Pagina 1 di 9 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 84
[ROM][CM7.2][ODEXED] New Experience Jelly Bean Special Edition [30-08-2013]
    Senior Droid L'avatar di autoradio78
    Samsung Galaxy Next
    Ringraziato 845 volte in 356 Posts
    Credits and big thanks to:
    Cyanogenmod Team for base rom;
    MrAndroid for kernel;
    DrunkenMaster betatester;
    F4uzan for activo speeder;
    All xda developers.
    Changelog:
    - Based on Official Cyanogenmod 7.2.0 build 01-03-2013 (dd-mm-yy) Nightly;
    - Mr Android kernel.
    Appearance, graphic and utility:
    - New Experience Launcher (full modded Zeam Launcher);
    - ICS\JB System Theme (no APK);
    - New Jelly Bean Statusbar (CM 10.0) with power widget under jb carrier, clock, date, settings and clear button, clickable notifications and closon;
    - Themed in ICS-JB-Blue Style default cm 7.2 lockscreens;
    - ICS-JB Patterns style;
    - Statusbar poer widget indicator color pressetted in ICS-JB Style (smali mod);
    - Atypic feedback in statusbar fixed;
    - New Transitions Jelly Bean style);
    - Tablet Tweaks (softkey) enabled in a framework;
    - Statusbar Center Clock (fixed black statusbar with active softkeys);
    - Full Roboto Font;
    - New advanced cm 10 style Settings.apk;
    - Gallery 3D replaced with QuickPic as user application;
    - Camerasound on\off patch by autoradio78;
    - Videosound on\off patch by autoradio78;
    - New Experience bootanimation logo and default wallpaper;
    - New tones from JB AOKP arrangement(only useful tones).
    Performance:
    - 99% odexed rom;
    - Kernel Tweaks from ActivoSpeeder by F4uzan;
    - Adrenaline Engine 4.4 by ImbaWind;
    - Adrenaline boost by ImbaWind;
    - Setperm tweak by me;
    - Bravia Engine;
    - build.prop new tweaks;
    - Dalvik set at 48m to default;
    - Compcache disabled;
    - Dithering disabled;
    - 16 bit trasparency enabled;
    - Scrolling cache disabled to default;
    - HOT!!!! Beats Sound with Dolby Mobile in DPS Manager for perfect sound;
    - Performance OC Kernel to 806 mhz;
    - Ability to install unknown source applications at first boot;
    - Debug usb removed from statusbar notifactions;
    - Airplane mode active by default after first boot (for those without a data plan);
    - Pre-patched host file (adaway) for not have advertisemant in applications.
    Applications:
    - CM7 SMS/MMS App Improved (with bubbles) by lousou76 [fixed invisible recipients typing];
    - CyanMobile advanced Taskmanager;
    - Superuser app and binary;
    - Gapps in build with latest Google Play Store 4.0.26;
    - Disabled Setup Wizard at first boot;
    - Deleted Voice Dialer TTS;
    - Deleted Pico TTS;
    - Deleted Theme Chooser and Theme Provider;
    - Deleted CM Update Notify;
    - Deleted CM Stats;
    - Deleted Protips;
    - Deleted Genie Widget;
    - Deleted LatinIME cm7 default keyboard;
    - Deleted CMWallpapers;
    - Hacker's Keyboard;
    - s2e;
    - CPU Temp Widget;
    - SGSII digital clock Widget ICS style by autoradio78;
    - File Manager;
    - Achep Timer and Stopwatch app;
    - Faster GPS;
    - Battery Calibrator;
    - Rescan Media Root;
    - LMT Pie Control.
    Ultima modifica di millo1978; 17-09-13 alle 12:16
  2. I seguenti 12 Utenti hanno ringraziato autoradio78 per il post:
    andredsun (02-05-13),CriGio (08-06-13),dedeswim (09-05-13),Drek (16-08-13),DrunkenMaster (02-05-13),Friezamii (19-05-13),Gege98 (17-08-13),Kirja (03-07-13),millo1978 (02-05-13),MrFrancesco961 (15-05-13),ninfole (19-06-13),valdemort (20-06-13)
    Samsung Galaxy Next
    Vi prego di non porre stupide domandi quali: "che differenza c'è tra la Special edition e la v9.x.x...la risposta sarebbe tanto scontata quanto banale: la prima è chi per chi -come me- ama lo stile holo e non cambia continuamente aspetto e tema alla rom avendo un bisogno compulsivo di personalizzazione..la seconda invece è per chi ama fare tutte queste cose..oppure più semplicemente ama lo stile stock-aosp di android 2.3.x
    Indicazioni fondamentali sull'utilizzo della rom.
    Per poter utilizzare questa rom è necessario partire dalla versione 2.3.4 (o superiore) di Android; Potete scaricare anche questo firmware S5570XWKTN e flashare con odin.
    Installazione della Recovery 5.2.0.8 by Squadzone
    Se sul vostro terminale non è presente nessuna recovery custom (cwm o rz) o state provenendo da un flash pulito con odin di una rom stock, è necessaria l'installazione della recovery cwm.
    Potete farlo seguendo questa guida per il flash della stessa recovery da odin.
    Se invece sul vostro terminale è già presente una recovery custom (cwm 4 o rz), potere -sempre da recovery- flashare Questo zip per avere l'aggiornamento alla 5.2.0.8 Touch by Squadzone
    Partizione della sdcard
    1. Recarsi in ricovery;
    2. Fare "wipe data/factory reset" e "wipe cache partition";
    3. Fare "advanced" e "wipe dalvik cache";
    4. Fare di nuovo "advanced" e poi "Partition SD Card"
    5. Scegliere il formato ext4 e assegnare 512 mb come dimensioni per la partizione ext e 0 (zero) alla partizione di swap;
    6. Tornare indietro (col tasto back fisico o touch) e rifare tutti wipe ("wipe data/factory reset", "wipe cache partition" e wipe dalvik cache")
    Flash della ROM
    A questo punto, dopo aver partizionato, possiamo procedere nel flash della rom.
    1. Recarsi in recovery;
    2. Fare tutti wipe ("wipe data/factory reset", "wipe cache partition" e wipe dalvik cache");
    3. Fare "install zip from sd card" e poi su "choose zip from sd card";
    4. Selezionare la mia rom e attendere che la procedura di flash sia conclusa;
    5. A flash terminato NON vanno rifatti i wipe e basterà solo fare: "reboot system now";
    6. Il primo boot potrebbe essere più lungo del solito, tutto normale.
    Flash delle Statusbar Alternative
    2. Fare "Mount and storage";
    3. Fare "mount system"
    4. Tornare indietro;
    5. Fare "install zip from sd card" e poi su "choose zip from sd card";
    6. Selezionare lo zip desiderato e attendere che la procedura di flash sia conclusa;
    7. "reboot system now".
    Flash della Tastiera Samsung Stock
    Primo avvio e operazioni preliminari
    Bug e problemi noti
    Come sapete dopo lunghi sforzi sono riuscito a portare il power widget sotto al pulsante impostazioni, cancella notifiche ecc ecc...tuttavia tale forzatura presenta due soli piccoli problemi:
    1. Quando dalle impostazioni Tablet si seleziona "barra di stato in basso"..questa appunto va in basso ma il power widget, l'orologio e il tasto impostazioni rimangono su;
    2. Quando si vuole nascondere l'indicatore del power widget è necessario attivare e disattivare lo stesso per notare l'effetto.
    3. A causa del center clock, al riavvio del terminale la satusbar appare nera: poco male..basta aprire l'emulatore di terminale (che fornisce una notifica in statusbar e puf...la statusbar riappare
    Tutto qui..nulla di trascendentale
    Modalità Aereo
    Al primo avvio, troverete il terminale in modalità Aereo: tutto normale, è una feature che ho voluto integrare per chi -come me- non ha un piano dati e vuole evitare di perdere dei soldi con a connessione automatica che parte al primo boot di ogni Cyano.
    Aggiunta account Google
    L'account Google deve essere inserito SOLO dal percorso: Ipostazioni\Account e sincronizzazione\Aggiungi account.
    S2E
    Qui di seguito le impostazioni consigliate per l'applicazione di cui all'oggetto:
    - Aprire l'applicazione s2e, attribuire i privilegi di root e attendere;
    - Spuntare solo: "Applicazioni" e "Applicazioni private";
    - Consiglio di non spostare "cache di download" in quanto si potrebbero avere problemi con il Play Store;
    - Consiglio infine di spostare la "dalvik cache" e i "dati delle applicazioni", solo nel caso in cui si avesse una sd card performante.
    Uso di Titanium Backup
    Titanium deve essere utilizzato in modo intelligente: no integrazione della dalvik cache, no ripristino di applicazioni di sistema, no ripristino di accounts e punti d'accesso.
    DOWNLOAD
    Ultima modifica di millo1978; 17-09-13 alle 12:18
  5. I seguenti 9 Utenti hanno ringraziato autoradio78 per il post:
    Ale2197 (02-05-13),andredsun (02-05-13),Drek (16-08-13),Friezamii (19-05-13),Gege98 (17-08-13),millo1978 (02-05-13),MrFrancesco961 (15-05-13),Piccio23 (02-01-14),UngherDroid (06-05-13)
  6. #3
    Samsung Galaxy Next
    Ultima modifica di autoradio78; 02-05-13 alle 17:39
  7. I seguenti 5 Utenti hanno ringraziato autoradio78 per il post:
    Ale2197 (02-05-13),Cyber-Ninja (09-09-13),galagala (03-05-13),Gege98 (17-08-13),millo1978 (02-05-13)
  8. #4
    galaxy next
    Ringraziato 25 volte in 22 Posts
    Il setperm tweak che funzione espleta?
    Inviato dal mio GT-S5570 CyanogenMod 7.2 con Tapatalk 2
  9. #5
    Samsung Galaxy Next
    Quote Originariamente inviato da moby90 Visualizza il messaggio
    Serve a montare la root folder e la cartella system come scrivibili e settare delle autorizzazioni su alcuni files i quali non possono essere modificati dai vari scripts nella cartella init.d
    Inviato dal mio GT-S5570 con Tapatalk 2
  10. I seguenti 2 Utenti hanno ringraziato autoradio78 per il post:
    Gege98 (17-08-13),moby90 (02-05-13)
  11. #6
    Samsung Galaxy Next; Nexus 5
    Ringraziato 169 volte in 154 Posts
    ciao autoradio, finalmente un'altra rom temata di sistema ci avevo messo su gli occhi da xda, ma aspettavo che la pubblicizzassi anche qui domanda (spero non da niubbo) dato che è odexata occupa più spazio nella memoria del telefono (lo dico solo perchè vedo che ci sono 2 file distinti per ogni app)? e l'essere odexata influisce sul funzionamento di link2sd? tnx
  12. #7
    Samsung Galaxy Next
    ciao , ma se al posto di utilizzare s2e volessi utilizzare int2ext+ cosa dovrei fare? :P
  13. #8
    Ringraziato 9 volte in 6 Posts
    No, è il contrario..per meglio dire, occupa più spazio in /system, ma meno spazio in /data che è di fatto la memoria interna del telefono, in cui vengono installate tutte le applicazioni non di sistema...le app in questa cartella non sono odexate, basta vedere la cartella /data presente nello zip, al cui interno ci sono i soli file apk delle app...questo permette di recuperare un sacco di spazio per nuove app...basta controllare per vedere i 166mb disponibili al primo boot...inoltre l'odex permette di guadagnare in prestazioni, con un aumento anche della velocità di boot...come ha già spiegato autoradio nei post di presentazione della rom su xda...infine, non ci sono problemi con applicazioni tipo link2sd, s2e o simili...
    Quote Originariamente inviato da cryos Visualizza il messaggio
    Ultima modifica di andredsun; 04-05-13 alle 11:32
  14. I seguenti 3 Utenti hanno ringraziato andredsun per il post:
    autoradio78 (04-05-13),cryos (04-05-13),Gege98 (17-08-13)
  15. #9
    Samsung Galaxy Next
    Ciao..quoto e sposo in pieno tutto ciò che ti è stato spiegato dall'utente @andredsun che ringrazio
    Quote Originariamente inviato da JohnJoker7 Visualizza il messaggio
    Se volessi usare int2ext ti basterebbe installare lo script e riavviare i terminale.
    Tuttavia ti sconsiglio vivamente di utilizzare il predetto script in quanto - cosa che ho detto forse un milione di volte - s2e, con una semplice GUI ti permette di scegliere cosa spostare nella partizione ext...cosa non da poco specie per schede microsd poco performanti
    Su quest'ultimo punto ti invito ad una buona lettura del secondo post
  16. I seguenti 4 Utenti hanno ringraziato autoradio78 per il post:
    andredsun (04-05-13),cryos (04-05-13),Gege98 (17-08-13),JohnJoker7 (04-05-13)
  17. #10
    Samsung Galaxy Next
    grazie mille.. seguirò il tuo consiglio/guida e comunque non seguo da moltissimo la scena android quindi devo un pò capirne di più pian piano .... un'altra domanda... la fotocamera è fenomenale c'è lo zoom XD.. ma di che versione si parla di bravia engine???
    Ultima modifica di JohnJoker7; 04-05-13 alle 14:56
