Utente del giorno: hobin con ben 2 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 18 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 172
[RECOVERY] TWRP Recovery (N7100)
    Moderatore L'avatar di 8thphloor
    ONEPLUS2, NOTE2, NEXUS 7 2013
    Ringraziato 2,944 volte in 1,616 Posts
    TEAM WIN RECOVERY PROJECT PER SAMSUNG GALAXY NOTE II (N7100)
    Youtube video: http://www.youtube.com/watch?v=RIvWVS_Rkxo
    Thread ufficiale XDA: [TOOL/UTILITY][TWRP][ 2.8][RECOVERY] TWRP 2.… | Samsung Galaxy Note II GT-N7100, N7105 | XDA Forums
    Ultima release per Note2: 3.0.2-0
    Introduzione:
    Team Win Recovery Project o twrp in breve, è una custom recovery creata con in mente la facilità d'uso e di personalizzazione. E' basata sui sorgenti della recovery AOSP a cui sono state aggiunte le opzioni standard e un sacco di features create ad hoc. L'interfaccia è touch al 100%. La gui è gestita da file xml e completamente temabile.
    Features principali:
    Touchscreen driven with real buttons and drag-to-scroll
    XML-based GUI that allows full customization of the layout true theming!
    Settings are saved to the sdcard and persist through reboots
    Ability to choose which partitions to back up and which to restore
    Ability to choose to compress backups now with pigz (multi-core processor support for faster compression times)
    Onscreen keyboard
    Decryption of /data
    Easy selection of internal/external storage
    See changelog below for new features
    In addition to the above new features, TWRP features a scripting engine that allows an app to send commands to the recovery for the recovery to perform during startup. We call this scripting engine OpenRecoveryScript. This engine will be put to use immediately in the GooManager app. GooManager will be able to install recoveries automatically for most supported devices. The app will also let you choose to install multiple zips from within Android, wipe cache & dalvik, and run a backup.
    Problemi noti:
    I backup fatti con recovery CWM non sono compatibili. Sarà necessario fare un nuovo backup subito dopo l'installazione della TWRP se si proviene da CWM
    (i backup fatti con Philz recovery sono invece compatibili).
    Source Code:
    GitHub - https://github.com/omnirom/android_bootable_recovery
    Gerrit Instance - http://gerrit.omnirom.org
    Download e installazione:
    Link: Download TWRP for t03g
    La recovery si può flashare da Odin in AP (o PDA in base alle versioni), scegliendo la versione in formato .tar, o da altra recovery custom, scegliendo la versione .zip.
    La versione corretta per il nostro note2 N7100 è la t03g
    N.B. Il flash di una custom recovery su un dispositivo con bootloader successivo a MJ5 causa l'attivazione del Knox counter, con la conseguente perdita della garanzia!
    Supporto:
    Supporto live qui: freenode Web IRC (qwebirc)
    Altro supporto: #twrp sui server IRC Freenode
    Ultima modifica di 8thphloor; 22-04-16 alle 14:41
    The answer to the ultimate question of life, the universe and everything is:
    CLEAN FLASH
  2. I seguenti 2 Utenti hanno ringraziato 8thphloor per il post:
    mellagarga (10-12-15),NiloGlock (28-05-15)
    Apr 2010
    Droidland
    reserved for future use
  5. #3
    Riserva Navajo
    che bella
  6. #4
    Apr 2010
    Droidland
    Quote Originariamente inviato da Andromeda1968 Visualizza il messaggio
    che bella
    Ede' la versione base ,se vedi i temi ...e' sublime la uso da sempre su htc ed anche su gnexus.Supporta il nandroid backup con compressione variabile ed il salvataggio su usb(con usb host )
    Piccolo esempio della potenzialita' theming
  7. #5
    Riserva Navajo
    mi manca solo un piccolo particolare....ma piccolo piccolo.....
    il Note II
  8. #6
    Androidiani Power User L'avatar di Picciotto
    vBulletin
    Nexus 5 P9+ P10+
    Ringraziato 3,631 volte in 1,957 Posts
    Rilasciata la 2.3.1.1 scusate se non metto il link ma ci sto vedendo doppio
    Inviato dal mio GT-N7100 con tapatalk 3 E' GROSSO
  9. #7
    Apr 2010
    Droidland
    Il link non lo pubblico di certo finche la recovery e' in fase sperimentale su questo non ci piove
  10. #8
    forli
    galaxy s2
    Scusate la domanda ma questa recovery andra a sostituire la cwm ? (Quand sara pronta per note 2 dovro installarla come si faceva con rom manager giusto?)
    Inviato dal mio GT-N7100 usando
    le mani per spingere i tasti
  11. #9
    vBulletin
    Nexus 5 P9+ P10+
    Quote Originariamente inviato da Chryss69 Visualizza il messaggio
    Hai 2 possibilità o fleshi con odin il file .tar o se hai la cwm fleshi il file .zip
  12. #10
    forli
    galaxy s2
    E gia fattibile o deve uscire ancora "bene " per note 2
