Utente del giorno: carotix con ben 6 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluemask con ben 6 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 25 Thanks ricevuti nell'ultimo mese
Pagina 8 di 11 primaprima ... 678910 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 106
[Kernel][RedPill]
  1. #71
    Androidiani Power User L'avatar di Picciotto
    vBulletin
    Nexus 5 P9+ P10+
    Ringraziato 3,631 volte in 1,957 Posts
    Quote Originariamente inviato da mitic Visualizza il messaggio
    E uscita la 1.00 però a qualche problemino
    Grazie mitic aggiorno OP....ma che problemi da?
    vBulletin
    Nexus 5 P9+ P10+
    RedPill Stable Revision 1.00:
    1. Exynos-Abuse Secured thru the low-level fix by AndreiLux (Thanks to AndreiLux)
    2. Using Official Google Toolchain 4.6.x
    3. Added the latest (v5.4) of the "faster crc32 algorithm" by Bob Pearson and Darrick Wong (Thanks to both of them)
    4. Added faux123 Dynamic fsync (Thanks to faux123)
    5. Enable Dynamic FSync and FSync Control to co-exist (Please read STweaks option to gain a better understanding)
    6. Backported ROW I/O scheduling algorithm (Thanks to Tatyana Brokhman)
    7. Revert to using original N7100 source bcmdhd drivers to fix WiFi for some users
    8. Added ability to increase brightness to 255 (Thanks to nebkat)
    9. Tick and workqueue updates from upstream kernel source (Please see commit log for details)
    10. Remove ntfs auto mounting since people use ExFAT and FAT32 while NTFS can be loaded by 3rd party tools
    11. Tweaked Ext2Int mount options
    12. Tweaked System mount options
    RedPill AOSP Revision 0.11:
    1. Exynos-Abuse Secured thru low-level fix by AndreiLux (Thanks to AndreiLux)
    3. Added Dynamic Writeback from 3.1 (Thanks to franciscofranco for the port)
    4. Added the latest (v5.4) of the "faster crc32 algorithm" by Bob Pearson and Darrick Wong (Thanks to both of them)
    7. Added ability to increase brightness to 255 (Thanks to nebkat)
    8. Tick and workqueue updates from upstream kernel source (Please see commit log for details)
    9. Remove ntfs auto mounting since people use ExFAT and FAT32 while NTFS can be loaded by 3rd party tools
    10. Tweaked System mount options
    11. Disable Ext2Int while I find a way to get around the new emulated mounts for multiuser support 4.2.1 brings (You can still use directory bind for some games and apps with large data requirements)
    Download in OP (Prima Pagina)
  4. #73
    Ringraziato 196 volte in 170 Posts
    Sì ma dicono che da il problema che da la sd danneggiata qualcuno a provato
  5. #74
    Androidiano L'avatar di Elvecio
    Finalmente arrivati ad un buon livello di sviluppo...faccio qualche ciclo di carica col Perseus, se non mi piace mi sa che torno : )
  6. #75
    Salve a tutti...
    Sto cercando disperatamente questo kernel in versione 1.30 con estensione TAR!!!
    ho un problema....non capisco xke il mio note 2 non ne vuole sapere di entrare in recovery mode...mi spiego meglio ho installato ROM Manager e ovviamente l'ultima CWM...ma quando digito per farlo riavviare in recovery il cellulare entra nella recovery stock e non quella CWM.
    quindi vorrei trovare suddetto kernel in TAR in modo da flashare con odin...
    Grazie in anticipo per gli aiuti.
  7. #76
    Androidiano VIP L'avatar di wolvie80
    Cameri (NO)
    Ringraziato 958 volte in 648 Posts
    Quote Originariamente inviato da pantaleodavide Visualizza il messaggio
    Salve a tutti...
    ma lascia stare rom manager e flasha la cmw di philz con odin!
    comunque non credo esista questo kernel in versione tar non essendo presente neanche su xda...
  8. Il seguente Utente ha ringraziato wolvie80 per il post:
    pantaleodavide (01-03-13)
  9. #77
    Cavolo grazie mille ha funzionato!!!
    ciao ciao!
  10. #78
    galaxy note2
    Ringraziato 33 volte in 30 Posts
    Ragazzi vedete che siamo arrivati alla versione 1.30
  11. #79
    vBulletin
    Nexus 5 P9+ P10+
    Lo stavo aspettando da tempo visto che è il mio kernel preferito nuova release ricca di novità e subito in stress test RedPill v1.42 | Changelog
  12. Il seguente Utente ha ringraziato Picciotto per il post:
    wolvie80 (23-03-13)
  13. #80
    Cameri (NO)
    Quote Originariamente inviato da Picciotto Visualizza il messaggio
    Bene era ora..
