[SOUNDMOD][21/6] CodexSound™ HD 4.3 "end of the line" !!
Non credevi di poter migliorara ed aumentare l'audio del tuo dispositivo? Funziona con il tuo dispositivo e ti darà il risultato desiderato
Ecco il vero mod audio per il vostro dispositivo
http://img194.imageshack.us/img194/6034/w9q.png
What is CodexSound ?
Mod pack per migliorare le prestazioni AUDIO |
LE CARATTERISTICHE AGGIUNTE
22 June
- compatible with Poweramp !!!
- even when stay in the music app. when turn on the setting and then leave the player lose his settings .
- System Wide audio
- xLoud ported for N7100
- SoundEnhancement full working From Xperia z
- Super Bass (Best feature of the mod)
- Surround Sound
- Clear Audio+ but true ported for N7100
- ClearPhase feel sounds improvement when open walkman
- Clear Bass
- Clear Stereo
- New Powerful custom compiled audio libraries
- SoX Codec for Superior Audio quality
- MP3 LAME Codec for Superior MP3 Quality
- Audio Fluence mode set to Broadside
- Qualcomm Fluence mode set to FluencePRO
- Custom made ALSA with auto config feature
- Audio Resampling from Android 4.1.x with level set to maximum of 4
- SRS Effect ENABLED (But does not load TruMedia effects so it's just a simple SRS virtualization)
- Custom tuned snd_soc_msm main audio configs
- Slightly louder audio
- Live and Beating Drums
- New Walkman From Xperia Z
- New Walkman Visualizer From Xperia Z
- Noozxoide EIZO as DSP
- TrackID From Xperia Z
- Dynamic Normalizer
- ClearPhase
- auto remove DSP/MusicFX
Compatibility
DOVREBBE ESSERE COMPATIBILE CON TUTTE LE ROM SAMMY
DOVREBBE ESSERE INCOMPATIBILE CON LE ROM AOSP
Downloads
Download !! CodexSound v4.3 High Definition
istruzioni d'installazione
esegui prima un nandroid backup e successivamente esegui l'installazione da recovery
NON DIMENTICARE DI CAMBIARE I SETTAGGI DEGLI EFFETTI MUSICALI
COME ABILITARE ClearPhase/ClearAudio+ ?
http://img42.imageshack.us/img42/3865/wjae.png
http://img819.imageshack.us/img819/8605/r7j.png
SE GRADISCI IL MIO LAVORO PREMI GRAZIE
INSERISCI QUESTO BANNER IN FIRMA SE RESTI SODDISFATTO DEL MOD
http://img35.imageshack.us/img35/559/78188272.png
cheers again !! http://forum.xda-developers.com/imag...rs-crossed.gif
