Pagina 1 di 11 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 107
CyanogenMod 10
    Bari
    Galaxy Mini 2- Galaxy mega 6.3
    Ringraziato 256 volte in 99 Posts
    CyanogenMod 10
    CyanogenMod 10 for Samsung Galaxy Mini 2
    Ne io e androidiani ci assumiamo la responsabilità di eventuali danni che questa custom rom potrebbe causare sui vostri dispositivi
    La rom funziona sui modelli:
    -GT-S6500;
    -GT-S6500D;
    -GT-S6500T;
    -GT-S6500L.
    Cosa non Funziona:
    * Off-mode charging (il device si riavvia)
    Altri malfunzionamenti:
    * Taking video in portrait mode, non è supportato dall'hardware del mini 2.
    Ringraziamenti vanno:
    People who helps me with testing and provides logs
    Everyone who is working on CyanogenMod 10, especially the CM team itself
    KonstaT - he has done an awesome job
    Dawnload:
    - Gapps: http://goo.im/gapps/gapps-jb-20121011-signed.zip
    - Download (stable - milestone builds): Goo.im Downloads - Browsing jena-cm10
    Come installare:
    1) raccomando di usare questa ClockWorkMod: http://forum.xda-developers.com/show....php?t=2156194
    2) Download ROM .zip
    3) Download Google apps
    4) Metti il file zip scaricato nella sd (internal or external storage)
    5) Accendi il telefono in recovery mode
    6) Ti consiglio di fare un nandroid backup
    7) Wipe data/factory reset
    8) Format /system (only if the previous ROM is CM 10/10.1)
    9) Installa la ROM .zip file
    10) Mount /system, installa le Google apps
    11) Fatto
    Bug reporting:
    https://github.com/TheWhisp/android_...ues?state=open
    1) Visit the above link
    2) Click on "New issue"
    3) Enter title that explains the problem
    4) Explain your problem very clearly with as much details as possible
    5) Attach logs and screenshots (if needed)
    Don't report a bug if it's already reported.
    Don't report a bug if you:
    1) have restored apps with Titanium Backup or similar software
    2) are using any kind of task killer
    3) are using any 3rd party tweak/hack
    Name what device you're using: jena, jenad or trebon
    Name CM version you're using: 10, 10.1, 10.2
    Use proper English, try not to make any spelling errors so I and other people can understand you correctly.
    XDAevDB Information
    CyanogenMod 10 for Samsung Galaxy Mini 2, a ROM for the Samsung Galaxy Mini
    Contributors
    TheWhisp
    ROM OS Version: 4.1.x Jelly Bean
    ROM Kernel: Linux 3.0.x
    Based On: CyanogenMod
    Version Information
    Status: Stable
    Current Stable Version: 20130827
    Stable Release Date: 2013-08-27
    Created 2013-10-11
    Last Updated 2013-10-11
    Immagini allegate
    Ultima modifica di DanielAstro97; 18-11-13 alle 13:19
  2. I seguenti 5 Utenti hanno ringraziato DanielAstro97 per il post:
    AntonioCinque (26-06-13),matt195 (21-04-13),NiloGlock (15-01-14),SimoCreeperFans (21-06-13)
    Lu89
    Se si potesse risolvere il problema wifi la flasherei ma cosi non posso...
  5. #3
    Bari
    non ti preoccupare sta per uscire una versione senza bug!
  6. Il seguente Utente ha ringraziato DanielAstro97 per il post:
  7. #4
    Lu89
    Meglio la 10 o la 10.1?
  8. #5
    Bari
    Sono allo stesso livello però fin ora la 10 è la più stabile
  9. #6
    Androidiani Power User L'avatar di dell
    Piuro
    D5803, E960 & (il fu) i9001
    Ringraziato 2,977 volte in 2,180 Posts
    Aggiungi anche i crediti e il link al thread di XDA
    Inviato dopo essere asceso, con Tapatalk.
    Don't be a n00b, be a newbie.
  10. #7
    Ringraziato 27 volte in 2 Posts
    Ma la posso installare anche da un altra rom?
    Inviato dal mio GT-S6500 usando Androidiani App
  11. #8
    Il link per le gapps non funsiona!
  12. #9
    L'ho fleshata ma non funsiona quasi nulla... non si puo chiamare ne mandare sms... wifi e camera non funsionano.. la sim non la legge... Vorrei mettere la 10.1 chi ha il link?
  13. #10
    Bari
    ho rimesso le gapps prova ad installarla ora!
