSM
    + Audio
    + SDCard/USB mass storage
    + Wifi
    + Bluetooth
    + 2D/3D HW acceleration
    + Multitouch
    + GPS
    - Sensors
    - Camera
    - Bluetooth audio
    - Hardware video encoding/decoding
    KNOWN ISSUES
    - Flash_kernel.zip fails with "cannot mount TMP:" error. Flashing other .29 kernel (like latest VOKU's) before applying flash_kernel.zip should help.
    - Phone gets stuck in recovery after flashing flash_kernel.zip. Flash a boot logo (less than 128KB!) in Odin with Debug only and Parameter clear options selected.
    - Neither samdroid nor native app2sd doesn't work (some application from Market to move applications to SD card is known to work as a replacement).
    - Reboot to recovery doesn't work. (Use 3 key combo, Volume Down + Call Accept + Call Disconnect)
    - Many 3D applications don't work correctly. This is because of an unfinished graphics driver, which had to be used, because Samsung driver isn't compatible with Android 2.3.
    - USB driver fails to install on Windows 7. Follow this tutorial to install it manually: [Discussion] CyanogenMod-7.1-NIGHTLY-Spica-alpha5.1 using driver from this post: [Discussion] CyanogenMod-7.1-NIGHTLY-Spica-alpha5.1
    - Native WLAN tethering is unsupported (Try this: android-wifi-tether - Wireless Tether for Root Users - Google Project Hosting)
    - Data traffic statistics aren't implemented yet
    - Audio routing doesn't work correctly in some VoIP applications (Skype)
    - Sometimes the earpiece might not be enabled on incoming calls, enabling and disabling speaker from menu helps.
    - CM BUG. Screen fade out animation is disabled by default. Disable screen off animation in CM Settings to fix it.
    - CM BUG. Sound mode notification widget is broken by default. Enable wanted sound modes in Sound mode notification widget settings in CM Settings to fix it.
    - CM BUG. Brightness notification widget settings give FC.
    - Slow write speeds in USB mass storage mode, especially on Windows. Sometimes a reboot or using USB mass storage mode from recovery can help.
    - Some people report problems with touchscreen. One of those packages might help: [Discussion] CyanogenMod-7.1-NIGHTLY-Spica-alpha6
    Fixes/Changelog
    - Updated CM sources, based on Android 2.3.7
    - Added GPS support
    - Fixed reboots with WiFi enabled
    - Updated WiFi driver
    - Fixed multitouch
    - Fixed headphone detection in sleep mode
    - Fixes for battery voltage drops during voice call and mobile data attached
    - Fixed SU updater
    - Fixed GSM network scan and selection
    - Fixed airplane mode
    + other minor fixes
    Per maggiori chiarimenti (ATTENZIONE la procedura di installazione come potete vedere è diversa rispetto le altre in quanto necessita di un precaricamento del Kernel) e per il DOWNLOAD vi rimando ai 3ad ufficiali di Samdroid:
    [Discussion] CyanogenMod-7.1.0-RC0-Spica-alpha5
    Ultima modifica di ANDROIDPC; 26-10-11 alle 09:32
    Smartphone: Samsung Galaxy NeXuS i9250
    ROM: Stock JOP40D - JB 4.2.1 Rooted
    Kernel: Stock 3.0.31
    Mar 2010
    Come potete vedere l'unico che è rimasto a sviluppare per lo Spica è il buon Tom3q che ha sviluppato un Kernel tutto suo per poter fare girare degnamente la ROM Gingerbread sul nostro vecchio Spica!!
    Notate bene che molti componenti non funzionano come si evince dalla lista STATUS, speriamo che questa sia una delle prime di una lunga serie di NIGHTLY.. ..contrariamente non avremo niente da fare con un Cell che funzionerebbe solo a metà!
    ATTENZIONE - nuovamente - all'installazione che per come descritta è un pò diversa dalla tipica per il carimento della CM (vano caricate tramite Recovery varie parti, compreso il Kernel)
    Grazie sempre comunque a Tom3q per l'impegno ed il lavoro svolto!
    Da TOM3Q:
    Remember, this is a test version, it isn't guaranteed that everything works correctly! However I will try to do my best to fix everything that doesn't.
    Mar 2010
    [AGGIORNAMENTO ALLA VERSIONE ALPHA 5.1]
    CHANGELOG ALPHA 5.1:
    Fixed microphone in voice calls.
    Fixed voice calls with screen locked.
    Fixed battery dropping from around 50% to 0% instantly.
    Fixed battery dropping to 0% after charging.
    Fixed WiFi.
    Fixed Bluetooth.
    Updated CM sources.
    ..aggiornata la prima pagina..
    Mar 2010
    [AGGIORNAMENTO ALLA VERSIONE ALPHA 5.2]
    Modificato il questa versione il Kernel.
    Fixed baseband crash issue
    Fixes for headphone detection in sleep mode
    Fixes for microUSB cable detection in sleep mode
    Fixes for CPU frequency scaling
    Ultima modifica di ANDROIDPC; 10-10-11 alle 12:44
    Senior Droid L'avatar di dadele87
    Aug 2010
    Ringraziato 68 volte in 51 Posts
    Ci sono ancora molti Fix da fare ma speriamo continui il suo lavoro il buon Tom3q!!! Io sono ancora senza il mio spica!!! L'ho spedito il 14 settembre ad un centro qui in svezia, ma ancora non l'hanno riparato! La cosa buona è che posso osservare lo stato dei lavori dal loro sito, ma sto impazzendo! Comunque ho deciso, appena mi arrivano un pò di soldini li metto sullo Xperia Neo!
    Secondo voi Ice Cream Sandwich ci andrà sullo spica???
    SE Xperia Neo "MT 15i"
    STOCK ICS 4.0.4 - ROOT - BOOTLOADER SBLOCCATO!
    Guide per gli Xperia2011:
    DooMLoRD ROOT Toolkit
    ROOT per .62
    ClockWorkMod Recovery
    Sbloccare il Bootloader!
    Flash di Custom Kernel/ROM
    TUTTE ALL'INTERNO DEL FORUM DEDICATO ALLO XPERIA NEO
    Samsung Galaxy Spica "GT-I5700"
    Se ti sono stato di aiuto non utilizzare altri post, premi il tasto "THANKS"
    Mar 2010
    Continua il lavoro di Tom3q.. ..giunto alla versione ALPHA6.
    Aggiorno la prima pagina! ..ma resta ancora una ROM sperimentale, instabile e incompleta!
    Aug 2010
    Nuovo aggiornamento alla alpha 6.1... anche se non ha aggiunto granchè dalla alpha6!
    ROOT per .62
