Utente del giorno: Q.dino con ben 3 Thanks ricevuti nelle ultime 24 ore
[ PC ] modificare le APK per il multiwindows con APK-Multi-Tool -SENZA ROOT-
    Senior Droid L'avatar di malaccio
    Ringraziato 24 volte in 12 Posts
    APKMultiWindows - xda-developers
    Quote Originariamente inviato da XDA Visualizza il messaggio
    Hello guys !! I have make an application to auto modify multiple apk for multiwindows with APK-Multi-Tool !
    1 - Just put yours APKs in "place-apk-here-for-modding" folder
    2 - Run APKMultiWindows.exe
    3 - Then Click GO
    4 - Wait and when it finish it open folder contains all modify APK !
    WARNING : Your APK do not contains space or "(" ")" and maybe other special char.
    note : For use this program you need to install java 1.6 minimum and after you need to create 2 environment variable.
    PATH => C:\Program Files\Java\jdk1.6.0_18\bin
    JAVA_HOME => C:\Program Files\Java\jdk1.6.0_18
    Step 1 : Right Click on MyComputer and click on properties .
    Step 2 : Click on Advanced tab
    Step 3: Click on Environment Variables
    Step 4: Create a new class path for JAVA_HOME
    Step 5: Enter the Variable name as JAVA_HOME and the value to your jdk bin path ie C:\Program Files\Java\jdk1.6.0_18
    Step 6: SAme for Path
    Enjoy !!!
    Qualcuno mi aiuta? mi son promesso di non moddare nč note 2 nč note 10.1.
    perō modificare alcune apk per renderle compatibili con il multiwindows mi serve molto...
    non capisco la procedura praticamente di tutti gli step..
    quale java devo installare?
    grazie a chi mi aiuterā
