Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 31
XDA [ROM][4.4.2][N9005][TW] NF4 MultiX v1.8/Multi DPI & CSC/Aroma/KNOX 0x0/Stable
    gt-p6200; gt-n9005
    Post
    multix 2.3 italiana, odex e Metodo knox 0x0
    Highlights: TW Launcher with landscape support. Supported DPIs: 480(default), 430,400,361,321
    Mobile Odin support KNOX 0x0 can be keept.
    changelog:
    • AROMA Installer (for almost fully customization)
    • Base: KOT49H.N9005XXUGNI4
    • Modem: not included
    • Stock N9005XXUGNI4 kernel & Lean hlteeur-kk-v3.4 & CivZ-KK_Xplorer-Rev1.5 & Ultimate kernel v.52*
    • Display languages (varie lingue compresa it_it)
    • Call recording can be enabled or disabled *
    • Messaging app hacks: displaying sent time, sms 100 recepients, SMS to MMS auto-converting increased
    Auto convert sms to mms after 7 sms; folder view & save-restore messages enabled
    • OS Scrolling cache disabled
    • Lock screen rotation *
    • Exit menu to stock web browser & home option *
    • Camera flash usable under 15% battery level
    • Disable or enable messaging log in call log *
    • Speedmeter in status bar with toggle in display options
    • All apps enabled in multi & in pen window
    • Note 3
    • Launcher rotation
    • Imaged battery in the statusbar
    • 3Minit Quicklaunch on notification panel
    • Disable signature verification
    • Multi instance
    • OGBattery Mod
    • ExtSdCard write issue fix
    • Call / message block enabled in device settings
    • App Ops enabled in general settings
    • Search window removed from the top of the settings pages can be found in general tab as button
    • Find my mobile & Reactivation lock removed from the settings
    • Launcher themes: Stock Note 3 KK; Stock Note 3 JB; S5
    • Accuweather widget stock Note 3
    • Optical reader *
    • Selectable languages for Optical reader: Varie lingue compresa Italiana
    • Included offline Samsung keyboard files: diverse lingue tra cui italiano
    • Included TTS voices: Varie lingue compresa Italiana
    • Included SVOX voices: GB; PT *
    • Hacked Flash player & Dolphin browser *
    • Camera Shutter Sound Menu enabled
    • Sending MMS forced
    • Flaslight quick settings toggle added
    • Download booster (nativ in FNF4)
    • Kids mode installer (nativ from FNF4) *
    • New camera mode Virtual tour (nativ in FNF4)
    • Quad view in multi window enabled
    • Hidden power button under the clock (only if in extras imaged battery mod selected) *
    • Finger Ink effect enabled on the lock screen
    • 4 way reboot*
    • S5 Photo editor *
    • Download booster Note 3 themed
    • Multi Dpi Playstore (all apps visible)
    • Option in Aroma for disable Magazine Home in stock TW Launcher
    • PullUp for stock TW launcher, start what you want at the bottom (as Aroma option)
    • Included CSC: Tutte le lingue, inculusa ITV
    • KNOX removed
    • Favorite & Moile Wi-Fi hotspot enabled
    • Lockscreen shortcuts are enabled for German & Austral users
    • Spell check (Google keyboard must be installed) *
    • Theme settings under Personalization in Settings
    • One Hand scale app from S5
    • Safe volume warning removed
    • Skip track with volume button mod added (Settings / Sound / Device)
    • Google L theme included for TW launcher
    • Viper4Android *
    • MultiX or Stock theme *
    • 4 Theme for multiwindow launcher (Stock, JB, Black, Transparent) *
    • Icon selection for Settings (Stock, Grey, None) *
    • Black wallpaper in wallpaper chooser
    • 4 kind SystemUI: stock, with imaged battery, with OGBattery, special edition from meawww & OGBattery *
    • Selectable notification panel background opacity: 100, 75, 50, 0 *
    • Selectable quick settings toggle color: blue, green, white *
    • Selectable quick settings toggle background: blue, transparent *
    • Disable ascending ringtone *
    • Frequently updated Google apps are moved to data/app
    • Quick pin/password unlock mod *
    • Default animation speed is set to 0.5
    • CSC features in Aroma installer: Secondary symbols, Call button to contacts,
    Disable TW launcher tilt animation, LTE status bar data icon
    • Xposed proof others.xml & feature.xml (use the options in Aroma installer)
    • Multi Dpi Playstore 4.9.13 included
    • UpdateMe 2.0.3 *
    • Screen Mirroring with custom kernel
    Aroma options
    • Wipe Methodes:
    Full wipe (for clean install formats cache/data/system/internal SD)
    Partial wipe (recommended for the first install formats cache/data/system)
    Easy wipe (for future use formats cache/system re select apps without data loss)
    No wipe
    • EFS backup:
    Yes or No (as you want)
    • Kernel selection:
    Update mode (keep the current kernel)
    Stock, Xplorer, Lean or Ultimate kernel
    • Install mode:
    Update mode (Do not use it at the first install)
    Install mode (system installation)
    • Density selection:
    480, 430, 400, 361 or 321 Dpi
    • Localozation selection:
    See above in change log (CSC)
    • Csc feature selection: (select an CSC to activate it)
    Secondary symbols; Call button to contacts; Disable TW launcher tilt animation; LTE status bar icon;
    • Selectable apps:
    AccuWeather app & widget; Bloomberg; G Books; G Chrome; Sketchbook; G Drive; Dropbox; Evernote; Flash Player &
    Dolphin Browser; Flipboard; G Games; Gmail; Google+; Hangouts; G Magazines; G Maps; G Music; Polaris Office;
    Polaris viewer; Quick search; Samsung Apps; Samsung browser; ChatON; Group Play; S Health; S Hub; Optical reader; S Link;
    G Photo editor; Story Album (only installer); S Translator; S Voice; Watch ON; Trip Advisor; G Videos; Yahoo widgets;
    Youtube; Xposed installer; Kids mode installer,
    G = Google S= Samsung
    • Accuweather widget:
    Note 3 or S5
    • Selectable services:
    ANT+; Hearingdro; Live wallpaper; Printing; Screen mirroring updater; Google L keyboard; Wallpaper chooser; Viper4Android;
    UpdateMe; GMS Core; (GMS Core must be installed after Factory data reset again)
    • Offline keyboard files:
    • Samsung TTS & SVOX voices:
    • TW Launcher:
    Note 3 or S5
    • Extra Rom settings
    See above in change log (if Extra Rom settings is selected, than select each mod again what you want, if in the extra
    Rom setting nothing is selected, than all changes will be removed. If extra Rom settings isn't selected than no change)
    • SystemUI selection:
    Stock, Imaged battery, OGBattery, Special edition from meawww
    • Volume mod:
    - Loudness from -1 to +5 (Headphones & Speaker)
    • Themes:
    - Stock or MultiX (black)
    Known Issues:
    • Stock Accuweather widget supports only portrait mode
    • S5 Launcher Edit page supports only portrait mode
    • SHealth comfort level screen not fully fixed for multi dpi usage
    • Smart scroll / Scroll by / Tilting head not working Fix added to post 1012
    Thanks to:
    - raj_ch2002 for starting the 240 dpi project
    - amarullz for Aroma installer
    - Chenglu for CWM Based Recovery
    - Pulser_g2 for the VillianTheme System
    - RevengeDeveloperTeam, I learned from the Angry Rom how to change the density in the apps
    - majdinj for his mods
    - Rovo89 and Tungstwenty for Xposed Framework
    - kmokhtar79 for the for his help and for the spoiler on the top and for 4 way reboot fix
    - jovy23 for messaging mods
    - gharrington for 3Minit Quicklaunch panel
    - meawww for OGBattery Mod guide and for call recording & ascending ringtone mod
    - OsamaGhareeb for the OG Battery Mod
    - surviveland for hacked Flash Player
    - kin201303 for all apps in MW & Pen window
    - _alexndr for new updater-script and for his help with MOP
    - arsaw and electron team for the ported S5 launcher
    - parkhyb for Imaged Battery
    - chainfire for CF-Auto-Root and for SuperSU
    - mateenf for ExtSdCard write Issue fix
    - civato for Xplorer kernel
    - Imoseyon for Lean kernel
    - FakeJap for PullUp
    - MyLifeRocks10 for Multi Dpi Playstore
    - iT iS Me for Spell check mod
    - loserskater & tdunham for Music control
    - daliborkv for TW Launcher L theme
    - da4kgr3y for Ultimate kernel
    - ViPER520 for Viper4Android
    - zhuhang for Viper4Android and for the IRS starter pack
    - Tsjoklat for Multi Dpi Play Store How To
    - sorg for Screen Mirroring hack
    Install instructions:
    Only for international N9005
    Se avete ancora la rom stock jelly bean (4.3):
    • Dovete fleshare il bootloader della rom stock kitkat (4.4.2)!
    • Il modo più semplice e fleshare tramite Odin 3.7, scaricando il firmware stock da Sammobile.com
    Metodo 1(se avete il knox a 0x1)(4.4.2):
    Attenzione con questo metodo si intaccherà il warranty. Knox passera allo stato 0x1
    • Rootate il telefeno tramite Cf-auto-root
    • Fleshate la Chenglu's CWM recovery
    • Andate il recovery (premendo contemporaneamente da spento tasto Home+Volume su+tasto accensione)
    • Se si desidera fate il backup della rom corrente;
    • Avviate l'installazione;
    • I vari wipe sono gia inseriti nell'installazione aroma, non sono necessari i wipe da recovery.
    • Selezionate quello che volete installare
    • andate avanti ed avviate l'installazione vera e propria
    • finendo le varia procedure, la rom si avvia da sola
    Metodo 2 (se avete il knox a 0x0 e volete mantenerlo tale)(4.4.2)
    • Effettuate il root tramite il towel root (presenti nel forum le varie guide)
    • Scaricate ed installate Mobile Odin Pro
    • Mettete la rom nella micro sd
    • Tramite mobile odin pro selezionate il file contenente la rom
    • avviate la procedura di aggiornamento
    • nell'aroma per quanto riguarda kernel e recovery, dovrete selezionare update mode!! in modo tale da mantenere kernel e recovery stock!
    • selezionate quello che volete installare dalla procedura aroma
    • e avviate l'installazione. si riavviera e partira la procedura mobile odin.
    METODO PROVATO TRAMITE MOBILE ODIN. SOTTO LA GUIDA!
    Link con tutti gli screenshot: https://plus.google.com/u/0/photos/1...37877596421361
    Link server XDA: [ROM][4.4.2][N9005][TW] NF4 MultiX v1.9 | Mu… | Galaxy Note 3 | XDA Forums
    Immagini allegate
    Ultima modifica di galaxy7plus; 11-11-14 alle 13:28
    gt-p6200; gt-n9005
    Wink
    Samsung Galaxy Note 3 N9005 (KNOX 0x1):
    Rom: MultiX v1.8 Firmware: XXUFNF4 Modem: XXUFNF2 Bootloader: XXUFNF4
    Kernel: Stock XXUFNF4 Recovery: Chenglu's CWM Based Recovery 6.0.4.7
    Ultima modifica di galaxy7plus; 10-09-14 alle 14:25
    gt-p6200; gt-n9005
    Post
    Scrivo questo post per guidarvi nell'installazione tramite mobile odin pro in merito al salvaguardare il contatore knox 0x0
    • Aprite mobile odin pro
    • Cliccate su “open file”
    • Selezionate il file zip
    • Attendete che carichi
    • Dovreste avere il segno di spunta su everroot, inject superuser, inject mobile odin
    • Scendete e cliccate su flash firmware
    • Si riavvierà e partirà in recovery boot
    • Partirà l’aroma
    • Andate avanti
    • Scegliete il wipe da effettuare (io consiglio di salvare tutti i dati con titanium backup ed effettuare il full wipe)
    • Selezionate l’update mode or knox 0x0
    • Lasciate tutto per come e descritto (install mode e 480 dpi)
    • Selezionate come localizzazione itv oppure hui se il vostro device e marchiato 3
    • Selezionate quello che volete trovare in più nella rom
    • Selezionate le app che volete installate
    • Andate avanti e selezionate quello che più vi aggrada
    • Arrivati alla fine vi darà di andare avanti e inizierà la vera e proprio installazione
    Appena finita l'installazione vi chiedera o di salvare il log o di andare avanti. voi andate avanti e si riavvierà. impieghera un po di tempo per riavviarsi ovviamente.
    Conclusione? rom installata e contatore inalterato! Sotto inserisco uno screenshot di phone info by samsung!
    Ultima modifica di galaxy7plus; 11-09-14 alle 13:44
    gt-p6200; gt-n9005
    Link download della versione 2.3
    http://forum.xda-developers.com/devd...ct/dl/?id=9565
    Consiglio di usare jdownloader
    Ultima modifica di galaxy7plus; 11-11-14 alle 13:34
    Zêna - Pianeta Genoa
    Mate 20 Pro
    Ciao...
    Ascolta, così però non va molto bene.
    Fai così almeno. ..
    • Traduci la presentazione
    • Scrivi i passaggi di installazione in italiano
    • L'hai testata tu?
    ___________________
  7. Il seguente Utente ha ringraziato Varioflex per il post:
    galaxy7plus (09-09-14)
  8. #6
    Androidiano VIP L'avatar di luchino71
    Dec 2009
    Pesaro Urbino
    Ora G4 poi boo,
    Ringraziato 814 volte in 547 Posts
    Quote Originariamente inviato da galaxy7plus Visualizza il messaggio
    Finalmente dopo tanto tempo, sono riusciti a creare una rom custom dove non viene intaccato il stramaledettissimo KNOX! Viene indicato come stabile questa rom. Essendo che non avrei le capacità ne il tempo di tradurre questa pagina da xda, ho pensato bene di postare la rom. aspetto ulteriori aggiornamenti.
    Un'altra cosa, come fa a non intaccare il knox se nella guida dice di installare la cwm e di fare il root con cf auto root ?
  9. #7
    gt-p6200; gt-n9005
    Quote Originariamente inviato da luchino71 Visualizza il messaggio
    Semplice. viene indicato nella rom comunque. fai root con towel root o un qualsiasi altro metodo per rootare senza far scattare knox, e installi mobile odin pro. copi la rom nella scheda sd, ed esegui la rom tramite mobile odin. ora traduco i passaggi della rom in modo da essere più comprensibili. l'euforia mi ha fatto postare la rom nuda e cruda da XDA vedo se in giornata riesco a fare tutti gli accorgimenti che varioflex mi ha presentato.
    Quote Originariamente inviato da Varioflex Visualizza il messaggio
    Ciao...
    Fai così almeno. ..
    • L'hai testata tu?
    ora traduco questi piccoli passaggi. ho visto la rom stamattina. non ho avuto il tempo di provarla. penso che a breve provero a metterla.
    Ultima modifica di luchino71; 09-09-14 alle 12:33
  10. #8
    Dec 2009
    Pesaro Urbino
    Ora G4 poi boo,
    Allora specifica bene questo passaggio altrimenti qualcuno potrebbe fare danni...
    P.S. non fare doppi post ma edita il precedente, stavolta li ho uniti io..
  11. Il seguente Utente ha ringraziato luchino71 per il post:
  12. #9
    gt-p6200; gt-n9005
    okay grazie. e la prima volta che posto una rom su questo forum. xD primo post aggiornato. vedro di fare l'introduzione più dettagliata.
  13. #10
    Mate 20 Pro
    Apporterei allora delle modifiche nel primo post, affinchè siano CHIARE e DISTINTE le due modalità di procedura
    Dopo il titolo che preannuncia le istruzioni di installazione andrei a fare quindi la specifica (ad esempio)
    ★☆ Install instructions ☆★
    ● Metodo 1 ( per chi ha già Knox a 0x1)
    ● Metodo 2 ( senza intaccare Knox )
    Quindi spiegare bene il metodo 1 e il 2.......
    mettendo bene in evidenza e all'inizio della spiegazione un WARNING per Knox per quanto riguarda il metodo 1
    (onde evitare che qualcuno poco attento faccia caos.......e magari lo utilizzi avendo Knox a 0x0)
    [CENTER] ♧♧♧♧♧♧♧[CENTER]
    Edit:
    E poi...
    Appena la installi.....
    Inserisci un pò di screen....
    Ultima modifica di Varioflex; 09-09-14 alle 15:40
    ___________________
  14. Il seguente Utente ha ringraziato Varioflex per il post:
