Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 19
[N910F][Touchwiz][Aroma]Emotion Revolution Note 4R12.1 - Note 5 Port R2.1
    Androidiano L'avatar di Emanuelbruno1993
    Samsung galaxy note 4 910f
    Ringraziato 77 volte in 56 Posts
    Nè io nè Androidiani ci riteniamo responsabili dei danni recati al vostro terminale durante il flash ecc.. Non procedete se non siete sicuri di ciò che state facendo!
    Ciao ragazzi vi presento queste due fantastiche rom che ho avuto il piacere di provare poco tempo fa... Entrambi molto belle.. Però questa è una cosa soggettiva.. Quindi fatemi sapere.... 😉
    CHANGELOG:
    R3.1Pure Note 5 Experience
    - based on POK1 Firmware
    - Deodex
    - Deblotware
    - Zipaligned
    - Rooted
    - Support int.d
    - Fixed sd
    - Improved and added multi-users
    - Added 1300 fonts styles*
    -3 Minibattery (optional)
    - Flashlight toogles
    - Lock screen pressing on the clock or pulldown
    - Added lock and home in pulldown
    - Emotion Control:
    Show / hide sfinder and fast connection.
    Show / Hide brightness bar.
    Show / hide ram usage in pulldown and custom color.
    Custom toogles number.
    Statusbar clock settings, position, color, day of the week, date ....
    Customize icon wifi color
    Customize icon data color
    Show / hide traffic data, color, type of traffic data and display refresh rate.
    Operator customization.
    Show / hide notifications in progress.
    Show / hide floating notifications.
    Customization statusbar color
    Customization 3minibattery batteries
    Enable / disable different settings by clicking on the statusbar.
    Change dpi.
    Disable advertising.
    Different types of systemui including android 6.
    Choice of themes
    Customized by sliding to the left application.
    Choice between three types of launchers; icons small, medium and stock.
    Choice between 7 types of lockscreen
    Rom application*
    - Camera Multidpi
    - Launcher sertings, with long press on the screen
    - Emotion kernel r23 with better ram management*
    - Performance tweaks
    -Added S5 toolbox with all apks
    Toggles for Screenshot.
    Mode Sound off toggles
    SmartLock -fix
    -new extended flashlight restart recording and screen capture sound types ...
    Added recording calls.
    -Fixed issues from previous release*
    More things we forget.
    -Now Supports N910G
    R13.1 Pure Note 4 Experience
    ROM 14
    -New Base CPC2
    -New Options for emotion control toogles
    -Change all statusbar colors*
    -Added Flashlight on Reboot menu
    Note5 -aircommand IMPORTANT !!! SELECT Settings / SPEN / designing SPEN / DETECT ANY AND KEYBOARD SAMSUNG SPEN
    Visually and other settings -Modify contacts Note4
    -new kernel
    R 13.1
    -fix Spen handwriting and language selection
    -fix Position change toogle flashlight
    -fix Kernel stock
    -fix SecMyFiles2015
    -new launchers with larger icons on Emotion Control
    R 13
    - Base POK1
    - Zipalign
    - Lite
    - Root
    - Busybox
    - Added data
    - Support init.d
    - Making 560 dpi
    - Improving battery Tweaks
    - Fix sd
    - Added Multiusers
    - Added 1300 sources
    - 3 Minit Battery
    - Flashlight in Toogles
    - Blocking in clock and curtain
    - Added lock and home in curtain
    - Camara Multidpi
    - Custom boot animation
    - Option swipe to open apks
    - Choice of wipes
    - AROMA INSTALLER
    3 types of SystemUI
    Contacts Note 4 or 5
    3 Types of TouchWizHome Multidpi compatible with Swype
    note 4 to 5 Application
    Note 4 or 5 Sounds
    Keyboard S6 White or Black
    Stock enforcing or Kernel Kernel Emotion
    -CONTROL EMOTION
    Sfinder show/hide
    notification brighness visibility
    heads up notifications
    visible toggles shown
    ram cleaner with quick toggles
    disable on going notifications
    Color choice status bar
    Battery types and color
    buttons on the notifications bar
    battery changer
    dpi changer
    remove ads
    statusbar clock mods
    wifi and signal colors
    internet meter and change color
    personalization statusbar
    4 types different systemui choice and toggles
    3 types of touchWizHome choice multidpi
    choice of themes touchWizHome
    choice application by swiping to the left-swipe
    rom applications drawer emotion
    - New Superuser 2.56 Beta
    - Note 5 recent Windows style
    - Increased number of recent adjustments.
    - VOL + Lantern on screen turned off from settings.
    - Removed warning loud.
    AVVISO
    PROCEDENDO CON IL FLASH DI UNA CUSTOM RECOVERY E DELLA ROM FARETE SCATTARE KNOK A 0X1 INVALIDANDO PER SEMPRE LA GARANZIA DEL VOSTRO TERMINALE!
    PRIMA DI PROCEDE CON I SEGUENTI PASSI È CONSIGLIABILE FARE UN NANODRID BACKUP E UN BACKUP DELL EFS!!
    VERIFICATE DI AVERE MODEM E BOOTLOADER GIUSTI ! SE NON È COSÌ DOVRETE PROCEDE CON IL FLASH DI TALI TRAMITE ODIN! LI TROVATE ENTRAMBI PIU GIU NELL AREA DOWNLOAD!
    per aggiornare bootloader e / o il modem è necessario spegnere il telefono, attendere 10 secondi e poi passare direttamente alla modalità download ( Voldown + Home + Power) In Odin carica il bootloader utilizzando il tasto BL e / o il modem usando CP . Premere "Start".
    INSTALLAZIONE
    1.Wipe Data
    2.Wipe Cache
    3.Wipe dalvik cache
    4.Wipe System
    5.Install Rom zip
    Link per i Download
    R3.1 Pure Note 5 Experience
    Rom:
    http://www.mediafire.com/?yxalq16huycn6ls
    Bootloader:
    http://www.mediafire.com/?72i9jbzbmqbr8fb
    Modem:
    http://www.mediafire.com/?jd2jdna13aglyah
    Exposed:http://www.mediafire.com/?1aq5ag32atxg6bj
    Apk Exposed:http://www.mediafire.com/?yh02d66u77ci2xk
    R14 Pure Note 4 Experience
    Rom:
    http://www.mediafire.com/?z5y4saw7k1ccc8h
    Bootloader:
    http://www.mediafire.com/?lhe5xxoyltfc635
    Modem:
    http://www.mediafire.com/?91va1g08e0c8728
    Exposed:
    http://www.mediafire.com/?82o7t7hfebd2o70
    apk exposed:
    http://www.mediafire.com/?xbs0x35y2bvfyud
    SCREENSHOTS
    KERNEL THREAD
    http://forum.xda-developers.com/show...25&postcount=1
    Pagina Officiale xda
    http://forum.xda-developers.com/note...te-iv-t2976107
    Credits:
    @MyaRom For providing the base. @justArchi for his awesome Android Kitchen
    @gharrington (3Minit) @psycho_666 @EMSpilot for his Note 4 guides
    @rovo89 for the Xposed* @daxgirl for amazing Guides and Swipe up app.
    XDAevDB Information
    [N910F/G][Touchwiz][Aroma]Emotion Revolution Note 4R12.1 - Note 5 Port R2.1 [9 -Dec], ROM for the Samsung Galaxy Note 4
    Contributors
    aukhan,*Pafcholini,*jcanonico, placiano
    ROM OS VersionLollipop
    ROM KernelLinux 3.10.x
    ROM Firmware Required5.1.1
    Based OnTouchwiz
    Version Information
    StatusStable
    Current Stable VersionR10.1
    Stable Release Date2015-10-06
    Created*2014-12-18
    Last Updated*2015-12-21
    Ultima modifica di Emanuelbruno1993; 03-04-16 alle 14:00
  2. I seguenti 5 Utenti hanno ringraziato Emanuelbruno1993 per il post:
    lorenzo63 (10-10-15),matdzovo (08-11-15),N1m0Y (05-10-15),RinoFxx (05-10-15),turrikan (22-02-16)
    Zêna - Pianeta Genoa
    Mate 20 Pro
    Ringraziato 7,416 volte in 5,978 Posts
    - Le prime immagini sono corrotte
    - Consiglia un Nandroid Backup prima di procedere
    - Metti un avviso IN ROSSO sul fatto che flashare una Recovery e la Rom fa scattare Knox a 0x1 facendo perdere PER SEMPRE la garanzia
    Per il resto... mi sembra ok
    Apporta le correzioni...
    ...e poi la aggiungo a Cafè Point
    ___________________
  5. Il seguente Utente ha ringraziato Varioflex per il post:
    Emanuelbruno1993 (05-10-15)
  6. #3
    Senior Droid L'avatar di RinoFxx
    Sep 2014
    Ringraziato 106 volte in 96 Posts
    Emanuel ormai siamo io e te che portiamo avanti la conoscenza delle rom e la sezione modding del note 4!
    Ottima rom anche questa! Fortuna che gli sviluppatori per note 4 su xda sono molto attivi e validi...
  7. Il seguente Utente ha ringraziato RinoFxx per il post:
  8. #4
    Quote Originariamente inviato da RinoFxx Visualizza il messaggio
    Purtroppo non ho la possibilità di testarle tutte perche non ho tempo e il telefono mi serve... 😂
    Però appena ho due minuti sono contento di auitare a portare avanti la sezione modding proprio perché (come me tempo fa) molte persone vengono a Carcare le rom qui e purtroppo non le trovano... E magari si tirano in dietro perche non comprendono bene le guide in inglese...
  9. #5
    magenta
    Ringraziato 42 volte in 28 Posts
    Ciao,sono un po confuso sui vari step per aggiornare..... un piccolo aiutino per non fare errori.....io sono sulla 9.1...per aggiornare alla 10....come procedo?.....flesho bootloder....modem appropriati.....poi in recovery flesho la rom 10....con o senza wipe cache?.......wipe system non va fatto vero?......quando riparte ho i permessi ri root o devo fare altro?......grazie
    Device: xiaomi redmi note 3 pro
    Rom : Miui 7 global
    Kernel: Stock
  10. #6
    Quote Originariamente inviato da ermegenesi Visualizza il messaggio
    Ciao... 😊La rom è prerootata...e se leggi sopra c'è scritto che i permessi vanno concessi dalle impostazioni di supersu... Cmq è consigliabile fare un full wipe come nella guida prima del flash...Non so se cambiano la base sia buona cosa evitare il wipe system e data....io personalmente preferisco fare flash puliti.... 😉Ti ricordo di fare un nanodroid backup prima del flash per sicurezza... 😉
    Ultima modifica di Emanuelbruno1993; 05-10-15 alle 22:28
  11. Il seguente Utente ha ringraziato Emanuelbruno1993 per il post:
    ermegenesi (05-10-15)
  12. #7
    magenta
    ...quindi faccio un full wipe e installo la rom come se fosse la prima volta.....anticipando con odin il flash del nuovo bootloder e modem. ok grazie
    Rom : Miui 7 global
    Kernel: Stock
  13. Il seguente Utente ha ringraziato ermegenesi per il post:
  14. #8
    Androidiano L'avatar di donflaminio
    milano
    htc wildfire EX ora SGS3
    Ringraziato 13 volte in 8 Posts
    buonasera..
    non capisco come mai odin non mi carica ne il bootloader ne il modem..
    mi da errore binario..
    Ultima modifica di donflaminio; 06-10-15 alle 23:13
    (Sgs 3)
  15. #9
    Quote Originariamente inviato da donflaminio Visualizza il messaggio
    buonasera..
    posta una foto o uno screen con l errore che ti da odin... Non essendomi mai capitata una cosa così non saprei aiutarti sinceramente.... Ma magari qualcuno che ne sa più di me ti può dare una dritta.. 😉
  16. #10
    milano
    odin.jpgnon mi carica i file odin magari sono corrotti ... (forse)...
    Ultima modifica di donflaminio; 06-10-15 alle 23:39
    (Sgs 3)
