Pagina 19 di 71 primaprima ... 917181920212969 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 702
[Super-Huge-Update][14.12.2013] X-NOTE v6.0 N9005 MK2
  1. #181
    Oct 2013
    Ringraziato 22 volte in 21 Posts
    [/QUOTE]
    Chiedo molto è vero. .ma le mie conoscenze sono minime.( inglese) ..qualcuno mi può spiegare più o meno le varie voci. ..grazie. ..
    AROMA INSTALLER, NOW YOU CAN CHOOSE APPLICATION AND MODS DURING INSTALLATIONCSC NOW COULD BE SELECTED IN AROMA DURING INSTALLATIONACDC SOUND MOD (AROMA) + AUDIO BOOST LEVELS SELECTION (AROMA)NOOZXOIDE EIZO REWIRE PRO SOUND MOD (AROMA)ENABLE/DISABLE SOME SYSTEM SOUND (AROMA)ENABLED MULTI INSTANCE FOR +6000 MOST USED APPLICATIONSRECOVERY SELECTION + TWRP PLAY THEMED
    OFFICE APP FROM ANDROID 4.4RAM BAR IN RECENT (XPOSED MODULE)BUILT IN TRAFFIC SPEEDMETER IN STATUSBARNO INCREASING RINGTONE ENABLE/DISABLE (XPOSED MODULE)KERNEL SELECTION (AROMA) ... STOCK MJ6 RECOMMENDEDSOME GRAPHIC CHANGES IN SYSTEMUI AND FRAMEWORKFULLY WORKING NEW MJ6 STOCK SAMSUNG BROWSERModded settings with link to NEW X-NOTE APPLICATION (UPDATED), it include many options:
    - Multi Window Manager
    - Pen Window Manager The new @xperiacle application include "ability to open Pen WIndow drawer without using the Spen [Only with the*PEN Window Launcheraddon/plugin]
    appSound boost mod made by @nowy57 and modified by me to have whole louder speaker audio also in call (pay attention with volume because note 3 speaker have a poor quality)customized some UI soundFixed spen pointer positionOCR photo reader from S4X-Note bootanimation
    Face unlock and SIGNATURE UNLOCK NOW BOTH INCLUDEDGalaxy gear manager included in data/appXposed frameworkXposed per app density (set many options for each app included dpi density)
    screenshots)Enabled secondary symbols on stock samsung keyboardCamera with shutter sound on/off optionBrowser with exit optionUnlocked lockscreen torch optionUnlocked call and message block settingsSms will display sent time instead off received timeUnlimited contacts joinGreenify appSegoe UI extra font available (nice!) + ifont app.Additional camera effects available by defaulteditor video, sketch book mobile, stranslator available by default (no need to download it)...
    Ultima modifica di ermaglia; 05-11-13 alle 17:24
    Oct 2013
    Sto iniziando le varie procedure prima di fare casino .. qualcuno mi sa dire se va bene mj1 o devo per forza aggiornare a mj3?
  4. #183
    Androidiano L'avatar di Caputmundi
    Oct 2013
    Che ti si spieghi ogni voce pretendi un po troppo. .. diciamo che è il meglio che puoi avere per ora dal tuo note 3. Per ogni cosa se la cerchi su Google trovi dettaglio.
    Il modem non credo te lo chieda durante il setup.
    Tra l altro mi sono accorto ora che io ho il modem mj2 e tra gli updates ota ho visto che c'è mj4 lo consigliate?
    Ultima modifica di Caputmundi; 06-11-13 alle 00:29
  5. #184
    Oct 2013
    Quote Originariamente inviato da Caputmundi Visualizza il messaggio
    Il modem non credo te lo chieda.
    Ahhh mi hai levato un grosso dubbio ..perché ora installo mj1 e poi flasho la rom in versione 4.0 in Aroma qualche suggerimento per i vari passaggi app. Da installare?
  6. #185
    Oct 2013
    Lascia impostazioni default kernel stock e launcher stock altre apps scegli tu ma tanto puoi anche disinstallarle dopo
  7. #186
    Oct 2013
    grazie ..ok sto cercando le varie voci su Google
  8. #187
    Oct 2013
    Installato modem mj4 seguendo isyruzioni di Soloilmeglio. Sembra tutto ok.
    Ultima modifica di Caputmundi; 06-11-13 alle 11:49
  9. #188
    Oct 2013
    sto lashando in kernel mi dice o di non installare niente o kernel mj6 (raccomandato) io monto frw mj1 consigli?
  10. #189
    Androidiano VIP L'avatar di soloilmeglio
    N7100 - N8000
    Ringraziato 1,796 volte in 1,191 Posts
    "Raccomandato" non è un consiglio??? Hahahahha
    If you like my work and wants to keep the project alive please consider to buy me a glass of red wine or a toy for my dog
  11. #190
    Oct 2013
    Quote Originariamente inviato da soloilmeglio Visualizza il messaggio
    Fatto Grazie mille. Sembra tutto ok. Sta rom va na favola. Complimenti ancora per il lavoro.
    Non è che rieci a farmi quello zip per rimettere solo icone stock per messaggi, rubrica calendario etc?
