[kernel][aosp|sammy] n.e.a.k.
    Androidiani Power User L'avatar di Picciotto
    vBulletin
    Nexus 5 P9+ P10+
    Ringraziato 3,631 volte in 1,957 Posts
    Caratteristiche
    Tutti i crediti vanno a simone201 e il team NEAR
    - Basata su Samsung official sources, aggiornato a 3.0.52
    - Governors: PegasusQ (default), Ondemand, LulzactiveV2, Performance, Conservative (module), Lazy (module)
    - Schedulers: BFQv5, Noop, SIO, VR (default)
    - Using JRCU (++smoothness, ++responsiveness)
    - XZ Compression only for KERNEL (--size)
    - Fully compatible with: NEAK Apps, Multi-Core Manager, Tegrak's Lulzactive app, Voltage Control, SetCPU, NSTools
    RAMDISK AND MISC:
    - LED Fade support (thx to teamhacksung) - seems broken on Note2
    - Init.d Support
    - CIFS and FUSE built in the kernel (no modules)
    - Android Logger (logcat) already enabled into the kernel
    - MULTI-CORE INTERFACE (renewed Tegrak's 2ndCore) -----> CLICK HERE for infos
    - FSync Control Interface (thx to Ezekeel - featured into uNEAK Engine)
    CPU/GPU:
    - NO OC!!!! (200-1600Mhz)
    - CPU Undervolt support (thx to netarchy, Entropy512 & AndreiLux)
    - Complete control of freqs/voltages with Voltage Control/SetCPU/uNEAK
    - GPU Overclock/Undervolt & Stepcount Interface (by gm & AndreiLux)
    - Charging current interface support (original by gm, ported by me) ----> AC, USB, MISC and DOCK supported
    - Speedmod Sharpness fix (thx to hardcore & AndreiLux)
    MEMORY & PERFORMACES:
    - ARM CPU Topology + Sched_MC (can be enabled via NEAK App, disabled by default)
    - SLQB Memory Allocator (better memory management)
    - Improved memory management functions
    - Allow CPU Unaligned access (++performaces)
    - Reduced a bit the debug (still need to strip it down for real)
    - AFTR ARM Idle Mode (enable via uNEAK Engine) (++battery)
    CONNECTIVITY TWEAKS:
    - Stochastic Fair Blue NET Scheduler
    - Reduced debugging WiFi/BT
    - TCP/IP Tweaks
    - TCP buffer tweaks
    OPTIMIZATIONS:
    - NO EXFAT SUPPORT (do not even ask for it please)
    - Heavily reduced debug system (logcat and last_kmsg support is still there) (++speed, --size)
    - Heavily Optimised TouchBooster logic
    - SW Sync framework support
    - Using Standalone Hotplug driver with non-hotplug governors (thx to gm)
    - 3 CPU cores OFF when screen is locked (thx to arighi for original implementation)
    - Upstream patches and fixes from Linux 3.2/3/4/5/6 mainline kernel
    - Compiled with Linaro GCC 4.7 (2012.11) + NEAK CFLAGS (heavily optimised) + Graphite Optimisations
    - Optimised EXT4 filesystem
    - Generally optimised code (removed useless functions and variables, fixed warnings)
    and many others...
    UNIQUE
    - MULTI-CORE INTERFACE (features also Multi-Core Manager App)
    - uNEAK ENGINE APP (available for free - Check out Play Store)
    - NO COMPRESSION for Ramdisks
    - FSync Control interface (thx to Ezekeel)
    - Tweaked PegasusQ, Ondemand, lulzactive and lazy governors
    - Tweaked BFQ, SIO and VR Schedulers for NAND devices
    Changelog
    v1.0x (AOSP&SAMMY):
    KERNEL:
    - Based on Samsung Official Sources (for N7100)
    - Updated to Linux 3.0.52
    - CPU Undervolt interface
    - GPU OC/UV interface
    - Charge Current interface
    - All the above features included
    - All NEAK features (from S3) included
    - Features the new uNEAK Engine APP (free - on the play store)
    - Various govs and schedulers
    RAMDISK:
    - Stock and AOSP ramdisks with NEAK mods and tweaks
    MISC:
    - Check above
    Download
    http://forum.xda-developers.com/show....php?t=2000328
  2. Il seguente Utente ha ringraziato Picciotto per il post:
    checco1926 (16-09-13)
    vBulletin
    Nexus 5 P9+ P10+
    Riservato......
    Non capisco perche il titolo lo ha scritto in minuscolo sia qui che nell' altro post
    aiuto mod
  5. Il seguente Utente ha ringraziato Picciotto per il post:
  6. #3
    vBulletin
    Nexus 5 P9+ P10+
  7. Il seguente Utente ha ringraziato Picciotto per il post:
