Pagina 1 di 71 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 702
[Super-Huge-Update][14.12.2013] X-NOTE v6.0 N9005 MK2
    Androidiano VIP L'avatar di Shinva
    Ringraziato 346 volte in 243 Posts
    Aggiornato alla V 6 Ho inserito le novità nel changelog
    Ho il piacere di annunciare la ROM di un nostro famoso e bravissimo cuoco: SOLOILMEGLIO
    FEATURES
    codice:
    FEATURES (new feature in RED CAPITAL LETTERS)
    Based on*European samsumg firmware MJ6. NOW SHOULD BE REGION UNLOCKED!Deodexed busyboxAutorooting Kernel with init.d support credits @danieljamie for the build tips and @angelom for autorootingZipalign new applications at boot and db optimizeKnox free
    AROMA INSTALLER, NOW YOU CAN CHOOSE APPLICATION AND MODS DURING INSTALLATIONCSC NOW COULD BE SELECTED IN AROMA DURING INSTALLATIONACDC SOUND MOD (AROMA) + AUDIO BOOST LEVELS SELECTION (AROMA)NOOZXOIDE EIZO REWIRE PRO SOUND MOD (AROMA)ENABLE/DISABLE SOME SYSTEM SOUND (AROMA)ENABLED MULTI INSTANCE FOR +6000 MOST USED APPLICATIONSRECOVERY SELECTION + TWRP PLAY THEMED (AROMA)EFS BACKUP (AROMA)FIXED LOCKSCREEN TO RIGHT VISUALIZATION AT ALL DPI SCREEN DENSITYSTOCK LAUNCHER WITH EDIT MODE ALWAYS ENABLEDMODDED BIG RECENT THUMBNAILMMS MAX SIZE 2048000 bytes, also increase the MMS IMAGE SIZE TO 4096x2048SMS 1000 UNLIMITED RECIPIENT LIMITX-NOTE ANDROID EASTER EGG (HAHAHAHAH)QUICK OFFICE APP FROM ANDROID 4.4RAM BAR IN RECENT (XPOSED MODULE)BUILT IN TRAFFIC SPEEDMETER IN STATUSBARNO INCREASING RINGTONE ENABLE/DISABLE (XPOSED MODULE)KERNEL SELECTION (AROMA) ... STOCK MJ6 RECOMMENDEDSOME GRAPHIC CHANGES IN SYSTEMUI AND FRAMEWORKFULLY WORKING NEW MJ6 STOCK SAMSUNG BROWSERModded settings with link to NEW X-NOTE APPLICATION (UPDATED), it include many options:
    - Multi Window Manager
    - Pen Window Manager The new @xperiacle application include "ability to open Pen WIndow drawer without using the Spen [Only with the*PEN Window Launcheraddon/plugin]
    - Torchlight in lockscreen
    - AD BLOCK
    - PIE-GESTURE CONTROL
    - Cpu monitor
    - Cpu spy
    - Change battery icon on the fly and select battery charge animation (+40 battery to choose)
    - Xposed installer + modules
    - Lockscreen settings Circle / Ripple with new animation
    - New X-Note information page with link to Dropbox folder for Updates, Extra, Themes (work in progress), link to XDA thread and donation button
    - reboot menu three way (normal, recovery, download)All application can be easy selected to have in floating window. Credits @xperiacle and his great applicationMultiwindow manager appSound boost mod made by @nowy57 and modified by me to have whole louder speaker audio also in call (pay attention with volume because note 3 speaker have a poor quality)customized some UI soundFixed spen pointer positionOCR photo reader from S4X-Note bootanimation
    Face unlock and SIGNATURE UNLOCK NOW BOTH INCLUDEDGalaxy gear manager included in data/appXposed frameworkXposed per app density (set many options for each app included dpi density)Call recording xposed moduleNo mms conversion xposed moduledisabled infinite scrolling in launcher (I like more)Enabled all rotation degree included upside downFully themed notification panel, status bar, circle battery, framework, dialer, application icons etc. (See screenshots)Enabled secondary symbols on stock samsung keyboardCamera with shutter sound on/off optionBrowser with exit optionUnlocked lockscreen torch optionUnlocked call and message block settingsSms will display sent time instead off received timeUnlimited contacts joinGreenify appSegoe UI extra font available (nice!) + ifont app.Additional camera effects available by defaulteditor video, sketch book mobile, stranslator available by default (no need to download it)
    NEW DONATORS, SUPPORTERS NAME AND GREETINGS ARE MENTIONED IN X-NOTE APPLICATIONmore to come
    COME INSTALLARE:
    - root your device and install a custom recovery... IMPORTANT! flash procedure tested only with latest TWRP.
    - MAKE EFS BACKUP!!!
    - download rom zip
    - CHECK MD5
    - reboot recovery and WIPE DATA*(DO NOT PERFORM OTHER WIPES)
    - install rom zip and follow AROMA INSTALLER
    - reboot device
    - do the samsung wizard then wait indexing service and media scanning (it may takes time, it depends on how many files you have in internal and external sd card)
    - done
    THX to Apachi per i fix per il force LTE network ON.
    DOWNLOAD:
    download link
    chrome://mega/content/secure.html#!z...ZnP4jd6eEJEXw4
    X-Note_Aroma_Build_6.0_MK2_Public.zip | by X-Note Team for Galaxy Note 3
    ______________________________________
    credits:
    Credits
    @xperiacle - for his great work
    @angelom for autoroot kernel
    @dsixda- For dsixda kitchen
    @civato - for spen pointer tips
    @Chainfire - For Superuser and a bunch of things
    @rovo89- For Xposed framework, for updates http://forum.xda-developers.com/show....php?t=1574401
    @Tungstwenty - For Xposed Module (custom dpi density)
    @OsamaGhareeb for battery mods
    Please pm me if I forgot some Dev
    COME AL SOLITO FLASHATE A VOSTRO RISCHIO E PERICOLO E RICORDO CHE INVALIDERETE LA KNOX WARRANTY ATTIVANDO IL COUNTER 0x1
    SUPPORTIAMO IL NOSTRO SVILUPPATORE DONANDO UN SEMPLICE CAFFè E PREMIAMO IL SUO OTTIMO LAVORO !
    https://mobile.paypal.com/it/cgi-bin...513AG835803J#m
    Immagini allegate
    Ultima modifica di luchino71; 17-12-13 alle 11:23
  2. I seguenti 5 Utenti hanno ringraziato Shinva per il post:
    dok (14-10-13),gionnyb89 (04-12-13),lorenzo63 (14-11-13),lust (19-12-13),N1m0Y (14-10-13)
    Androidiano VIP L'avatar di sharks
    Ringraziato 67 volte in 67 Posts
    Ottima rom appena messa!
  5. #3
    Androidiano VIP L'avatar di soloilmeglio
    N7100 - N8000
    Ringraziato 1,796 volte in 1,191 Posts
    Te piaceva così tanto lo screenshot che l'hai postato 5 volte ahhahahha
    If you like my work and wants to keep the project alive please consider to buy me a glass of red wine or a toy for my dog
  6. I seguenti 2 Utenti hanno ringraziato soloilmeglio per il post:
    sharks (14-10-13),Shinva (14-10-13)
  7. #4
    Mi piace troppo sta rom, dopo che non sono riuscito a seguirti sul note 2 almeno sul note 3 riesco!😊😊😊😊
  8. #5
    N7100 - N8000
    Quote Originariamente inviato da sharks Visualizza il messaggio
    Ora ti invio un pm. .. leggi....
    qui comunque c'è anche il lavoro di Xentrix Developer siamo in 2
    Ultima modifica di soloilmeglio; 14-10-13 alle 17:08
  9. Il seguente Utente ha ringraziato soloilmeglio per il post:
    sondra (21-07-14)
  10. #6
    Androidiano VIP L'avatar di snakkuzzo
    Jun 2010
    roma
    Ringraziato 106 volte in 87 Posts
    bel lavoro..ma finke,non si puo resettare knox con recovery,non moddo.
    una domanda:
    sul fix sound cosa accade?aumenta il volume.oppure aumentano i bassi sulla cassa sotto?
    Le vie del signore sono infinite...ecco togliti da davanti che ti schiaccio!
  11. #7
    N7100 - N8000
    No c'è un fix sound, forse intendevi sound boost, aumenta il volume di tutto, sia cuffie che audio in chiamata e viva voce e altoparlante. Purtroppo però qualità altoparlante è scarsa e tende a frequenze alte nonostante il boost
  12. #8
    Jun 2010
    roma
    Quote Originariamente inviato da soloilmeglio Visualizza il messaggio
    si parlavo propio del sound boost.
    allora è inutile secondo me mettere quella mod. gia distorce leggermente,cosi distorce sempre ,vero?
    cmq su note2 era meglio.
  13. #9
    N7100 - N8000
    No... distorce se alzi troppo... in cuffia però è necessario proprio fare il boost...
  14. #10
    bella rom
    ahahahah sim ho messo 5 volte la screen ahahahah
    avete fatto davvero un ottimo lavoro !
